hello:
MIPI-CSI camera can not play whith ffplay on NX. My NX device information is as follows:
Linux jetson-desktop 4.9.201-tegra #1 SMP PREEMPT Fri Feb 19 08:42:04 PST 2021 aarch64 aarch64 aarch64 GNU/Linux
DISTRIB_DESCRIPTION=“Ubuntu 18.04.5 LTS”
R32 (release), REVISION: 5.1, GCID: 26202423, BOARD: t186ref, EABI: aarch64, DATE: Fri Feb 19 16:50:29 UTC 2021
and the camera is mounted in /dev/video0. Use this command to play back the video:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)20/1’ ! nvvidconv ! ‘video/x-raw(memory:NVMM),format=(string)NV12’ ! nvoverlaysink -e
but can not play whith ffplay,the error message of the ffplay prompt is as follows:
jetson@jetson-desktop:~/work/ffmpeg_arm64/build/lib$./ffplay -i /dev/video0
ffplay version 4.2.2 Copyright (c) 2003-2019 the FFmpeg developers
built with gcc 7 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)
configuration: --prefix=/work/ffmpeg_arm64/ffmpeg/build --arch=arm64 --target-os=linux --pkg-config-flags=–static --extra-cflags=-I/work/ffmpeg_arm64/ffmpeg/build/include --extra-ldflags=-L/work/ffmpeg_arm64/ffmpeg/build/lib --extra-libs=‘-lpthread -lm’ --enable-shared --enable-gpl --enable-libfdk-aac --enable-libmp3lame --enable-libopus --enable-libx264 --enable-libx265 --enable-nonfree --enable-libvpx --enable-sdl2 --enable-libv4l2
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
libpostproc 55. 5.100 / 55. 5.100
[video4linux2,v4l2 @ 0x7f68000b60] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0x7f68000b60] Time per frame unknown
[video4linux2,v4l2 @ 0x7f68000b60] Dequeued v4l2 buffer contains corrupted data (16084992 bytes).
Last message repeated 30 times
Last message repeated 5 times
Last message repeated 4 times
