Mipi CSI-2 lanes swap on Jetpack 5
Is it possible to make csi-2 work with camera different lanes order?
I fount topic MIPI Lane swapping
I found some lane-swap related functions for C-PHY mode.
I tried to set brick_config.lane_swizzle to 0x15 (value that should swap lanes to right order) in the csi5_stream_set_config.
But xavier still doesn’t receive frames and getting errors:
     kworker/0:0-2846    [000] ....   336.091916: rtcpu_nvcsi_intr: tstamp:11067276474 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091917: rtcpu_nvcsi_intr: tstamp:11067282955 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091917: rtcpu_nvcsi_intr: tstamp:11067282955 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091918: rtcpu_vinotify_error: tstamp:11067297863 cch:0 vi:0 tag:CSIMUX_FRAME channel:0x00 frame:0 vi_tstamp:354153235616 data:0x00000000000000a2
     kworker/0:0-2846    [000] ....   336.091919: rtcpu_nvcsi_intr: tstamp:11067328325 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091919: rtcpu_nvcsi_intr: tstamp:11067328325 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091920: rtcpu_nvcsi_intr: tstamp:11067330959 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091920: rtcpu_nvcsi_intr: tstamp:11067330959 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091920: rtcpu_nvcsi_intr: tstamp:11067332150 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091921: rtcpu_nvcsi_intr: tstamp:11067332150 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091921: rtcpu_vinotify_error: tstamp:11067333511 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x04 frame:0 vi_tstamp:354154504608 data:0x0000000000000289
     kworker/0:0-2846    [000] ....   336.091921: rtcpu_nvcsi_intr: tstamp:11067335731 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091922: rtcpu_nvcsi_intr: tstamp:11067335731 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
     kworker/0:0-2846    [000] ....   336.091922: rtcpu_nvcsi_intr: tstamp:11067337583 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:2 vc:0 status:0x00000004
Also I tried other values for lane_swizzle, but camera still doesn’t work.
Is it possible to make work camera with with different lanes order?
I’m using 'serial_c" with 4-lane mode. How to set NVCSI_PHY_1_NVCSI_CIL_LANE_SWIZZLE_CTRL_0 properly?
There’s CHANSEL_NOMATCH could be incorrect embedded_data_height in device tree and below tells the CRC error.
Does the trace log different while modify the lane_swizzle?
I’m sure that camera doesn’t send any embedded data. It sending only YUYV(dt = 0x1e) frames with 1920x1080 size.
CHANSEL_NOMATCH and CSIMUX_FRAME data value change for some lane_swizzle, but with any lane_swizzle value I have errors in trace and sometimes xavier reboots after CBB-error
Sorry for the late response.
The error tell the payload CRC error.
When lanes are in wrong order - CRC will have error, it is expected behavior, I suppose.
Is it possible to get received mipi csi packet headers? It would help to understand does brick_config.lane_swizzle working.
The lane_swizzle is working for v4l2 usage but argus pipeline.
