Hello @ShaneCCC and @JerryChang
I have changed port-index to 0 from 2 in all places and tegra_sinterface to "serial_a"from serial_c but sill iam unable to get any video
I checked “v4l2-ctl --device /dev/video0 --all” in terminal and VI got enumurated as VI port 0
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, ov5693 1-0036
Bus info : *platform:15c10000.vi:0*
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 0: no power)
Format Video Capture:
Width/Height : 1920/1080
Pixel Format : 'BG10'
Field : None
Bytes per Line : 3840
Size Image : 4147200
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Camera Controls
group_hold 0x009a2003 (bool) : default=0 value=0 flags=execute-on-write
hdr_enable 0x009a2004 (intmenu): min=0 max=1 default=0 value=0
eeprom_data 0x009a2005 (str) : min=0 max=2048 step=2 value='00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' flags=read-only, has-payload
otp_data 0x009a2006 (str) : min=0 max=1024 step=2 value='0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000' flags=read-only, has-payload
fuse_id 0x009a2007 (str) : min=0 max=16 step=2 value='0000000000000000' flags=read-only, has-payload
gain 0x009a2009 (int64) : min=0 max=0 step=0 default=0 value=10 flags=slider
exposure 0x009a200a (int64) : min=0 max=0 step=0 default=0 value=34 flags=slider
frame_rate 0x009a200b (int64) : min=0 max=0 step=0 default=0 value=1816577 flags=slider
exposure_short 0x009a200c (int64) : min=0 max=0 step=0 default=0 value=34 flags=slider
sensor_configuration 0x009a2032 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
sensor_mode_i2c_packet 0x009a2033 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
sensor_control_i2c_packet 0x009a2034 (u32) : min=0 max=0 step=0 default=0 flags=read-only, volatile, has-payload
bypass_mode 0x009a2064 (intmenu): min=0 max=1 default=0 value=0
override_enable 0x009a2065 (intmenu): min=0 max=1 default=0 value=0
height_align 0x009a2066 (int) : min=1 max=16 step=1 default=1 value=1
size_align 0x009a2067 (intmenu): min=0 max=2 default=0 value=0
write_isp_format 0x009a2068 (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties 0x009a2069 (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties 0x009a206a (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties 0x009a206b (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings 0x009a206c (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
low_latency_mode 0x009a206d (bool) : default=0 value=0
sensor_modes 0x009a2082 (int) : min=0 max=30 step=1 default=30 value=3 flags=read-only
Device tree source code:
host1x {
vi@15c10000 {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
e3326_vi_in0: endpoint {
port-index = <0>;
bus-width = <2>;
remote-endpoint = <&e3326_csi_out0>;
};nvcsi@15a00000 { num-channels = <1>; #address-cells = <1>; #size-cells = <0>; channel@0 { reg = <0>; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; e3326_csi_in0: endpoint@0 { port-index = <0>; bus-width = <2>; remote-endpoint = <&e3326_ov5693_out0>; }; }; port@1 { reg = <1>; e3326_csi_out0: endpoint@1 { remote-endpoint = <&e3326_vi_in0>; }; }; }; }; };
i2c@c240000 {
ov5693_c@36 {
compatible = “nvidia,ov5693”;
/* I2C device address */
reg = <0x36>;/* V4L2 device node location */ devnode = "video0"; /* Physical dimensions of sensor */ physical_w = "3.674"; physical_h = "2.738"; /* Define any required hw resources needed by driver */ /* ie. clocks, io pins, power sources */ avdd-reg = "vana"; iovdd-reg = "vif"; /* Sensor output flip settings */ vertical-flip = "true"; /** * A modeX node is required to support v4l2 driver * implementation with NVIDIA camera software stack * * mclk_khz = ""; * Standard MIPI driving clock, typically 24MHz * * num_lanes = ""; * Number of lane channels sensor is programmed to output * * tegra_sinterface = ""; * The base tegra serial interface lanes are connected to * Incase of virtual HW devices, use virtual * For SW emulated devices, use host * * phy_mode = ""; * PHY mode used by the MIPI lanes for this device * * discontinuous_clk = ""; * The sensor is programmed to use a discontinuous clock on MIPI lanes * * dpcm_enable = "true"; * The sensor is programmed to use a DPCM modes * * cil_settletime = ""; * MIPI lane settle time value. * A "0" value attempts to autocalibrate based on mclk_multiplier * * * * * active_w = ""; * Pixel active region width * * active_h = ""; * Pixel active region height * * pixel_t = ""; * The sensor readout pixel pattern * * readout_orientation = "0"; * Based on camera module orientation. * Only change readout_orientation if you specifically * Program a different readout order for this mode * * line_length = ""; * Pixel line length (width) for sensor mode. * This is used to calibrate features in our camera stack. * * mclk_multiplier = ""; * Multiplier to MCLK to help time hardware capture sequence * TODO: Assign to PLL_Multiplier as well until fixed in core * * pix_clk_hz = ""; * Sensor pixel clock used for calculations like exposure and framerate * * * * * inherent_gain = ""; * Gain obtained inherently from mode (ie. pixel binning) * * == Source Control Settings == * * Gain factor used to convert fixed point integer to float * Gain range [min_gain/gain_factor, max_gain/gain_factor] * Gain step [step_gain/gain_factor is the smallest step that can be configured] * Default gain [Default gain to be initialized for the control. * use min_gain_val as default for optimal results] * Framerate factor used to convert fixed point integer to float * Framerate range [min_framerate/framerate_factor, max_framerate/framerate_factor] * Framerate step [step_framerate/framerate_factor is the smallest step that can be configured] * Default Framerate [Default framerate to be initialized for the control. * use max_framerate to get required performance] * Exposure factor used to convert fixed point integer to float * For convenience use 1 sec = 1000000us as conversion factor * Exposure range [min_exp_time/exposure_factor, max_exp_time/exposure_factor] * Exposure step [step_exp_time/exposure_factor is the smallest step that can be configured] * Default Exposure Time [Default exposure to be initialized for the control. * Set default exposure based on the default_framerate for optimal exposure settings] * * gain_factor = ""; (integer factor used for floating to fixed point conversion) * min_gain_val = ""; (ceil to integer) * max_gain_val = ""; (ceil to integer) * step_gain_val = ""; (ceil to integer) * default_gain = ""; (ceil to integer) * Gain limits for mode * * exposure_factor = ""; (integer factor used for floating to fixed point conversion) * min_exp_time = ""; (ceil to integer) * max_exp_time = ""; (ceil to integer) * step_exp_time = ""; (ceil to integer) * default_exp_time = ""; (ceil to integer) * Exposure Time limits for mode (us) * * * min_hdr_ratio = ""; * max_hdr_ratio = ""; * HDR Ratio limits for mode * * framerate_factor = ""; (integer factor used for floating to fixed point conversion) * min_framerate = ""; * max_framerate = ""; * step_framerate = ""; (ceil to integer) * default_framerate = ""; (ceil to integer) * Framerate limits for mode (fps) */ mode0 { // OV5693_MODE_2592X1944 mclk_khz = "24000"; num_lanes = "2"; tegra_sinterface = "serial_a"; phy_mode = "DPHY"; discontinuous_clk = "yes"; dpcm_enable = "false"; cil_settletime = "0"; active_w = "1920"; active_h = "1080"; mode_type = "bayer"; pixel_phase = "bggr"; csi_pixel_bit_depth = "10"; readout_orientation = "0"; line_length = "1935"; inherent_gain = "1"; mclk_multiplier = "6.67"; pix_clk_hz = "90000000"; gain_factor = "10"; min_gain_val = "10";/* 1DB*/ max_gain_val = "160";/* 16DB*/ step_gain_val = "1"; default_gain = "10"; min_hdr_ratio = "1"; max_hdr_ratio = "1"; framerate_factor = "1000000"; min_framerate = "1816577";/*1.816577 */ max_framerate = "30000000";/*30*/ step_framerate = "1"; default_framerate = "30000000"; exposure_factor = "1000000"; min_exp_time = "34";/* us */ max_exp_time = "550385";/* us */ step_exp_time = "1"; default_exp_time = "33334";/* us */ embedded_metadata_height = "0"; }; mode1 { //OV5693_MODE_2592X1458 mclk_khz = "24000"; num_lanes = "2"; tegra_sinterface = "serial_a"; phy_mode = "DPHY"; discontinuous_clk = "yes"; dpcm_enable = "false"; cil_settletime = "0"; active_w = "2592"; active_h = "1458"; mode_type = "bayer"; pixel_phase = "bggr"; csi_pixel_bit_depth = "10"; readout_orientation = "0"; line_length = "2688"; inherent_gain = "1"; mclk_multiplier = "6.67"; pix_clk_hz = "90000000"; gain_factor = "10"; min_gain_val = "10";/* 1DB*/ max_gain_val = "160";/* 16DB*/ step_gain_val = "1"; default_gain = "10"; min_hdr_ratio = "1"; max_hdr_ratio = "1"; framerate_factor = "1000000"; min_framerate = "1816577";/*1.816577 */ max_framerate = "30000000";/*30*/ step_framerate = "1"; default_framerate = "30000000"; exposure_factor = "1000000"; min_exp_time = "34";/* us */ max_exp_time = "550385";/* us */ step_exp_time = "1"; default_exp_time = "33334";/* us */ embedded_metadata_height = "0"; }; mode2 { //OV5693_MODE_1280X720 mclk_khz = "24000"; num_lanes = "2"; tegra_sinterface = "serial_a"; phy_mode = "DPHY"; discontinuous_clk = "yes"; dpcm_enable = "false"; cil_settletime = "0"; active_w = "1280"; active_h = "720"; mode_type = "bayer"; pixel_phase = "bggr"; csi_pixel_bit_depth = "10"; readout_orientation = "0"; line_length = "1752"; inherent_gain = "1"; mclk_multiplier = "6.67"; pix_clk_hz = "90000000"; gain_factor = "10"; min_gain_val = "10";/* 1DB*/ max_gain_val = "160";/* 16DB*/ step_gain_val = "1"; default_gain = "10"; min_hdr_ratio = "1"; max_hdr_ratio = "1"; framerate_factor = "1000000"; min_framerate = "2787078";/* 2.787078 */ max_framerate = "120000000";/* 120*/ step_framerate = "1"; default_framerate = "120000000"; exposure_factor = "1000000"; min_exp_time = "22";/* us */ max_exp_time = "358733";/* us */ step_exp_time = "1"; default_exp_time = "8334";/* us */ embedded_metadata_height = "0"; }; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; e3326_ov5693_out0: endpoint { port-index = <0>; bus-width = <2>; remote-endpoint = <&e3326_csi_in0>; }; }; }; };
e3326_lens_ov5693@P5V27C {
min_focus_distance = “0.0”;
hyper_focal = “0.0”;
focal_length = “2.67”;
f_number = “2.0”;
aperture = “2.0”;
};tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
* Physical settings to calculate max ISO BW
* num_csi_lanes = <>;
* Total number of CSI lanes when all cameras are active
* max_lane_speed = <>;
* Max lane speed in Kbit/s
* min_bits_per_pixel = <>;
* Min bits per pixel
* vi_peak_byte_per_pixel = <>;
* Max byte per pixel for the VI ISO case
* vi_bw_margin_pct = <>;
* Vi bandwidth margin in percentage
* max_pixel_rate = <>;
* Max pixel rate in Kpixel/s for the ISP ISO case
* isp_peak_byte_per_pixel = <>;
* Max byte per pixel for the ISP ISO case
* isp_bw_margin_pct = <>;
* Isp bandwidth margin in percentage
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <160000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;/** * The general guideline for naming badge_info contains 3 parts, and is as follows, * The first part is the camera_board_id for the module; if the module is in a FFD * platform, then use the platform name for this part. * The second part contains the position of the module, ex. “rear” or “front”. * The third part contains the last 6 characters of a part number which is found * in the module's specsheet from the vender. */ modules { module0 { badge = "e3326_front_P5V27C"; position = "rear"; orientation = "1"; drivernode0 { /* Declare PCL support driver (classically known as guid) */ pcl_id = "v4l2_sensor"; /* Driver v4l2 device name */ devname = "ov5693 2-0036"; /* Declare the device-tree hierarchy to driver instance */ proc-device-tree = "/proc/device-tree/i2c@c240000/ov5693_c@36"; }; drivernode1 { /* Declare PCL support driver (classically known as guid) */ pcl_id = "v4l2_lens"; proc-device-tree = "/proc/device-tree/e3326_lens_ov5693@P5V27C/"; }; }; };
But still iam unable to get the video , following messages were obtained this time instead of no response from terminal
root@rev-desktop:~# v4l2-ctl --stream-mmap --stream-count=1 -d /dev/video0
VIDIOC_STREAMON: failed: Invalid argument
Trace logs:
# tracer: nop
# entries-in-buffer/entries-written: 183/183 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-23467 [003] .... 1082.634809: tegra_channel_open: vi-output, ov5693 1-0036
v4l2-ctl-23467 [002] .... 1082.637350: tegra_channel_set_power: ov5693 1-0036 : 0x1
v4l2-ctl-23467 [002] .... 1082.637496: camera_common_s_power: status : 0x1
v4l2-ctl-23467 [002] .... 1082.642273: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-23467 [002] .... 1082.642284: csi_s_power: enable : 0x1
v4l2-ctl-23467 [002] .... 1082.654557: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
v4l2-ctl-23467 [002] .n.. 1082.670717: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-23467 [002] .... 1082.679236: tegra_channel_set_stream: 15a00000.nvcsi--1 : 0x1
v4l2-ctl-23467 [002] .... 1082.679243: csi_s_stream: enable : 0x1
v4l2-ctl-23467 [002] .... 1082.679293: tegra_channel_set_stream: ov5693 1-0036 : 0x1
kworker/1:2-23123 [001] .... 1082.684858: rtos_queue_peek_from_isr_failed: tstamp:34151818154 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1082.684864: rtcpu_start: tstamp:34151822228
kworker/1:2-23123 [001] .... 1082.684868: rtos_queue_send_from_isr_failed: tstamp:34151940637 queue:0x0bcb41f8
kworker/1:2-23123 [001] .... 1082.684869: rtos_queue_send_from_isr_failed: tstamp:34151940860 queue:0x0bcb8a60
kworker/1:2-23123 [001] .... 1082.684870: rtos_queue_send_from_isr_failed: tstamp:34151941083 queue:0x0bcba5e0
kworker/1:2-23123 [001] .... 1082.684872: rtos_queue_send_from_isr_failed: tstamp:34151941328 queue:0x0bcbb3a0
kworker/1:2-23123 [001] .... 1082.684873: rtos_queue_send_from_isr_failed: tstamp:34151941546 queue:0x0bcbc160
kworker/1:2-23123 [001] .... 1082.684876: rtcpu_string: tstamp:34151942259 id:0x04010000 str:"Configuring VI GoS.
kworker/1:2-23123 [001] .... 1082.684933: rtcpu_string: tstamp:34151942526 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/1:2-23123 [001] .... 1082.684954: rtcpu_string: tstamp:34151942856 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/1:2-23123 [001] .... 1082.684973: rtcpu_string: tstamp:34151943227 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/1:2-23123 [001] .... 1082.684991: rtcpu_string: tstamp:34151943535 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/1:2-23123 [001] .... 1082.685009: rtcpu_string: tstamp:34151943844 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/1:2-23123 [001] .... 1082.685027: rtcpu_string: tstamp:34151944152 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/1:2-23123 [001] .... 1082.685045: rtcpu_string: tstamp:34151952154 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
kworker/1:2-23123 [001] .... 1082.685047: rtcpu_string: tstamp:34151952344 id:0x04010000 str:"on 2.2
kworker/1:2-23123 [001] .... 1082.685066: rtos_queue_send_from_isr_failed: tstamp:34151982650 queue:0x0bcb41f8
kworker/1:2-23123 [001] .... 1082.685067: rtos_queue_send_from_isr_failed: tstamp:34151982875 queue:0x0bcb8a60
kworker/1:2-23123 [001] .... 1082.685069: rtos_queue_send_from_isr_failed: tstamp:34151983102 queue:0x0bcba5e0
kworker/1:2-23123 [001] .... 1082.685070: rtos_queue_send_from_isr_failed: tstamp:34151983320 queue:0x0bcbb3a0
kworker/1:2-23123 [001] .... 1082.685071: rtos_queue_send_from_isr_failed: tstamp:34151983536 queue:0x0bcbc160
kworker/1:2-23123 [001] .... 1082.685073: rtcpu_string: tstamp:34151984724 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/1:2-23123 [001] .... 1082.685091: rtos_queue_send_from_isr_failed: tstamp:34152262079 queue:0x0bcb41f8
kworker/1:2-23123 [001] .... 1082.685093: rtos_queue_send_from_isr_failed: tstamp:34152262258 queue:0x0bcb8a60
kworker/1:2-23123 [001] .... 1082.685094: rtos_queue_send_from_isr_failed: tstamp:34152262421 queue:0x0bcba5e0
kworker/1:2-23123 [001] .... 1082.685096: rtos_queue_send_from_isr_failed: tstamp:34152262578 queue:0x0bcbb3a0
kworker/1:2-23123 [001] .... 1082.685097: rtos_queue_send_from_isr_failed: tstamp:34152262735 queue:0x0bcbc160
kworker/1:2-23123 [001] .... 1082.740810: rtcpu_vinotify_event: tstamp:34152454794 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:32006626112 data:0x10000000
kworker/1:2-23123 [001] .... 1082.740816: rtcpu_vinotify_event: tstamp:34152454958 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:32006629920 data:0x31000001
kworker/1:2-23123 [001] .... 1082.740817: rtcpu_vinotify_event: tstamp:34152455138 tag:RESERVED_19 channel:0x23 frame:0 vi_tstamp:32006630912 data:0x07020001
kworker/1:2-23123 [001] .... 1082.740819: rtcpu_vinotify_event: tstamp:34152455284 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:32006685248 data:0x10000000
kworker/1:2-23123 [001] .... 1082.740820: rtcpu_vinotify_event: tstamp:34152455474 tag:RESERVED_18 channel:0x23 frame:0 vi_tstamp:32006689120 data:0x31000002
kworker/1:2-23123 [001] .... 1082.852812: rtos_queue_peek_from_isr_failed: tstamp:34156818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1083.020819: rtos_queue_peek_from_isr_failed: tstamp:34161818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1083.188746: rtos_queue_peek_from_isr_failed: tstamp:34166818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1083.356724: rtos_queue_peek_from_isr_failed: tstamp:34171818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1083.468723: rtos_queue_peek_from_isr_failed: tstamp:34176818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1083.636688: rtos_queue_peek_from_isr_failed: tstamp:34181818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1083.804681: rtos_queue_peek_from_isr_failed: tstamp:34186818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1083.972692: rtos_queue_peek_from_isr_failed: tstamp:34191818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1084.140635: rtos_queue_peek_from_isr_failed: tstamp:34196818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1084.308621: rtos_queue_peek_from_isr_failed: tstamp:34201818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1084.476617: rtos_queue_peek_from_isr_failed: tstamp:34206818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1084.588585: rtos_queue_peek_from_isr_failed: tstamp:34211818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1084.756552: rtos_queue_peek_from_isr_failed: tstamp:34216818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1084.924545: rtos_queue_peek_from_isr_failed: tstamp:34221818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1085.092493: rtos_queue_peek_from_isr_failed: tstamp:34226818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1085.260521: rtos_queue_peek_from_isr_failed: tstamp:34231818535 queue:0x0bcbcf78
vi-output, ov56-23469 [000] .... 1085.275118: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt c4
v4l2-ctl-23467 [003] .... 1085.278868: tegra_channel_close: vi-output, ov5693 1-0036
v4l2-ctl-23467 [003] .... 1085.280909: tegra_channel_set_power: ov5693 1-0036 : 0x0
v4l2-ctl-23467 [003] .... 1085.280928: camera_common_s_power: status : 0x0
v4l2-ctl-23467 [000] .... 1085.283274: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
v4l2-ctl-23467 [000] .... 1085.283280: csi_s_power: enable : 0x0
kworker/1:2-23123 [001] .... 1085.316481: rtos_queue_send_from_isr_failed: tstamp:34233315965 queue:0x0bcb41f8
kworker/1:2-23123 [001] .... 1085.316488: rtos_queue_send_from_isr_failed: tstamp:34233316127 queue:0x0bcb8a60
kworker/1:2-23123 [001] .... 1085.316490: rtos_queue_send_from_isr_failed: tstamp:34233316291 queue:0x0bcba5e0
kworker/1:2-23123 [001] .... 1085.316491: rtos_queue_send_from_isr_failed: tstamp:34233316449 queue:0x0bcbb3a0
kworker/1:2-23123 [001] .... 1085.316493: rtos_queue_send_from_isr_failed: tstamp:34233316606 queue:0x0bcbc160
kworker/1:2-23123 [001] .... 1085.316494: rtos_queue_send_from_isr_failed: tstamp:34233378081 queue:0x0bcb41f8
kworker/1:2-23123 [001] .... 1085.316496: rtos_queue_send_from_isr_failed: tstamp:34233378243 queue:0x0bcb8a60
kworker/1:2-23123 [001] .... 1085.316498: rtos_queue_send_from_isr_failed: tstamp:34233378408 queue:0x0bcba5e0
kworker/1:2-23123 [001] .... 1085.316499: rtos_queue_send_from_isr_failed: tstamp:34233378565 queue:0x0bcbb3a0
kworker/1:2-23123 [001] .... 1085.316501: rtos_queue_send_from_isr_failed: tstamp:34233378723 queue:0x0bcbc160
kworker/1:2-23123 [001] .... 1085.316504: rtcpu_string: tstamp:34233385400 id:0x04010000 str:"Configuring VI GoS.
kworker/1:2-23123 [001] .... 1085.316557: rtcpu_string: tstamp:34233385594 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/1:2-23123 [001] .... 1085.316579: rtcpu_string: tstamp:34233385856 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/1:2-23123 [001] .... 1085.316599: rtcpu_string: tstamp:34233386131 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/1:2-23123 [001] .... 1085.316618: rtcpu_string: tstamp:34233386372 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/1:2-23123 [001] .... 1085.316637: rtcpu_string: tstamp:34233386616 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/1:2-23123 [001] .... 1085.316656: rtcpu_string: tstamp:34233386857 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/1:2-23123 [001] .... 1085.428498: rtos_queue_peek_from_isr_failed: tstamp:34236818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1085.596486: rtos_queue_peek_from_isr_failed: tstamp:34241818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1085.708472: rtos_queue_peek_from_isr_failed: tstamp:34246818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1085.876402: rtos_queue_peek_from_isr_failed: tstamp:34251818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1086.044386: rtos_queue_peek_from_isr_failed: tstamp:34256818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1086.212371: rtos_queue_peek_from_isr_failed: tstamp:34261818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1086.380335: rtos_queue_peek_from_isr_failed: tstamp:34266818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1086.548330: rtos_queue_peek_from_isr_failed: tstamp:34271818533 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1086.716307: rtos_queue_peek_from_isr_failed: tstamp:34276818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1086.828320: rtos_queue_peek_from_isr_failed: tstamp:34281818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1086.996319: rtos_queue_peek_from_isr_failed: tstamp:34286818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1087.164228: rtos_queue_peek_from_isr_failed: tstamp:34291818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1087.332212: rtos_queue_peek_from_isr_failed: tstamp:34296818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1087.500213: rtos_queue_peek_from_isr_failed: tstamp:34301818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1087.668189: rtos_queue_peek_from_isr_failed: tstamp:34306818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1087.836190: rtos_queue_peek_from_isr_failed: tstamp:34311818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1087.948126: rtos_queue_peek_from_isr_failed: tstamp:34316818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1088.116113: rtos_queue_peek_from_isr_failed: tstamp:34321818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1088.284082: rtos_queue_peek_from_isr_failed: tstamp:34326818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1088.452117: rtos_queue_peek_from_isr_failed: tstamp:34331818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1088.620036: rtos_queue_peek_from_isr_failed: tstamp:34336818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1088.788057: rtos_queue_peek_from_isr_failed: tstamp:34341818533 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1088.956011: rtos_queue_peek_from_isr_failed: tstamp:34346818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1089.068011: rtos_queue_peek_from_isr_failed: tstamp:34351818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1089.235963: rtos_queue_peek_from_isr_failed: tstamp:34356818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1089.403961: rtos_queue_peek_from_isr_failed: tstamp:34361818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1089.571939: rtos_queue_peek_from_isr_failed: tstamp:34366818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1089.739975: rtos_queue_peek_from_isr_failed: tstamp:34371818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1089.907887: rtos_queue_peek_from_isr_failed: tstamp:34376818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1090.075855: rtos_queue_peek_from_isr_failed: tstamp:34381818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1090.187828: rtos_queue_peek_from_isr_failed: tstamp:34386818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1090.355820: rtos_queue_peek_from_isr_failed: tstamp:34391818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1090.523831: rtos_queue_peek_from_isr_failed: tstamp:34396818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1090.691789: rtos_queue_peek_from_isr_failed: tstamp:34401818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1090.863740: rtos_queue_peek_from_isr_failed: tstamp:34406818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1091.031771: rtos_queue_peek_from_isr_failed: tstamp:34411818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1091.199757: rtos_queue_peek_from_isr_failed: tstamp:34416818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1091.311713: rtos_queue_peek_from_isr_failed: tstamp:34421818538 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1091.479679: rtos_queue_peek_from_isr_failed: tstamp:34426818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1091.647662: rtos_queue_peek_from_isr_failed: tstamp:34431818538 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1091.815647: rtos_queue_peek_from_isr_failed: tstamp:34436818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1091.983628: rtos_queue_peek_from_isr_failed: tstamp:34441818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1092.151587: rtos_queue_peek_from_isr_failed: tstamp:34446818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1092.319613: rtos_queue_peek_from_isr_failed: tstamp:34451818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1092.431568: rtos_queue_peek_from_isr_failed: tstamp:34456819274 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1092.599570: rtos_queue_peek_from_isr_failed: tstamp:34461818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1092.767529: rtos_queue_peek_from_isr_failed: tstamp:34466818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1092.935480: rtos_queue_peek_from_isr_failed: tstamp:34471818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1093.103524: rtos_queue_peek_from_isr_failed: tstamp:34476818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1093.271434: rtos_queue_peek_from_isr_failed: tstamp:34481818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1093.439438: rtos_queue_peek_from_isr_failed: tstamp:34486818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1093.551452: rtos_queue_peek_from_isr_failed: tstamp:34491818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1093.719391: rtos_queue_peek_from_isr_failed: tstamp:34496818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1093.887398: rtos_queue_peek_from_isr_failed: tstamp:34501818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1094.055353: rtos_queue_peek_from_isr_failed: tstamp:34506818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1094.223333: rtos_queue_peek_from_isr_failed: tstamp:34511818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1094.391303: rtos_queue_peek_from_isr_failed: tstamp:34516818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1094.559287: rtos_queue_peek_from_isr_failed: tstamp:34521818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1094.671263: rtos_queue_peek_from_isr_failed: tstamp:34526818531 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1094.839291: rtos_queue_peek_from_isr_failed: tstamp:34531818540 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1095.007227: rtos_queue_peek_from_isr_failed: tstamp:34536818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1095.175206: rtos_queue_peek_from_isr_failed: tstamp:34541818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1095.343193: rtos_queue_peek_from_isr_failed: tstamp:34546818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1095.511170: rtos_queue_peek_from_isr_failed: tstamp:34551818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1095.679125: rtos_queue_peek_from_isr_failed: tstamp:34556818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1095.791171: rtos_queue_peek_from_isr_failed: tstamp:34561818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1095.959102: rtos_queue_peek_from_isr_failed: tstamp:34566818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1096.127090: rtos_queue_peek_from_isr_failed: tstamp:34571818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1096.295073: rtos_queue_peek_from_isr_failed: tstamp:34576818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1096.463084: rtos_queue_peek_from_isr_failed: tstamp:34581818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1096.631032: rtos_queue_peek_from_isr_failed: tstamp:34586818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1096.799019: rtos_queue_peek_from_isr_failed: tstamp:34591818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1096.910998: rtos_queue_peek_from_isr_failed: tstamp:34596818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1097.078988: rtos_queue_peek_from_isr_failed: tstamp:34601818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1097.246941: rtos_queue_peek_from_isr_failed: tstamp:34606818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1097.414941: rtos_queue_peek_from_isr_failed: tstamp:34611818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1097.582917: rtos_queue_peek_from_isr_failed: tstamp:34616818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1097.750868: rtos_queue_peek_from_isr_failed: tstamp:34621818542 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1097.918900: rtos_queue_peek_from_isr_failed: tstamp:34626818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1098.030846: rtos_queue_peek_from_isr_failed: tstamp:34631818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1098.198842: rtos_queue_peek_from_isr_failed: tstamp:34636818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1098.366814: rtos_queue_peek_from_isr_failed: tstamp:34641818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1098.534793: rtos_queue_peek_from_isr_failed: tstamp:34646818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1098.702759: rtos_queue_peek_from_isr_failed: tstamp:34651818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1098.870758: rtos_queue_peek_from_isr_failed: tstamp:34656818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1099.038755: rtos_queue_peek_from_isr_failed: tstamp:34661818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1099.150719: rtos_queue_peek_from_isr_failed: tstamp:34666818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1099.318712: rtos_queue_peek_from_isr_failed: tstamp:34671818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1099.486669: rtos_queue_peek_from_isr_failed: tstamp:34676818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1099.654661: rtos_queue_peek_from_isr_failed: tstamp:34681818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1099.822641: rtos_queue_peek_from_isr_failed: tstamp:34686818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1099.990623: rtos_queue_peek_from_isr_failed: tstamp:34691818538 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1100.158589: rtos_queue_peek_from_isr_failed: tstamp:34696818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1100.270590: rtos_queue_peek_from_isr_failed: tstamp:34701818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1100.438559: rtos_queue_peek_from_isr_failed: tstamp:34706818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1100.606518: rtos_queue_peek_from_isr_failed: tstamp:34711818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1100.774541: rtos_queue_peek_from_isr_failed: tstamp:34716818538 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1100.942476: rtos_queue_peek_from_isr_failed: tstamp:34721818536 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1101.114481: rtos_queue_peek_from_isr_failed: tstamp:34726818535 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1101.226508: rtos_queue_peek_from_isr_failed: tstamp:34731818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1101.394472: rtos_queue_peek_from_isr_failed: tstamp:34736818539 queue:0x0bcbcf78
kworker/1:2-23123 [001] .... 1101.562421: rtos_queue_peek_from_isr_failed: tstamp:34741818536 queue:0x0bcbcf78
root@rev-desktop:~#
V4l2 compliance test
rev@rev-desktop:~$ v4l2-compliance
v4l2-compliance SHA : not available
Driver Info:
Bus info : platform:[15c10000.vi:0](http://15c10000.vi:0/)
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Compliance test for device /dev/video0 (not using libv4l2):
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second video open: OK
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
Debug ioctls:
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
test VIDIOC_LOG_STATUS: OK
Input ioctls:
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
test VIDIOC_G/S/ENUMINPUT: OK
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
test VIDIOC_G/S_EDID: OK (Not Supported)
Test input 0:
Control ioctls:
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: OK
test VIDIOC_QUERYCTRL: OK
test VIDIOC_G/S_CTRL: OK
test VIDIOC_G/S/TRY_EXT_CTRLS: OK
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: OK
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 1 Private Controls: 23
Format ioctls:
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
fail: v4l2-test-formats.cpp(1184): ret && node->has_frmintervals
test VIDIOC_G/S_PARM: FAIL
test VIDIOC_G_FBUF: OK (Not Supported)
test VIDIOC_G_FMT: OK
test VIDIOC_TRY_FMT: OK
warn: v4l2-test-formats.cpp(997): S_FMT cannot handle an invalid pixelformat.
warn: v4l2-test-formats.cpp(998): This may or may not be a problem. For more information see:
warn: v4l2-test-formats.cpp(999): http://www.mail-archive.com/linux-media@vger.kernel.org/msg56550.html
fail: v4l2-test-formats.cpp(1013): S_FMT cannot handle an invalid format
test VIDIOC_S_FMT: FAIL
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
fail: v4l2-test-formats.cpp(1550): doioctl(node, VIDIOC_S_FMT, &fmt)
fail: v4l2-test-formats.cpp(1647): doioctl(node, VIDIOC_S_FMT, &fmt)
test Scaling: FAIL
Codec ioctls:
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls:
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: OK
test VIDIOC_EXPBUF: OK
Test input 0:
Total: 43, Succeeded: 40, Failed: 3, Warnings: 3
