Hi. We had made mipi capture board with Jetson AGX Xavier.
Using custom kernel based on L4T 32.5.2
Using V4l2 framework to capture camera raw binary data.disable Jetson ISP
Using MIPI D-PHY generator(up to 2.5Gbps/lane,1/2/4lane,various data type, and so on)
Also already checked capturing 2lane MIPI CSI2 RAW10 data at CSI port0 and port1.
After that,we try to capture 4lane.
4lane CSI2 RAW10 data.same image width and height, same datarate.
Input CSI CLKP/N to CSI port 0 and Input CSI DataP/N 0_3 to CSI port0 and port1.
Changed DeviceTree setting about lane/bus count from 2 to 4 with DeviceTree overlay.
Following list we change
node | property name |
tegra-camera-platform | num_csi_lanes |
vi@15c10000/ports/port/endpoint | bus-width |
nvcsi@15a00000/ports/port/endpoint | bus-width |
i2c@3180000/devname/ports/port/endpoint | bus-width |
i2c@3180000/devname/mode | num_lanes |
*devname means devicename such as imx219,ov5693
Then, using func_hd command,check these propery values exactly “4”
i.e.:func_hd /proc/device-tree/tegra-camera-platform/num_csi_lanes.
But capture failed with this error.
error code output at random.
i.e.:
[ 134.587187] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 134.589399] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 134.682352] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 96, err_data 4194400
[ 134.729911] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 134.777441] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 134.920462] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 134.921764] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 135.015681] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 32, err_data 160
[ 135.016995] tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 0, err_data 131072
Is there any other parameter to change?
Do you have idea to solve this?
