You need to configurate it by jetson-io.
There is a useful youtube on this config topic.
When I run the python config program as sudo, there is a quick “flash”, looks like a panel is being drawn, then the program aborts with no error message. No way to debug it if I cannot see an error message.
How do I debug jetson-io.py?
Reflash the system by sdkmanager to try again.
I now using sdkmanager. Some progress, but here is the problem with automatic and manual flashing.
Setup;
windows/vbox/linux
jetson/nano/orin
able to ssh fromlinux to jetsonb
auto flash does not work:
jetson reboots
jetson does not come up, based on monitor
ssh fails, and retry fails
manual fails
use pins 9/10 for recovery mode
not able to get to a state where flash is enabled after reboot
Would like to get auto mode working, Any reason why Jetson would not boot properly after shutdown command from host?
thx.
If you use Orin Nano developer kit, please follow this and see if you can successfully re-flash the system image:
Quick Start — NVIDIA Jetson Linux Developer Guide
system
Closed
May 6, 2025, 2:56am
10
