Hi all,
We are currently working with two camera modules from two different vendors on the XavierNX devkit.
- The first camera is an ADI ToF sensor. In particular, ADI had to use two CSI entries and two i2c entries in the device tree (even if only one camera is being used). Note that physically, the camera is linked to the XavierNX through a single 2 lane CSI-2 link.
- The second camera is a RBPC-HQ (with the IMX477). We’re using the dtsi gently provided by RidgeRun.
We fused both device trees to support the two cameras simultaneously. In particular, in the cam_i2cmux
, we had something like:
compatible = "i2c-mux-gpio";
#address-cells = <1>;
#size-cells = <0>;
i2c-parent = <&cam_i2c>;
mux-gpios = <&tegra_aon_gpio CAM_I2C_MUX GPIO_ACTIVE_HIGH>;
i2c@0 {
reg = <0>;
#size-cells = <0>;
adi_tof_cam0@64 {
compatible = "adi,addi9036";
reg = <0x64>;
sensor_model = "MN34906BL";
physical_w = "2.688";
use_decibel_gain = "true";
devnode = "video0";
delayed_gain = "true";
use_sensor_mode_id = "true";
physical_h = "3.584";
mode0 {
mclk_khz = "45000";
num_lanes = "2";
tegra_sinterface = "serial_e";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "640";
active_h = "480";
mode_type = "bayer";
pixel_phase = "bggr";
csi_pixel_bit_depth = "12";
pix_clk_hz = "73728000";
line_length = "640";
inherent_gain = "1";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
min_gain_val = "0"; /* 0dB */
max_gain_val = "0"; /* 48dB */
step_gain_val = "1"; /* 0.3 */
default_gain = "0";
min_framerate = "5000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate = "30000000";
embedded_metadata_height = "0";
ports {
#address-cells = <0x1>;
#size-cells = <0x0>;
port@0 {
reg = <0x0>;
adi9036_out0: endpoint {
port-index = <0>;
remote-endpoint = <&addi9036_csi_in0>;
bus-width = <2>;
vc-id = <0>;
eeprom@56 {
reg = <0x56>;
compatible = "atmel,24c1024";
pagesize = <32>;
i2c@1 {
reg = <1>;
#size-cells = <0>;
adi_tof_cam1@64 {
reg = <0x64>;
devnode = "video0";
mode0 {
mclk_khz = "45000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "640";
active_h = "480";
default_gain = "0";
ports {
port@0 {
reg = <0x0>;
adi9036_out1: endpoint {
port-index = <0>;
remote-endpoint = <&addi9036_csi_in1>;
bus-width = <2>;
vc-id = <1>;
eeprom@56 {
reg = <0x56>;
pagesize = <32>;
i2c@2 {
reg = <2>;
#size-cells = <0>;
imx477_cam1: rbpcv3_imx477_c@1a {
compatible = "ridgerun,imx477";
reg = <0x1a>;
reset-gpios = <&tegra_main_gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
devnode = "video2";
physical_w = "7.564";
physical_h = "5.476";
sensor_model = "imx477";
mode0 { /* IMX477_MODE_4032X3040 */
mclk_khz = "24000";
num_lanes = "2";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
active_w = "4032";
active_h = "3040";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
readout_orientation = "90";
line_length = "9024";
mclk_multiplier = "80";
pix_clk_hz = "840000000";
gain_factor = "16";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = "16"; /* 1.00x */
max_gain_val = "356"; /* 22x */
default_gain = "16"; /* 1.00x */
min_framerate = "2000000"; /* 2.0 fps */
max_framerate = "30000000"; /* 30.0 fps */
default_framerate = "30000000"; /* 30.0 fps */
min_exp_time = "11"; /* us */
max_exp_time = "500000"; /* us */
step_exp_time = "1";
default_exp_time = "2495"; /* us */
embedded_metadata_height = "2";
mode1 { /* IMX477_MODE_1920X1080 */
mclk_khz = "24000";
num_lanes = "2";
phy_mode = "DPHY";
active_w = "1920";
active_h = "1080";
gain_factor = "16";
max_framerate = "60000000"; /* 60.0 fps */
default_framerate = "60000000"; /* 60.0 fps */
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
rbpcv3_imx477_out1: endpoint {
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&rbpcv3_imx477_csi_in1>;
Using this device tree, the ADI camera works fine but the IMX477 sensor is not detected during i2c probe. Here is a list of detected i2c devices
sudo i2cdetect -l
i2c-3 i2c 3190000.i2c I2C adapter
i2c-1 i2c c240000.i2c I2C adapter
i2c-11 i2c i2c-2-mux (chan_id 2) I2C adapter
i2c-8 i2c 31e0000.i2c I2C adapter
i2c-6 i2c 31c0000.i2c I2C adapter
i2c-4 i2c Tegra BPMP I2C adapter I2C adapter
i2c-2 i2c 3180000.i2c I2C adapter
i2c-0 i2c 3160000.i2c I2C adapter
i2c-9 i2c i2c-2-mux (chan_id 0) I2C adapter
i2c-10 i2c i2c-2-mux (chan_id 1) I2C adapter
i2c-7 i2c c250000.i2c I2C adapter
i2c-5 i2c 31b0000.i2c I2C adapter
The ADI i2c parts are working normally
sudo i2cdetect -r -y 9 # ADDI IR
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- UU UU -- -- -- -- -- -- -- --
60: -- -- -- -- UU -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- 73 -- -- -- --
sudo i2cdetect -r -y 10 # ADDI TOF
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
However, the IMX477 i2c response (on i2c bus 11) seems incorrect:
sudo i2cdetect -r -y 11
50: -- -- -- -- -- -- 56 57 -- -- -- -- -- -- -- --
60: -- -- -- -- 64 -- -- -- -- -- -- -- -- -- -- --
In fact, this is a copy of i2c bus 9 (named i2c@0 on the device tree cam-i2c-mux), and I can’t understand why.
Is their any overwrite ? is i2c bus 11 reserved for something ?
Thanks,
K
