MIPI Display Problem with TX2 NX
Hi we met the same situation in topic No DSI MIPI data on custom carrier board - #41 by therealmatiss.
When we pulled up the DP HPD pin, it is worked ok.
How should we modified something to mask the DP HPD detected?
You can disable DP driver by modifying the device tree.
Hi Wayne,
Thanks for your reply.
We have disabled the DP and the problem also occur.
I attach the dts in the attachment.
dsi dts.txt (247.8 KB)
Do you have any dmesg to share here? I actually really don’t know what issue you are talking about…
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5499-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jun 11 16:10:01 PDT 2024
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[    0.000000] OF: fdt: - 80000000 ,  70000000
[    0.000000] OF: fdt: - f0200000 ,  85600000
[    0.000000] OF: fdt: - 175e00000 ,  200000
[    0.000000] OF: fdt: - 176600000 ,  200000
[    0.000000] OF: fdt: - 177000000 ,  200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Found tegra_fbmem: 00800000@96085000
[    0.000000] Found lut_mem: 00002008@96081000
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] On node 0 totalpages: 1004541
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 521725 pages, LIFO batch:31
[    0.000000]   Normal zone: 7624 pages used for memmap
[    0.000000]   Normal zone: 482816 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[    0.000000] pcpu-alloc: s57816 r8192 d32296 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: enabling workaround for Spectre-BHB
[    0.000000] CPU features: enabling workaround for ARM erratum 1742098
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 988725
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2  video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0x96085000 lut_mem=0x2008@0x96081000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29624(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3147688K/4018164K available (15486K kernel code, 2982K rwdata, 6716K rodata, 8640K init, 614K bss, 116812K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0x        (ptrval) - 0x        (ptrval)   ( 15488 KB)
[    0.000000]     .rodata : 0x        (ptrval) - 0x        (ptrval)   (  6784 KB)
[    0.000000]       .init : 0x        (ptrval) - 0x        (ptrval)   (  8640 KB)
[    0.000000]       .data : 0x        (ptrval) - 0x        (ptrval)   (  2983 KB)
[    0.000000]        .bss : 0x        (ptrval) - 0x        (ptrval)   (   615 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03dc8000   (    61 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0f7200000   (  3954 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000974] Console: colour dummy device 80x25
[    0.000979] console [tty0] enabled
[    0.000982] bootconsole [uart8250] disabled
[    0.000990] kmemleak: Kernel memory leak detector disabled
[    0.001000] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.001007] pid_max: default: 32768 minimum: 301
[    0.001337] Security Framework initialized
[    0.001505] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001509] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002087] ftrace: allocating 47298 entries in 185 pages
[    0.131883] sched-energy: Sched-energy-costs installed from DT
[    0.140554] ASID allocator initialised with 65536 entries
[    0.164968] tegra-id: chipid=21817.
[    0.164974] tegra-id: opt_subrevision=1.
[    0.164994] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.165002] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/lanai/kernel-dts/tegra186-p3636-0001-p3509-0000-a01.dts
[    0.165007] DTB Build time: <unknown>
[    0.214636] CPU1: Booted secondary processor [4e0f0030]
[    0.246026] CPU2: Booted secondary processor [4e0f0030]
[    0.277026] CPU3: Booted secondary processor [411fd073]
[    0.308983] CPU4: Booted secondary processor [411fd073]
[    0.340974] CPU5: Booted secondary processor [411fd073]
[    0.341032] Brought up 6 CPUs
[    0.341036] SMP: Total of 6 processors activated.
[    0.341041] CPU features: detected feature: 32-bit EL0 Support
[    0.342633] CPU: All CPU(s) started at EL2
[    0.342781] alternatives: patching kernel code
[    0.345188] devtmpfs: initialized
[    0.367709] Initilizing CustomIPI irq domain
[    0.367852] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.367860] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.376772] pinctrl core: initialized pinctrl subsystem
[    0.377012] OS set in device tree is not L4T.
[    0.377205] regulator-dummy: no parameters
[    0.377337] Initializing plugin-manager
[    0.377393] Plugin module not found
[    0.377428] Plugin-manager status disabled
[    0.378665] NET: Registered protocol family 16
[    0.379637] pstore: using zlib compression
[    0.379652] console [pstore-1] enabled
[    0.379655] pstore: Registered ramoops as persistent store backend
[    0.379658] ramoops: attached 0x200000@0x175880000, ecc: 0/0
[    0.393042] cpuidle: using governor menu
[    0.393971] bpmp: waiting for handshake
[    0.393975] bpmp: handshake completed
[    0.393992] bpmp: synchronizing channels
[    0.394000] bpmp: channels synchronized
[    0.394003] bpmp: mail init ok
[    0.395459] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.395463] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.395468] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.395471] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.395473] arm-smmu 12000000.iommu: 	nested translation
[    0.395480] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.395485] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.395489] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.395493] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.395496] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.397328] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.397341] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.400574] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.401569] Registering BPMP clocks...
[    0.401637] tegra_bpmp_clk_init: clock init ok (638 clks)
[    0.402097] Serial: AMBA PL011 UART driver
[    0.402991] tegra_powergate_init: DONE
[    0.402998] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/lanai/kernel-dts/tegra186-p3636-0001-p3509-0000-a01.dts
[    0.403002] DTB Build time: <unknown>
[    0.404260] Tegra reboot handler registered.
[    0.405400] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.405464] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.405477] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.405479] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[    0.405482] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.405630] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.405640] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.405899] iommu: Adding device 3460000.sdhci to group 0
[    0.407024] iommu: Adding device 3160000.i2c to group 1
[    0.407411] iommu: Adding device c240000.i2c to group 2
[    0.407700] iommu: Adding device 3180000.i2c to group 3
[    0.407977] iommu: Adding device 3190000.i2c to group 4
[    0.408342] iommu: Adding device 31b0000.i2c to group 5
[    0.408636] iommu: Adding device 31c0000.i2c to group 6
[    0.408915] iommu: Adding device c250000.i2c to group 7
[    0.409226] iommu: Adding device 31e0000.i2c to group 8
[    0.410651] iommu: Adding device 3210000.spi to group 9
[    0.410932] iommu: Adding device c260000.spi to group 10
[    0.411561] iommu: Adding device 3100000.serial to group 11
[    0.411845] iommu: Adding device 3110000.serial to group 12
[    0.412127] iommu: Adding device 3130000.serial to group 13
[    0.413260] iommu: Adding device 2490000.ether_qos to group 14
[    0.413271] arm-smmu: forcing sodev map for 2490000.ether_qos
[    0.414068] iommu: Adding device b000000.rtcpu to group 15
[    0.415756] iommu: Adding device 13e10000.host1x to group 16
[    0.416050] iommu: Adding device 13e10000.host1x:ctx0 to group 17
[    0.416328] iommu: Adding device 13e10000.host1x:ctx1 to group 18
[    0.416608] iommu: Adding device 13e10000.host1x:ctx2 to group 19
[    0.416889] iommu: Adding device 13e10000.host1x:ctx3 to group 20
[    0.417199] iommu: Adding device 13e10000.host1x:ctx4 to group 21
[    0.417478] iommu: Adding device 13e10000.host1x:ctx5 to group 22
[    0.417755] iommu: Adding device 13e10000.host1x:ctx6 to group 23
[    0.418045] iommu: Adding device 13e10000.host1x:ctx7 to group 24
[    0.418457] iommu: Adding device 150c0000.nvcsi to group 25
[    0.419006] iommu: Adding device 15700000.vi to group 26
[    0.419313] iommu: Adding device 15600000.isp to group 27
[    0.419518] iommu: Adding device 15200000.dc_common to group 28
[    0.419560] platform 15200000.dc_common: OF IOVA linear map 0x96085000 size (0x800000)
[    0.419603] platform 15200000.dc_common: OF IOVA linear map 0x96081000 size (0x2008)
[    0.420053] iommu: Adding device 15200000.nvdisplay to group 29
[    0.420493] iommu: Adding device 15340000.vic to group 30
[    0.420692] iommu: Adding device 154c0000.nvenc to group 31
[    0.420887] iommu: Adding device 15480000.nvdec to group 32
[    0.421210] iommu: Adding device 15380000.nvjpg to group 33
[    0.421405] iommu: Adding device 15500000.tsec to group 34
[    0.421604] iommu: Adding device 15100000.tsecb to group 35
[    0.422099] iommu: Adding device 15810000.se to group 36
[    0.422289] iommu: Adding device 15820000.se to group 37
[    0.422474] iommu: Adding device 15830000.se to group 38
[    0.422660] iommu: Adding device 15840000.se to group 39
[    0.423415] iommu: Adding device smmu_test to group 40
[    0.423980] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c10000
[    0.423991] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c20000
[    0.424001] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c30000
[    0.424011] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c40000
[    0.424020] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c50000
[    0.424027] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.424036] mc-err: mcerr ops are set to t18x
[    0.424176] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[    0.424943] iommu: Adding device 3530000.xhci to group 41
[    0.424957] arm-smmu: forcing sodev map for 3530000.xhci
[    0.425394] iommu: Adding device 3550000.xudc to group 42
[    0.425406] arm-smmu: forcing sodev map for 3550000.xudc
[    0.425914] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[    0.425922] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.425927] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.426507] iommu: Adding device 17000000.gp10b to group 43
[    0.427437] tegra-reset 5000000.clock: registered 193 resets.
[    0.429321] iommu: Adding device d000000.bpmp to group 44
[    0.429527] bpmp: ping status is 0
[    0.429604] bpmp d000000.bpmp: firmware tag is 91572a54614f84d0fd0c270beec2c56f
[    0.431199] bpmp d000000.bpmp: probe ok
[    0.433744] iommu: Adding device 2600000.dma to group 45
[    0.434534] GPIO line 424 (camera-control-output-low) hogged as output/low
[    0.434564] GPIO line 427 (camera-control-output-low) hogged as output/low
[    0.434608] GPIO line 408 (w-disable1) hogged as output/high
[    0.434644] GPIO line 410 (w-disable2) hogged as output/high
[    0.434800] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[    0.438516] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[    0.440034] iommu: Adding device 10003000.pcie-controller to group 46
[    0.440049] arm-smmu: forcing sodev map for 10003000.pcie-controller
[    0.440345] iommu: Adding device sound to group 47
[    0.440649] iommu: Adding device 3510000.hda to group 48
[    0.447102] iommu: Adding device c1a0000.aon to group 49
[    0.447617] vdd-1v8-ap: 1800 mV
[    0.447820] vdd-ac-bat: 5000 mV
[    0.447995] vdd-3v3-disp-cvb: 3300 mV
[    0.448260] vdd-3v3-cvb: 3300 mV
[    0.448434] vdd-1v8-cvb: 1800 mV
[    0.448612] vdd-fan: 5000 mV
[    0.448803] vdd-hdmi-5v0: 5000 mV
[    0.449013] vdd_sys_en: 1200 mV
[    0.473442] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.476030] eventlib_kernel: keventlib is initialized, test id: 0
[    0.476228] SCSI subsystem initialized
[    0.476332] libata version 3.00 loaded.
[    0.476514] usbcore: registered new interface driver usbfs
[    0.476586] usbcore: registered new interface driver hub
[    0.476614] usbcore: registered new device driver usb
[    0.486171] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.488679] vddio-ddr: at 1125 mV
[    0.492564] avdd_dsi_csi: 1200 mV
[    0.496545] vdd-1v8: 1800 mV
[    0.500566] vdd-3v3-sys: 3300 mV
[    0.501431] spmic-ldo0: at 1800 mV
[    0.502046] spmic-ldo1: at 800 mV
[    0.504999] vddio-3v3: 3300 mV
[    0.505654] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.508997] vdd-rtc: at 800 mV
[    0.509666] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[    0.512995] spmic-ldo6: at 800 mV
[    0.516994] vdd-pex-1v00: 1000 mV
[    0.517580] dvdd-pex: 1000 mV
[    0.519502] GPIO line 253 (spmic_gpio_input) hogged as input
[    0.519628] GPIO line 254 (spmic_gpio_input) hogged as input
[    0.519781] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[    0.519951] max77620 4-003c: max77620 probe successful
[    0.520308] media: Linux media interface: v0.10
[    0.520341] Linux video capture interface: v2.00
[    0.522558] pps_core: LinuxPPS API ver. 1 registered
[    0.522561] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.522572] PTP clock support registered
[    0.522751] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.522931] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.522947] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.524021] trusty trusty: trusty version: Built: 16:08:32 Jun 11 2024
[    0.524035] trusty trusty: selected api version: 3 (requested 3)
[    0.524852] Advanced Linux Sound Architecture Driver Initialized.
[    0.525162] Bluetooth: Core ver 2.22
[    0.525188] NET: Registered protocol family 31
[    0.525191] Bluetooth: HCI device and connection manager initialized
[    0.525197] Bluetooth: HCI socket layer initialized
[    0.525202] Bluetooth: L2CAP socket layer initialized
[    0.525214] Bluetooth: SCO socket layer initialized
[    0.525775] vdd-sys-bl: 3300 mV
[    0.527330] camchar: rtcpu character device driver loaded
[    0.527752] gpio tegra-gpio wake61 for gpio=92(L:4)
[    0.527824] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[    0.528683] clocksource: Switched to clocksource arch_sys_counter
[    0.551430] VFS: Disk quotas dquot_6.6.0
[    0.551510] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.551769] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.552193] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    0.552308] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    0.552311] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.552321] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[    0.552325] nvmap_page_pool_init: Total RAM pages: 975338
[    0.552329] nvmap_page_pool_init: nvmap page pool size: 121917 pages (476 MB)
[    0.552389] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.552893] misc nvmap: created heap vpr base 0x        (ptrval) size (688128KiB)
[    0.554851] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    0.560469] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.560650] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.561001] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.561075] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.561207] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.561421] la/ptsa driver initialized.
[    0.561430] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.561432] pre_t19x_iso_plat_init(): max_iso_bw=23040000KB
[    0.561745] NET: Registered protocol family 2
[    0.561823] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.584938] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.585101] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.585415] TCP: Hash tables configured (established 32768 bind 32768)
[    0.585464] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.585527] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.585805] NET: Registered protocol family 1
[    0.586219] RPC: Registered named UNIX socket transport module.
[    0.586222] RPC: Registered udp transport module.
[    0.586225] RPC: Registered tcp transport module.
[    0.586227] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.586233] PCI: CLS 0 bytes, default 64
[    0.586349] Trying to unpack rootfs image as initramfs...
[    0.798982] Freeing initrd memory: 7068K
[    0.813483] host1x 13e10000.host1x: initialized
[    0.814742] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.816858] audit: initializing netlink subsys (disabled)
[    0.816883] audit: type=2000 audit(0.704:1): initialized
[    0.817282] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.823791] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.824799] ntfs: driver 2.1.32 [Flags: R/W].
[    0.825330] 9p: Installing v9fs 9p2000 file system support
[    0.827419] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.827482] io scheduler noop registered
[    0.827699] io scheduler cfq registered (default)
[    0.830637] gic 2a41000.agic-controller: GIC IRQ controller registered
[    0.893041] iommu: Adding device aconnect@2a41000:adsp_audio to group 50
[    0.913367] iommu: Adding device 2993000.adsp to group 51
[    0.913935] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    0.918725] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.919601] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    0.920432] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.921220] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.923244] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[    0.923948] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[    0.924235] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[    0.924510] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.924614] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    0.925774] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[    0.926779] tsec 15500000.tsec: initialized
[    0.927655] tsec 15100000.tsecb: initialized
[    0.929878] nvdec 15480000.nvdec: initialized
[    0.933695] falcon 15340000.vic: initialized
[    0.934769] falcon 154c0000.nvenc: initialized
[    0.935764] falcon 15380000.nvjpg: initialized
[    0.937613] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    0.938955] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    0.940327] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    0.941724] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    0.943118] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    0.944646] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    0.946083] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    0.947444] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    0.950069] tegradccommon 15200000.dc_common: host1x channel mapped
[    0.950076] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    0.950109] tegradccommon 15200000.dc_common: dma mapping done
[    0.950800] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/dsi
[    0.950930] tegradc 15200000.nvdisplay: No hpd-gpio in DT
[    0.950977] tegradc 15200000.nvdisplay: DT parsed successfully
[    0.950998] tegradc 15200000.nvdisplay: Display dc.        (ptrval) registered with id=0
[    0.956549] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[    0.956552] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[    0.956555] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[    0.956744] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    0.956750] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    0.959918] tegradc 15200000.nvdisplay: Force clock continuous mode
[    0.961003] tegradc 15200000.nvdisplay: probed
[    0.962865] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    0.963498] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    0.963519] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    0.963901] kfuse 3830000.kfuse: initialized
[    0.965166] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.968240] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.970305] console [ttyS0] disabled
[    0.970339] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 33, base_baud = 25500000) is a Tegra
[    0.970380] console [ttyS0] enabled
[    0.971524] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 34, base_baud = 0) is a TEGRA_UART
[    0.971699] serial-tegra 3130000.serial: RX in PIO mode
[    0.972273] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 35, base_baud = 0) is a TEGRA_UART
[    0.973383] [drm] Initialized
[    0.976880] Console: switching to colour frame buffer device 160x50
[    0.980205] brd: module loaded
[    0.981076] tegradc 15200000.nvdisplay: fb registered
[    0.981522] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    0.981571] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    0.983483] loop: module loaded
[    0.983526] tegra_profiler: version: 1.145, samples/io: 49/28
[    0.983611] tegra_profiler: auth: init
[    0.984150] THERMAL EST: found 3 subdevs
[    0.984154] THERMAL EST num_resources: 0
[    0.984160] [THERMAL EST subdev 0]
[    0.984164] [THERMAL EST subdev 1]
[    0.984168] [THERMAL EST subdev 2]
[    0.984176] THERMAL EST: Found 2 profiles, default profile is quiet
[    0.984420] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    0.984423] THERMAL EST: thz register success.
[    0.984514] THERMAL EST: end of probe, return err: 0
[    0.985178] sd: No Scsi addr parsed to reserve index
[    0.985201] hisi_sas: driver version v1.6
[    0.990371] tun: Universal TUN/TAP device driver, 1.6
[    0.990375] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.991022] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    0.991024] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.991056] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    0.991058] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.991088] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.991090] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.991124] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    0.991126] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    1.140683] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    1.147285] tegradc 15200000.nvdisplay: timeout waiting for postcomp init state to promote
[    1.204675] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    1.211260] tegradc 15200000.nvdisplay: timeout waiting for win assignments to promote
[    1.219237] tegradc 15200000.nvdisplay: tegra_nvdisp_head_enable, failed head enable
[    1.232758] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[    1.234652] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[    1.235059] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3b 70 f5
[    1.235081] Using phyrst_lpmode = 1 from DT
[    1.237139] PPP generic driver version 2.4.2
[    1.237336] PPP BSD Compression module registered
[    1.237339] PPP Deflate Compression module registered
[    1.237353] PPP MPPE Compression module registered
[    1.237356] NET: Registered protocol family 24
[    1.237404] usbcore: registered new interface driver r8152
[    1.237435] usbcore: registered new interface driver asix
[    1.237468] usbcore: registered new interface driver ax88179_178a
[    1.237493] usbcore: registered new interface driver cdc_ether
[    1.237519] usbcore: registered new interface driver net1080
[    1.237546] usbcore: registered new interface driver cdc_subset
[    1.237572] usbcore: registered new interface driver zaurus
[    1.237609] usbcore: registered new interface driver cdc_ncm
[    1.237727] VFIO - User Level meta-driver version: 0.3
[    1.238540] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.238550] ehci-pci: EHCI PCI platform driver
[    1.238579] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.238585] ohci-pci: OHCI PCI platform driver
[    1.238611] ohci-platform: OHCI generic platform driver
[    1.241996] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[    1.243406] tegra-xusb 3530000.xhci: extcon 0:         (ptrval) id
[    1.243764] usbcore: registered new interface driver uas
[    1.243810] usbcore: registered new interface driver usb-storage
[    1.243880] usbcore: registered new interface driver usbserial
[    1.246026] tegra-xusb 3530000.xhci: Firmware timestamp: 2020-07-06 13:39:28 UTC, Version: 55.18 release
[    1.246120] tegra-xusb 3530000.xhci: xHCI Host Controller
[    1.246139] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[    1.246868] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[    1.246879] tegra-xudc-new 3550000.xudc: device count: 1
[    1.246896] tegra-xusb 3530000.xhci: irq 65, io mem 0x03530000
[    1.247031] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.247036] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.247040] usb usb1: Product: xHCI Host Controller
[    1.247043] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.247046] usb usb1: SerialNumber: 3530000.xhci
[    1.247373] hub 1-0:1.0: USB hub found
[    1.247404] hub 1-0:1.0: 4 ports detected
[    1.247780] tegra-xusb 3530000.xhci: xHCI Host Controller
[    1.247788] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[    1.247922] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.247926] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.247930] usb usb2: Product: xHCI Host Controller
[    1.247933] tegra-xudc-new 3550000.xudc: USB charger detection disabled
[    1.247934] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.247937] usb usb2: SerialNumber: 3530000.xhci
[    1.247943] tegra-xudc-new 3550000.xudc: vbus state: 1
[    1.247951] tegra-xudc-new 3550000.xudc: device mode on: 0
[    1.248080] tegra-xudc-new 3550000.xudc: active: 0 => 1
[    1.248229] hub 2-0:1.0: USB hub found
[    1.248257] hub 2-0:1.0: 3 ports detected
[    1.248563] mousedev: PS/2 mouse device common for all mice
[    1.248620] usbcore: registered new interface driver xpad
[    1.249494] Wake76 for irq=199
[    1.249496] Wake77 for irq=199
[    1.249498] Wake78 for irq=199
[    1.249500] Wake79 for irq=199
[    1.249502] Wake80 for irq=199
[    1.249504] Wake81 for irq=199
[    1.249505] Wake82 for irq=199
[    1.249558] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[    1.249563] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[    1.256692] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.369033] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.370046] Wake73 for irq=42
[    1.371292] rtc rtc1: alarm rtc device
[    1.371303] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    1.371317] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    1.371460] i2c /dev entries driver
[    1.372757] i2c i2c-2: Added multiplexed i2c bus 9
[    1.372976] i2c i2c-2: Added multiplexed i2c bus 10
[    1.372980] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    1.373377] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    1.396712] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    1.396751] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.404371] imx219 9-0010: board setup failed
[    1.408813] imx219: probe of 9-0010 failed with error -121
[    1.409105] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    1.432306] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    1.432354] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.440042] imx219 10-0010: board setup failed
[    1.444577] imx219: probe of 10-0010 failed with error -121
[    1.445456] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.449877] parse_throttle_dt_data: Num cap clks = 4
[    1.449881] parse_throttle_dt_data: clk=mcpu type=1
[    1.449884] parse_throttle_dt_data: clk=bcpu type=2
[    1.449891] parse_throttle_dt_data: clk=gpu type=4
[    1.449894] parse_throttle_dt_data: clk=emc type=3
[    1.450537] tegra_throttle_probe: probe successful. #cdevs=4
[    1.451087] FAN dev name: pwm-fan
[    1.451136] FAN:gpio request success.
[    1.451145] FAN: can't find tach_gpio
[    1.451153] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    1.451172] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    1.451345] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.451350] pwm_fan_driver pwm-fan: tach period: 1000
[    1.451799] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.451803] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    1.451807] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    1.451811] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    1.451814] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.451818] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.451822] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.451825] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.451829] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.451833] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.452359] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    1.453359] device-mapper: uevent: version 1.0.3
[    1.453715] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.453964] CPU EMC frequency mapping table: from device tree
[    1.455811] cpufreq: platform driver Initialization: pass
[    1.456399] cpuidle: Initializing cpuidle driver init for Denver cluster
[    1.456517] cpuidle: Initializing cpuidle driver init for A57 cluster
[    1.457357] sdhci: Secure Digital Host Controller Interface driver
[    1.457359] sdhci: Copyright(c) Pierre Ossman
[    1.457360] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.458334] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    1.459876] CMDQ: cmdq_platfm_init successful
[    1.460786] CQE: CMD_TIMING bit set for R1B DCMD
[    1.460895] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    1.467293] tegra-se-nvhost 15810000.se: initialized
[    1.468346] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    1.468879] tegra-se-nvhost 15820000.se: initialized
[    1.469814] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    1.470240] tegra-se-nvhost 15830000.se: initialized
[    1.471018] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    1.471462] tegra-se-nvhost 15840000.se: initialized
[    1.472395] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    1.473172] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    1.473327] hidraw: raw HID events driver (C) Jiri Kosina
[    1.474264] usbcore: registered new interface driver usbhid
[    1.474267] usbhid: USB HID core driver
[    1.476909] ashmem: initialized
[    1.478959] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    1.480777] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[    1.480992] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    1.481115] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[    1.481183] tegra186-cam-rtcpu b000000.rtcpu: no priority specified, using 99 as default
[    1.481826] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[    1.481893] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[    1.481935] tegra-capture-ivc ivc-b000000.rtcpu:ivccontrol@52c0: no priority specified, using 99 as default
[    1.481986] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[    1.482032] tegra-capture-ivc ivc-b000000.rtcpu:ivccapture@72c0: no priority specified, using 99 as default
[    1.482079] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[    1.482177] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9180-0xb200 TX[1x8192]=0xb200-0xd280
[    1.482459] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (48)
[    1.482461] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    1.482957] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=bf12e2c549579b8fe7e0596d313688814d0c34ea
[    1.484508] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    1.484926] tegra186-aondbg aondbg: aondbg driver probe() OK
[    1.485309] register_ari_mca_banks: Registered MCA ROC:IOB
[    1.485609] register_ari_mca_banks: Registered MCA ROC:CCE
[    1.486306] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486309] tegra18-bridge 2390000.axi2apb: enabled timeout = 9894000
[    1.486311] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    1.486354] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486356] tegra18-bridge 23a0000.axi2apb: enabled timeout = 9894000
[    1.486358] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    1.486408] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486410] tegra18-bridge 23b0000.axi2apb: enabled timeout = 9894000
[    1.486412] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    1.486454] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486456] tegra18-bridge 23c0000.axi2apb: enabled timeout = 9894000
[    1.486458] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    1.486500] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486502] tegra18-bridge 23d0000.axi2apb: enabled timeout = 9894000
[    1.486504] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    1.486545] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486550] tegra18-bridge 2100000.axip2p: enabled timeout = 9894000
[    1.486552] tegra18-bridge 2100000.axip2p: bridge probed OK
[    1.486592] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486598] tegra18-bridge 2110000.axip2p: enabled timeout = 9894000
[    1.486599] tegra18-bridge 2110000.axip2p: bridge probed OK
[    1.486639] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486644] tegra18-bridge 2120000.axip2p: enabled timeout = 9894000
[    1.486645] tegra18-bridge 2120000.axip2p: bridge probed OK
[    1.486687] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486692] tegra18-bridge 2130000.axip2p: enabled timeout = 9894000
[    1.486694] tegra18-bridge 2130000.axip2p: bridge probed OK
[    1.486733] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486736] tegra18-bridge 2140000.axip2p: enabled timeout = 9894000
[    1.486738] tegra18-bridge 2140000.axip2p: bridge probed OK
[    1.486778] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486783] tegra18-bridge 2150000.axip2p: enabled timeout = 9894000
[    1.486785] tegra18-bridge 2150000.axip2p: bridge probed OK
[    1.486825] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486830] tegra18-bridge 2160000.axip2p: enabled timeout = 9894000
[    1.486832] tegra18-bridge 2160000.axip2p: bridge probed OK
[    1.486874] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486879] tegra18-bridge 2170000.axip2p: enabled timeout = 9894000
[    1.486881] tegra18-bridge 2170000.axip2p: bridge probed OK
[    1.486920] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486926] tegra18-bridge 2180000.axip2p: enabled timeout = 9894000
[    1.486928] tegra18-bridge 2180000.axip2p: bridge probed OK
[    1.486969] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.486973] tegra18-bridge 2190000.axip2p: enabled timeout = 9894000
[    1.486975] tegra18-bridge 2190000.axip2p: bridge probed OK
[    1.487025] **** A57 ECC: Enabled
[    1.487027] tegra18_a57_serr_init: on CPU 5 a A57 Core
[    1.487089] tegra18x_actmon d230000.actmon: in actmon_register()...
[    1.487446] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    1.487826] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    1.487937] denver_knobs_init:MTS_VERSION:66340021
[    1.490425] nvpmodel: initialized successfully
[    1.491195] trusty-virtio trusty:virtio: initializing
[    1.491297] trusty_ipc virtio0: vring0: va(pa)          (ptrval)(0) qsz 32 notifyid 1
[    1.491304] trusty_ipc virtio0: vring1: va(pa)          (ptrval)(0) qsz 32 notifyid 2
[    1.491365] trusty-virtio trusty:virtio: initializing done
[    1.491443] trusty_ipc virtio0: is online
[    1.492643] usbcore: registered new interface driver snd-usb-audio
[    1.496697] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.500712] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    1.509776] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    1.509892] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    1.512691] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    1.519440] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[    1.519444] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.519446] usb 1-2: Product: USB2.1 Hub
[    1.519449] usb 1-2: Manufacturer: GenesysLogic
[    1.520211] hub 1-2:1.0: USB hub found
[    1.520464] hub 1-2:1.0: 2 ports detected
[    1.542378] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    1.557645] mmc0: periodic cache flush enabled
[    1.557653] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.558058] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.558181] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.558293] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.558388] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    1.561165] OPE platform probe
[    1.561240] OPE platform probe successful
[    1.563460]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[    1.611258] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.611335] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.611402] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.611470] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.611537] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.611603] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.611673] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.611742] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.611806] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.611873] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.611944] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    1.612008] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    1.612078] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    1.612143] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    1.612211] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    1.612280] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    1.612346] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    1.612414] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    1.612482] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    1.612547] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    1.635552] u32 classifier
[    1.635555]     Actions configured
[    1.635617] Initializing XFRM netlink socket
[    1.636171] NET: Registered protocol family 10
[    1.636775] NET: Registered protocol family 17
[    1.636786] NET: Registered protocol family 15
[    1.636845] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.636884] Bluetooth: RFCOMM socket layer initialized
[    1.636892] Bluetooth: RFCOMM ver 1.11
[    1.636895] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.636899] Bluetooth: HIDP socket layer initialized
[    1.636913] 9pnet: Installing 9P2000 support
[    1.636950] Key type dns_resolver registered
[    1.637227] Registered cp15_barrier emulation handler
[    1.637248] Registered setend emulation handler
[    1.638078] registered taskstats version 1
[    1.640498] isp 15600000.isp: initialized
[    1.641282] usb 2-2: new SuperSpeed USB device number 2 using tegra-xusb
[    1.643612] nvcsi 150c0000.nvcsi: initialized
[    1.644535] tegra-vi4 15700000.vi: using default number of vi channels,15
[    1.646966] Wake83 for irq=51
[    1.647042] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[    1.647184] input: gpio-keys as /devices/gpio-keys/input/input2
[    1.648414] tegra-vi4 15700000.vi: initialized
[    1.649247] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--2 bound
[    1.649328] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[    1.663702] usb 2-2: New USB device found, idVendor=05e3, idProduct=0620
[    1.663706] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.663709] usb 2-2: Product: USB3.2 Hub
[    1.663712] usb 2-2: Manufacturer: GenesysLogic
[    1.666370] hub 2-2:1.0: USB hub found
[    1.667049] hub 2-2:1.0: 2 ports detected
[    1.668703] usb 1-2: usb_suspend_both: status 0
[    1.677339] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:01:25 UTC (946688485)
[    1.678100] mmcblk mmc0:0001: Card claimed for testing.
[    1.679244] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.695825] bpmp: mounted debugfs mirror
[    1.696694] bwmgr: missing cdev-type property
[    1.700568] ALSA device list:
[    1.700572]   #0: tegra-hda at 0x3518000 irq 378
[    1.700574]   #1: tegra-snd-t186ref-mobile-rt565x
[    1.702994] Freeing unused kernel memory: 8640K
[    1.725102] Root device found: mmcblk0p1
[    1.726179] Found dev node: /dev/mmcblk0p1
[    1.745220] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.746955] Rootfs mounted over mmcblk0p1
[    1.756847] usb usb1: usb_suspend_both: status 0
[    1.770346] Switching from initrd to actual rootfs
[    1.824699] usb 2-2: usb_suspend_both: status 0
[    1.824809] usb usb2: usb_suspend_both: status 0
[    1.853505] systemd[1]: System time before build time, advancing clock.
[    1.870126] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.878900] cgroup: cgroup2: unknown option "nsdelegate"
[    1.890762] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.891478] systemd[1]: Detected architecture arm64.
[    1.909806] systemd[1]: Set hostname to <tx2nx-desktop>.
[    1.992387] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    1.992394] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.080705] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    2.082723] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[    2.105510] random: systemd: uninitialized urandom read (16 bytes read)
[    2.105542] systemd[1]: Reached target Mounting snaps.
[    2.105695] random: systemd: uninitialized urandom read (16 bytes read)
[    2.105712] systemd[1]: Reached target Mounted snaps.
[    2.105857] random: systemd: uninitialized urandom read (16 bytes read)
[    2.106830] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.106955] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.108326] systemd[1]: Created slice User and Session Slice.
[    2.156592] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.186670] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[    2.186677] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.186680] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[    2.186683] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[    2.186686] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.186716] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[    2.186894] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.187064] iommu: Adding device 0000:00:03.0 to group 52
[    2.187071] arm-smmu: forcing sodev map for 0000:00:03.0
[    2.187142] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.187317] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[    2.187410] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[    2.187929] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    2.188179] iommu: Adding device 0000:01:00.0 to group 53
[    2.188184] arm-smmu: forcing sodev map for 0000:01:00.0
[    2.196893] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.196945] pci 0000:00:03.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
[    2.196951] pci 0000:01:00.0: BAR 0: assigned [mem 0x40100000-0x40101fff 64bit]
[    2.196998] pci 0000:00:03.0: PCI bridge to [bus 01]
[    2.197006] pci 0000:00:03.0:   bridge window [mem 0x40100000-0x401fffff]
[    2.197665] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[    2.197669] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.197676] pcie_pme 0000:00:03.0:pcie001: service driver pcie_pme loaded
[    2.197764] aer 0000:00:03.0:pcie002: service driver aer loaded
[    2.468666] systemd-journald[2134]: Received request to flush runtime journal from PID 1
[    2.495581] Intel(R) Wireless WiFi driver for Linux
[    2.495585] Copyright(c) 2003- 2015 Intel Corporation
[    2.495923] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[    2.499062] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[    2.509461] iwlwifi 0000:01:00.0: Falling back to user helper
[    2.848720] random: crng init done
[    2.852171] random: 130 urandom warning(s) missed due to ratelimiting
[    3.088885] using random self ethernet address
[    3.093518] using random host ethernet address
[    3.691995] Mass Storage Function, version: 2009/09/11
[    3.692002] LUN: removable file: (no medium)
[    3.707504] using random self ethernet address
[    3.726787] using random host ethernet address
[    3.801194] rndis0: HOST MAC 7a:fe:f9:f1:7d:ec
[    3.801256] rndis0: MAC 7a:fe:f9:f1:7d:ed
[    3.803519] usb0: HOST MAC 7a:fe:f9:f1:7d:ee
[    3.803555] usb0: MAC 7a:fe:f9:f1:7d:ef
[    3.803585] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[    3.804981] bcpu-throttle-alert cooling device registered.
[    3.807696] mcpu-throttle-alert cooling device registered.
[    3.809248] l4tbr0: port 1(rndis0) entered blocking state
[    3.809252] l4tbr0: port 1(rndis0) entered disabled state
[    3.809779] device rndis0 entered promiscuous mode
[    3.815929] gpu-throttle-alert cooling device registered.
[    3.819769] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    3.828770] l4tbr0: port 2(usb0) entered blocking state
[    3.828773] l4tbr0: port 2(usb0) entered disabled state
[    3.829346] device usb0 entered promiscuous mode
[    3.836147] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    3.884535] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    3.916769] tegra-xusb 3530000.xhci: entering ELPG
[    3.919525] tegra-xusb 3530000.xhci: entering ELPG done
[    3.920472] android_work: did not send uevent (0 0           (null))
[    3.956155] android_work: sent uevent USB_STATE=CONNECTED
[    4.201775] gpio tegra-gpio-aon wake51 for gpio=47(AA:7)
[    4.207115] net eth0: get_configure_l3v4_filter -->
[    4.208445] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.263067] zram: Added device: zram0
[    4.265556] zram: Added device: zram1
[    4.269428] zram: Added device: zram2
[    4.273438] zram: Added device: zram3
[    4.274092] zram: Added device: zram4
[    4.274547] zram: Added device: zram5
[    4.340467] zram0: detected capacity change from 0 to 334258176
[    4.428732] Adding 326420k swap on /dev/zram0.  Priority:5 extents:1 across:326420k SS
[    4.441859] zram1: detected capacity change from 0 to 334258176
[    4.464829] Adding 326420k swap on /dev/zram1.  Priority:5 extents:1 across:326420k SS
[    4.466754] android_work: sent uevent USB_STATE=DISCONNECTED
[    4.468352] zram2: detected capacity change from 0 to 334258176
[    4.500228] android_work: sent uevent USB_STATE=CONNECTED
[    4.520643] configfs-gadget gadget: high-speed config #1: c
[    4.520680] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[    4.520698] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[    4.520716] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[    4.520822] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[    4.520841] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[    4.520858] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[    4.520896] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[    4.520925] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[    4.520948] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[    4.521052] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[    4.521254] android_work: sent uevent USB_STATE=CONFIGURED
[    4.524974] Adding 326420k swap on /dev/zram2.  Priority:5 extents:1 across:326420k SS
[    4.542460] zram3: detected capacity change from 0 to 334258176
[    4.555390] tegra-xudc-new 3550000.xudc: setup request failed: -22
[    4.562630] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[    4.562651] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[    4.562850] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[    4.592407] Adding 326420k swap on /dev/zram3.  Priority:5 extents:1 across:326420k SS
[    4.606876] zram4: detected capacity change from 0 to 334258176
[    4.638052] Adding 326420k swap on /dev/zram4.  Priority:5 extents:1 across:326420k SS
[    4.648839] zram5: detected capacity change from 0 to 334258176
[    4.675721] Adding 326420k swap on /dev/zram5.  Priority:5 extents:1 across:326420k SS
[    4.692465] configfs-gadget gadget: Wrong NDP SIGN
[    4.715957] configfs-gadget gadget: Wrong NDP SIGN
[    4.886079] configfs-gadget gadget: Wrong NDP SIGN
[    4.889074] configfs-gadget gadget: Wrong NDP SIGN
[    4.889128] configfs-gadget gadget: Wrong NDP SIGN
[    4.938354] Bridge firewalling registered
[    4.976450] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    5.250531] Netfilter messages via NETLINK v0.30.
[    5.256468] ctnetlink v0.93: registering with nfnetlink.
[    5.398936] configfs-gadget gadget: Wrong NDP SIGN
[    5.500734] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[    5.661305] tegradc 15200000.nvdisplay: blank - powerdown
[    5.661319] tegradc 15200000.nvdisplay: unblank
[    5.724050] configfs-gadget gadget: Wrong NDP SIGN
[    5.776733] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.776737] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    5.828712] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.828716] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    5.880726] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.880730] tegradc 15200000.nvdisplay: timeout waiting for postcomp init state to promote
[    5.893021] configfs-gadget gadget: Wrong NDP SIGN
[    5.928964] configfs-gadget gadget: Wrong NDP SIGN
[    5.929033] configfs-gadget gadget: Wrong NDP SIGN
[    5.930326] configfs-gadget gadget: Wrong NDP SIGN
[    5.931107] configfs-gadget gadget: Wrong NDP SIGN
[    5.932772] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.932776] tegradc 15200000.nvdisplay: timeout waiting for win assignments to promote
[    5.932779] tegradc 15200000.nvdisplay: tegra_nvdisp_head_enable, failed head enable
[    5.933659] configfs-gadget gadget: Wrong NDP SIGN
[    5.955938] configfs-gadget gadget: Wrong NDP SIGN
[    5.957553] configfs-gadget gadget: Wrong NDP SIGN
[    5.957608] configfs-gadget gadget: Wrong NDP SIGN
[    5.957657] configfs-gadget gadget: Wrong NDP SIGN
[    5.958137] configfs-gadget gadget: Wrong NDP SIGN
[    5.958322] configfs-gadget gadget: Wrong NDP SIGN
[    5.959500] configfs-gadget gadget: Wrong NDP SIGN
[    5.959769] configfs-gadget gadget: Wrong NDP SIGN
[    5.960302] configfs-gadget gadget: Wrong NDP SIGN
[    5.960815] configfs-gadget gadget: Wrong NDP SIGN
[    5.960949] configfs-gadget gadget: Wrong NDP SIGN
[    6.069389] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[    6.069392] iwlwifi 0000:01:00.0: Falling back to user helper
[    6.108778] tegradc 15200000.nvdisplay: unblank
[    6.244721] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.244725] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    6.296700] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.296704] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    6.348707] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.348710] tegradc 15200000.nvdisplay: timeout waiting for postcomp init state to promote
[    6.386834] configfs-gadget gadget: Wrong NDP SIGN
[    6.400714] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.400719] tegradc 15200000.nvdisplay: timeout waiting for win assignments to promote
[    6.400722] tegradc 15200000.nvdisplay: tegra_nvdisp_head_enable, failed head enable
We encountered the same issue as this ticket, At the same time, I didn’t see any solution in this ticket, except for pull-up the DP HPD pin
The reason that there is no reply on that old post is because there is already no software thing to do for that HPD detection on DP.
Disable all the SOR node and it shall not affect the DP things anymore.
Hi Wayne,
We try to disable all SOR(sor0 and sor1) and the problem also occur.
I attach the dts.
dmesg
[    0.000976] Console: colour dummy device 80x25
[    0.000980] console [tty0] enabled
[    0.000984] bootconsole [uart8250] disabled
[    0.000991] kmemleak: Kernel memory leak detector disabled
[    0.001002] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.001008] pid_max: default: 32768 minimum: 301
[    0.001339] Security Framework initialized
[    0.002089] ftrace: allocating 47298 entries in 185 pages
[    0.132089] sched-energy: Sched-energy-costs installed from DT
[    0.164890] tegra-id: chipid=21817.
[    0.164896] tegra-id: opt_subrevision=1.
[    0.164916] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.164924] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/lanai/kernel-dts/tegra186-p3636-0001-p3509-
[    0.164928] DTB Build time: <unknown>
[    0.214637] CPU1: Booted secondary processor [4e0f0030]
[    0.246018] CPU2: Booted secondary processor [4e0f0030]
[    0.277020] CPU3: Booted secondary processor [411fd073]
[    0.308988] CPU4: Booted secondary processor [411fd073]
[    0.340978] CPU5: Booted secondary processor [411fd073]
[    0.341040] CPU features: detected feature: 32-bit EL0 Support
[    0.342904] CPU: All CPU(s) started at EL2
[    0.343032] alternatives: patching kernel code
[    0.345391] devtmpfs: initialized
[    0.367810] Initilizing CustomIPI irq domain
[    0.367953] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.367962] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.376937] pinctrl core: initialized pinctrl subsystem
[    0.377205] OS set in device tree is not L4T.
[    0.377366] regulator-dummy: no parameters
[    0.377501] Initializing plugin-manager
[    0.377557] Plugin module not found
[    0.377591] Plugin-manager status disabled
[    0.378815] NET: Registered protocol family 16
[    0.379846] pstore: using zlib compression
[    0.379859] console [pstore-1] enabled
[    0.379862] pstore: Registered ramoops as persistent store backend
[    0.379866] ramoops: attached 0x200000@0x175880000, ecc: 0/0
[    0.393035] cpuidle: using governor menu
[    0.393968] bpmp: waiting for handshake
[    0.393972] bpmp: handshake completed
[    0.393990] bpmp: synchronizing channels
[    0.393997] bpmp: channels synchronized
[    0.394000] bpmp: mail init ok
[    0.395461] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.395466] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.395470] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.395473] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.395476] arm-smmu 12000000.iommu: 	nested translation
[    0.395482] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.395487] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.395491] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.395496] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.395499] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.397307] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.397321] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.400657] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.401679] Registering BPMP clocks...
[    0.401751] tegra_bpmp_clk_init: clock init ok (638 clks)
[    0.402236] Serial: AMBA PL011 UART driver
[    0.403144] tegra_powergate_init: DONE
[    0.403151] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/lanai/kernel-dts/tegra186-p3636-0001-p3509-
[    0.403156] DTB Build time: <unknown>
[    0.404449] Tegra reboot handler registered.
[    0.405614] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.405679] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.405693] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.405695] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[    0.405698] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.405851] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.405861] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.406127] iommu: Adding device 3460000.sdhci to group 0
[    0.407266] iommu: Adding device 3160000.i2c to group 1
[    0.407649] iommu: Adding device c240000.i2c to group 2
[    0.407935] iommu: Adding device 3180000.i2c to group 3
[    0.408211] iommu: Adding device 3190000.i2c to group 4
[    0.408576] iommu: Adding device 31b0000.i2c to group 5
[    0.408874] iommu: Adding device 31c0000.i2c to group 6
[    0.409197] iommu: Adding device c250000.i2c to group 7
[    0.409478] iommu: Adding device 31e0000.i2c to group 8
[    0.410892] iommu: Adding device 3210000.spi to group 9
[    0.411169] iommu: Adding device c260000.spi to group 10
[    0.411806] iommu: Adding device 3100000.serial to group 11
[    0.412099] iommu: Adding device 3110000.serial to group 12
[    0.412390] iommu: Adding device 3130000.serial to group 13
[    0.413553] iommu: Adding device 2490000.ether_qos to group 14
[    0.413565] arm-smmu: forcing sodev map for 2490000.ether_qos
[    0.414383] iommu: Adding device b000000.rtcpu to group 15
[    0.416083] iommu: Adding device 13e10000.host1x to group 16
[    0.416377] iommu: Adding device 13e10000.host1x:ctx0 to group 17
[    0.416651] iommu: Adding device 13e10000.host1x:ctx1 to group 18
[    0.416933] iommu: Adding device 13e10000.host1x:ctx2 to group 19
[    0.417226] iommu: Adding device 13e10000.host1x:ctx3 to group 20
[    0.417511] iommu: Adding device 13e10000.host1x:ctx4 to group 21
[    0.417785] iommu: Adding device 13e10000.host1x:ctx5 to group 22
[    0.418061] iommu: Adding device 13e10000.host1x:ctx6 to group 23
[    0.418349] iommu: Adding device 13e10000.host1x:ctx7 to group 24
[    0.418757] iommu: Adding device 150c0000.nvcsi to group 25
[    0.419307] iommu: Adding device 15700000.vi to group 26
[    0.419608] iommu: Adding device 15600000.isp to group 27
[    0.419806] iommu: Adding device 15200000.dc_common to group 28
[    0.419848] platform 15200000.dc_common: OF IOVA linear map 0x96085000 size (0x800000)
[    0.419889] platform 15200000.dc_common: OF IOVA linear map 0x96081000 size (0x2008)
[    0.420330] iommu: Adding device 15200000.nvdisplay to group 29
[    0.420764] iommu: Adding device 15340000.vic to group 30
[    0.420954] iommu: Adding device 154c0000.nvenc to group 31
[    0.421167] iommu: Adding device 15480000.nvdec to group 32
[    0.421458] iommu: Adding device 15380000.nvjpg to group 33
[    0.421645] iommu: Adding device 15500000.tsec to group 34
[    0.421838] iommu: Adding device 15100000.tsecb to group 35
[    0.422033] iommu: Adding device 15810000.se to group 36
[    0.422219] iommu: Adding device 15820000.se to group 37
[    0.422398] iommu: Adding device 15830000.se to group 38
[    0.422576] iommu: Adding device 15840000.se to group 39
[    0.423306] iommu: Adding device smmu_test to group 40
[    0.423862] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c10000
[    0.423873] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c20000
[    0.423882] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c30000
[    0.423891] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c40000
[    0.423900] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c50000
[    0.423907] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.423916] mc-err: mcerr ops are set to t18x
[    0.424053] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[    0.424811] iommu: Adding device 3530000.xhci to group 41
[    0.424827] arm-smmu: forcing sodev map for 3530000.xhci
[    0.425301] iommu: Adding device 3550000.xudc to group 42
[    0.425313] arm-smmu: forcing sodev map for 3550000.xudc
[    0.425823] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[    0.425829] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.425834] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.426416] iommu: Adding device 17000000.gp10b to group 43
[    0.427328] tegra-reset 5000000.clock: registered 193 resets.
[    0.429199] iommu: Adding device d000000.bpmp to group 44
[    0.429402] bpmp: ping status is 0
[    0.429478] bpmp d000000.bpmp: firmware tag is 91572a54614f84d0fd0c270beec2c56f
[    0.431042] bpmp d000000.bpmp: probe ok
[    0.433595] iommu: Adding device 2600000.dma to group 45
[    0.434380] GPIO line 424 (camera-control-output-low) hogged as output/low
[    0.434411] GPIO line 427 (camera-control-output-low) hogged as output/low
[    0.434455] GPIO line 408 (w-disable1) hogged as output/high
[    0.434490] GPIO line 410 (w-disable2) hogged as output/high
[    0.434642] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[    0.438422] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[    0.439959] iommu: Adding device 10003000.pcie-controller to group 46
[    0.439974] arm-smmu: forcing sodev map for 10003000.pcie-controller
[    0.440280] iommu: Adding device sound to group 47
[    0.440591] iommu: Adding device 3510000.hda to group 48
[    0.447114] iommu: Adding device c1a0000.aon to group 49
[    0.447654] vdd-1v8-ap: 1800 mV
[    0.447860] vdd-ac-bat: 5000 mV
[    0.448040] vdd-3v3-disp-cvb: 3300 mV
[    0.448310] vdd-3v3-cvb: 3300 mV
[    0.448492] vdd-1v8-cvb: 1800 mV
[    0.448675] vdd-fan: 5000 mV
[    0.448873] vdd-hdmi-5v0: 5000 mV
[    0.449089] vdd_sys_en: 1200 mV
[    0.473746] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.476289] eventlib_kernel: keventlib is initialized, test id: 0
[    0.476492] SCSI subsystem initialized
[    0.476652] libata version 3.00 loaded.
[    0.476776] usbcore: registered new interface driver usbfs
[    0.476809] usbcore: registered new interface driver hub
[    0.476836] usbcore: registered new device driver usb
[    0.485985] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.488683] vddio-ddr: at 1125 mV
[    0.492552] avdd_dsi_csi: 1200 mV
[    0.496547] vdd-1v8: 1800 mV
[    0.500551] vdd-3v3-sys: 3300 mV
[    0.501430] spmic-ldo0: at 1800 mV
[    0.502063] spmic-ldo1: at 800 mV
[    0.504549] vddio-3v3: 3300 mV
[    0.505210] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.508550] vdd-rtc: at 800 mV
[    0.509233] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[    0.512549] spmic-ldo6: at 800 mV
[    0.516548] vdd-pex-1v00: 1000 mV
[    0.517137] dvdd-pex: 1000 mV
[    0.519104] GPIO line 253 (spmic_gpio_input) hogged as input
[    0.519234] GPIO line 254 (spmic_gpio_input) hogged as input
[    0.519388] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[    0.519558] max77620 4-003c: max77620 probe successful
[    0.519908] media: Linux media interface: v0.10
[    0.519936] Linux video capture interface: v2.00
[    0.522149] pps_core: LinuxPPS API ver. 1 registered
[    0.522152] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.522165] PTP clock support registered
[    0.522341] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.522527] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.522543] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.523641] trusty trusty: trusty version: Built: 16:08:32 Jun 11 2024
[    0.523655] trusty trusty: selected api version: 3 (requested 3)
[    0.524784] Advanced Linux Sound Architecture Driver Initialized.
[    0.525152] Bluetooth: Core ver 2.22
[    0.525180] NET: Registered protocol family 31
[    0.525182] Bluetooth: HCI device and connection manager initialized
[    0.525189] Bluetooth: HCI socket layer initialized
[    0.525196] Bluetooth: L2CAP socket layer initialized
[    0.525209] Bluetooth: SCO socket layer initialized
[    0.525781] vdd-sys-bl: 3300 mV
[    0.527308] camchar: rtcpu character device driver loaded
[    0.527725] gpio tegra-gpio wake61 for gpio=92(L:4)
[    0.527795] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[    0.528720] clocksource: Switched to clocksource arch_sys_counter
[    0.551082] VFS: Disk quotas dquot_6.6.0
[    0.551162] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.551425] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.551852] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    0.551983] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    0.551987] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.552011] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[    0.552016] nvmap_page_pool_init: Total RAM pages: 975338
[    0.552019] nvmap_page_pool_init: nvmap page pool size: 121917 pages (476 MB)
[    0.552066] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.552538] misc nvmap: created heap vpr base 0x        (ptrval) size (688128KiB)
[    0.554449] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    0.559934] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.560119] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.560466] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.560542] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.560706] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.560915] la/ptsa driver initialized.
[    0.560923] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.560926] pre_t19x_iso_plat_init(): max_iso_bw=23040000KB
[    0.561239] NET: Registered protocol family 2
[    0.561318] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.596867] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.597027] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.597331] TCP: Hash tables configured (established 32768 bind 32768)
[    0.597379] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.597439] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.597708] NET: Registered protocol family 1
[    0.598046] RPC: Registered named UNIX socket transport module.
[    0.598049] RPC: Registered udp transport module.
[    0.598051] RPC: Registered tcp transport module.
[    0.598054] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.598060] PCI: CLS 0 bytes, default 64
[    0.598173] Trying to unpack rootfs image as initramfs...
[    0.810454] Freeing initrd memory: 7068K
[    0.825081] host1x 13e10000.host1x: initialized
[    0.826328] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.828412] audit: initializing netlink subsys (disabled)
[    0.828444] audit: type=2000 audit(0.712:1): initialized
[    0.828870] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.835416] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.836396] ntfs: driver 2.1.32 [Flags: R/W].
[    0.836941] 9p: Installing v9fs 9p2000 file system support
[    0.838964] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.839030] io scheduler noop registered
[    0.839236] io scheduler cfq registered (default)
[    0.842068] gic 2a41000.agic-controller: GIC IRQ controller registered
[    0.852595] iommu: Adding device aconnect@2a41000:adsp_audio to group 50
[    0.872570] iommu: Adding device 2993000.adsp to group 51
[    0.873116] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    0.877927] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.878763] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    0.879544] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.880303] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.882223] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[    0.882885] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[    0.883098] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[    0.883350] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.883458] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    0.884826] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[    0.885635] tsec 15500000.tsec: initialized
[    0.886499] tsec 15100000.tsecb: initialized
[    0.888643] nvdec 15480000.nvdec: initialized
[    0.892526] falcon 15340000.vic: initialized
[    0.893620] falcon 154c0000.nvenc: initialized
[    0.894619] falcon 15380000.nvjpg: initialized
[    0.896382] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    0.897744] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    0.899148] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    0.900547] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    0.902023] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    0.903370] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    0.904721] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    0.906067] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    0.908575] tegradccommon 15200000.dc_common: host1x channel mapped
[    0.908582] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    0.908614] tegradccommon 15200000.dc_common: dma mapping done
[    0.909429] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/dsi
[    0.909543] tegradc 15200000.nvdisplay: No hpd-gpio in DT
[    0.909582] tegradc 15200000.nvdisplay: DT parsed successfully
[    0.909603] tegradc 15200000.nvdisplay: Display dc.        (ptrval) registered with id=0
[    0.915297] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[    0.915301] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[    0.915304] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[    0.915453] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    0.915459] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    0.918614] tegradc 15200000.nvdisplay: Force clock continuous mode
[    0.919680] tegradc 15200000.nvdisplay: probed
[    0.921231] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    0.921864] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    0.921885] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    0.922267] kfuse 3830000.kfuse: initialized
[    0.923446] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.926267] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.928349] console [ttyS0] disabled
[    0.928384] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 33, base_baud = 25500000) is a Tegra
[    0.928423] console [ttyS0] enabled
[    0.929592] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 34, base_baud = 0) is a TEGRA_UART
[    0.929766] serial-tegra 3130000.serial: RX in PIO mode
[    0.930337] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 35, base_baud = 0) is a TEGRA_UART
[    0.931352] [drm] Initialized
[    0.935751] Console: switching to colour frame buffer device 160x50
[    0.938138] brd: module loaded
[    0.940124] tegradc 15200000.nvdisplay: fb registered
[    0.940563] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    0.940610] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    0.941491] loop: module loaded
[    0.941539] tegra_profiler: version: 1.145, samples/io: 49/28
[    0.941618] tegra_profiler: auth: init
[    0.942272] THERMAL EST: found 3 subdevs
[    0.942276] THERMAL EST num_resources: 0
[    0.942280] [THERMAL EST subdev 0]
[    0.942284] [THERMAL EST subdev 1]
[    0.942287] [THERMAL EST subdev 2]
[    0.942296] THERMAL EST: Found 2 profiles, default profile is quiet
[    0.942542] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    0.942544] THERMAL EST: thz register success.
[    0.942639] THERMAL EST: end of probe, return err: 0
[    0.943244] sd: No Scsi addr parsed to reserve index
[    0.943267] hisi_sas: driver version v1.6
[    0.948572] tun: Universal TUN/TAP device driver, 1.6
[    0.948576] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.949250] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    0.949253] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.949284] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    0.949286] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.949320] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.949322] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.949352] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    0.949354] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    1.080675] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    1.087266] tegradc 15200000.nvdisplay: timeout waiting for postcomp init state to promote
[    1.144671] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    1.151244] tegradc 15200000.nvdisplay: timeout waiting for win assignments to promote
[    1.159208] tegradc 15200000.nvdisplay: tegra_nvdisp_head_enable, failed head enable
[    1.188744] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[    1.190680] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[    1.191095] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3b 70 f5
[    1.191118] Using phyrst_lpmode = 1 from DT
[    1.193343] PPP generic driver version 2.4.2
[    1.193516] PPP BSD Compression module registered
[    1.193519] PPP Deflate Compression module registered
[    1.193532] PPP MPPE Compression module registered
[    1.193536] NET: Registered protocol family 24
[    1.193604] usbcore: registered new interface driver r8152
[    1.193666] usbcore: registered new interface driver asix
[    1.193722] usbcore: registered new interface driver ax88179_178a
[    1.193779] usbcore: registered new interface driver cdc_ether
[    1.193833] usbcore: registered new interface driver net1080
[    1.193887] usbcore: registered new interface driver cdc_subset
[    1.193940] usbcore: registered new interface driver zaurus
[    1.194004] usbcore: registered new interface driver cdc_ncm
[    1.194160] VFIO - User Level meta-driver version: 0.3
[    1.195108] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.195117] ehci-pci: EHCI PCI platform driver
[    1.195178] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.195184] ohci-pci: OHCI PCI platform driver
[    1.195242] ohci-platform: OHCI generic platform driver
[    1.198718] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[    1.200125] tegra-xusb 3530000.xhci: extcon 0:         (ptrval) id
[    1.200845] usbcore: registered new interface driver uas
[    1.200888] usbcore: registered new interface driver usb-storage
[    1.200955] usbcore: registered new interface driver usbserial
[    1.202464] tegra-xusb 3530000.xhci: Firmware timestamp: 2020-07-06 13:39:28 UTC, Version: 55.18 release
[    1.202486] tegra-xusb 3530000.xhci: xHCI Host Controller
[    1.202504] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[    1.203226] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[    1.203253] tegra-xusb 3530000.xhci: irq 64, io mem 0x03530000
[    1.203421] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.203426] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.203430] usb usb1: Product: xHCI Host Controller
[    1.203434] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.203437] usb usb1: SerialNumber: 3530000.xhci
[    1.203759] hub 1-0:1.0: USB hub found
[    1.203787] hub 1-0:1.0: 4 ports detected
[    1.204150] tegra-xusb 3530000.xhci: xHCI Host Controller
[    1.204158] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[    1.204288] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.204292] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.204295] usb usb2: Product: xHCI Host Controller
[    1.204298] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.204301] usb usb2: SerialNumber: 3530000.xhci
[    1.204588] hub 2-0:1.0: USB hub found
[    1.204612] hub 2-0:1.0: 3 ports detected
[    1.205132] Wake76 for irq=199
[    1.205134] Wake77 for irq=199
[    1.205136] Wake78 for irq=199
[    1.205138] Wake79 for irq=199
[    1.205140] Wake80 for irq=199
[    1.205141] Wake81 for irq=199
[    1.205143] Wake82 for irq=199
[    1.205168] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[    1.205173] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[    1.206015] tegra-xudc-new 3550000.xudc: device count: 1
[    1.207041] tegra-xudc-new 3550000.xudc: USB charger detection disabled
[    1.207049] tegra-xudc-new 3550000.xudc: vbus state: 1
[    1.207057] tegra-xudc-new 3550000.xudc: device mode on: 0
[    1.207183] tegra-xudc-new 3550000.xudc: active: 0 => 1
[    1.207608] mousedev: PS/2 mouse device common for all mice
[    1.207660] usbcore: registered new interface driver xpad
[    1.308902] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.325937] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.326918] Wake73 for irq=42
[    1.328162] rtc rtc1: alarm rtc device
[    1.328173] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    1.328187] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    1.328331] i2c /dev entries driver
[    1.329922] i2c i2c-2: Added multiplexed i2c bus 9
[    1.330165] i2c i2c-2: Added multiplexed i2c bus 10
[    1.330169] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    1.330560] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    1.353896] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    1.353934] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.361545] imx219 9-0010: board setup failed
[    1.365983] imx219: probe of 9-0010 failed with error -121
[    1.366278] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    1.389479] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    1.389523] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.397200] imx219 10-0010: board setup failed
[    1.401725] imx219: probe of 10-0010 failed with error -121
[    1.402838] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.407036] parse_throttle_dt_data: Num cap clks = 4
[    1.407041] parse_throttle_dt_data: clk=mcpu type=1
[    1.407043] parse_throttle_dt_data: clk=bcpu type=2
[    1.407050] parse_throttle_dt_data: clk=gpu type=4
[    1.407053] parse_throttle_dt_data: clk=emc type=3
[    1.407665] tegra_throttle_probe: probe successful. #cdevs=4
[    1.408149] FAN dev name: pwm-fan
[    1.408200] FAN:gpio request success.
[    1.408208] FAN: can't find tach_gpio
[    1.408216] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    1.408235] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    1.408408] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.408412] pwm_fan_driver pwm-fan: tach period: 1000
[    1.408856] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.408861] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    1.408865] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    1.408869] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    1.408872] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.408876] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.408879] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.408883] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.408886] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.408890] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.409380] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    1.410320] device-mapper: uevent: version 1.0.3
[    1.410641] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.410881] CPU EMC frequency mapping table: from device tree
[    1.412790] cpufreq: platform driver Initialization: pass
[    1.413313] cpuidle: Initializing cpuidle driver init for Denver cluster
[    1.413430] cpuidle: Initializing cpuidle driver init for A57 cluster
[    1.414181] sdhci: Secure Digital Host Controller Interface driver
[    1.414183] sdhci: Copyright(c) Pierre Ossman
[    1.414184] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.415120] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    1.416689] CMDQ: cmdq_platfm_init successful
[    1.417600] CQE: CMD_TIMING bit set for R1B DCMD
[    1.417635] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    1.422804] tegra-se-nvhost 15810000.se: initialized
[    1.424880] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    1.425383] tegra-se-nvhost 15820000.se: initialized
[    1.426308] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    1.426747] tegra-se-nvhost 15830000.se: initialized
[    1.427533] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    1.427942] tegra-se-nvhost 15840000.se: initialized
[    1.428847] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    1.429531] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    1.429655] hidraw: raw HID events driver (C) Jiri Kosina
[    1.430887] usbcore: registered new interface driver usbhid
[    1.430889] usbhid: USB HID core driver
[    1.433609] ashmem: initialized
[    1.435664] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    1.437392] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[    1.437594] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    1.437710] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[    1.437774] tegra186-cam-rtcpu b000000.rtcpu: no priority specified, using 99 as default
[    1.438411] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[    1.438482] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[    1.438524] tegra-capture-ivc ivc-b000000.rtcpu:ivccontrol@52c0: no priority specified, using 99 as default
[    1.438574] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[    1.438621] tegra-capture-ivc ivc-b000000.rtcpu:ivccapture@72c0: no priority specified, using 99 as default
[    1.438669] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[    1.438770] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9180-0xb200 TX[1x8192]=0xb200-0xd280
[    1.439049] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (48)
[    1.439052] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    1.439532] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=bf12e2c549579b8fe7e0596d313688814d0c34ea
[    1.441172] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    1.441578] tegra186-aondbg aondbg: aondbg driver probe() OK
[    1.441963] register_ari_mca_banks: Registered MCA ROC:IOB
[    1.442260] register_ari_mca_banks: Registered MCA ROC:CCE
[    1.442957] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.442959] tegra18-bridge 2390000.axi2apb: enabled timeout = 9894000
[    1.442962] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    1.443006] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443008] tegra18-bridge 23a0000.axi2apb: enabled timeout = 9894000
[    1.443010] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    1.443051] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443053] tegra18-bridge 23b0000.axi2apb: enabled timeout = 9894000
[    1.443055] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    1.443095] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443097] tegra18-bridge 23c0000.axi2apb: enabled timeout = 9894000
[    1.443099] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    1.443141] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443143] tegra18-bridge 23d0000.axi2apb: enabled timeout = 9894000
[    1.443145] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    1.443186] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443191] tegra18-bridge 2100000.axip2p: enabled timeout = 9894000
[    1.443193] tegra18-bridge 2100000.axip2p: bridge probed OK
[    1.443237] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443242] tegra18-bridge 2110000.axip2p: enabled timeout = 9894000
[    1.443244] tegra18-bridge 2110000.axip2p: bridge probed OK
[    1.443287] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443291] tegra18-bridge 2120000.axip2p: enabled timeout = 9894000
[    1.443293] tegra18-bridge 2120000.axip2p: bridge probed OK
[    1.443333] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443338] tegra18-bridge 2130000.axip2p: enabled timeout = 9894000
[    1.443340] tegra18-bridge 2130000.axip2p: bridge probed OK
[    1.443388] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443391] tegra18-bridge 2140000.axip2p: enabled timeout = 9894000
[    1.443393] tegra18-bridge 2140000.axip2p: bridge probed OK
[    1.443434] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443439] tegra18-bridge 2150000.axip2p: enabled timeout = 9894000
[    1.443441] tegra18-bridge 2150000.axip2p: bridge probed OK
[    1.443482] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443487] tegra18-bridge 2160000.axip2p: enabled timeout = 9894000
[    1.443489] tegra18-bridge 2160000.axip2p: bridge probed OK
[    1.443529] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443534] tegra18-bridge 2170000.axip2p: enabled timeout = 9894000
[    1.443536] tegra18-bridge 2170000.axip2p: bridge probed OK
[    1.443577] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443582] tegra18-bridge 2180000.axip2p: enabled timeout = 9894000
[    1.443584] tegra18-bridge 2180000.axip2p: bridge probed OK
[    1.443627] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.443631] tegra18-bridge 2190000.axip2p: enabled timeout = 9894000
[    1.443633] tegra18-bridge 2190000.axip2p: bridge probed OK
[    1.443687] **** A57 ECC: Enabled
[    1.443689] tegra18_a57_serr_init: on CPU 0 a A57 Core
[    1.443749] tegra18x_actmon d230000.actmon: in actmon_register()...
[    1.444102] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    1.444471] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    1.444586] denver_knobs_init:MTS_VERSION:66340021
[    1.446948] nvpmodel: initialized successfully
[    1.447696] trusty-virtio trusty:virtio: initializing
[    1.447795] trusty_ipc virtio0: vring0: va(pa)          (ptrval)(0) qsz 32 notifyid 1
[    1.447802] trusty_ipc virtio0: vring1: va(pa)          (ptrval)(0) qsz 32 notifyid 2
[    1.447865] trusty-virtio trusty:virtio: initializing done
[    1.447944] trusty_ipc virtio0: is online
[    1.448694] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.449229] usbcore: registered new interface driver snd-usb-audio
[    1.460697] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    1.464688] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    1.469638] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    1.469788] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    1.471398] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[    1.471401] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.471404] usb 1-2: Product: USB2.1 Hub
[    1.471406] usb 1-2: Manufacturer: GenesysLogic
[    1.472210] hub 1-2:1.0: USB hub found
[    1.472490] hub 1-2:1.0: 2 ports detected
[    1.509400] OPE platform probe
[    1.509468] OPE platform probe successful
[    1.510370] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    1.525378] mmc0: periodic cache flush enabled
[    1.525444] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.529804] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.533951] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.534052] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.538168] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    1.542683]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[    1.561857] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.561932] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.562007] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.562072] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.562139] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.562205] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.562269] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.562334] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.562398] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.562467] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.562536] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    1.562600] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    1.562666] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    1.562733] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    1.562798] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    1.562875] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    1.562940] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    1.563004] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    1.563074] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    1.563137] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    1.587165] u32 classifier
[    1.587168]     Actions configured
[    1.587227] Initializing XFRM netlink socket
[    1.587782] NET: Registered protocol family 10
[    1.589101] usb 2-2: new SuperSpeed USB device number 2 using tegra-xusb
[    1.592405] NET: Registered protocol family 17
[    1.592416] NET: Registered protocol family 15
[    1.592476] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.592515] Bluetooth: RFCOMM socket layer initialized
[    1.592524] Bluetooth: RFCOMM ver 1.11
[    1.592528] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.592532] Bluetooth: HIDP socket layer initialized
[    1.592546] 9pnet: Installing 9P2000 support
[    1.592582] Key type dns_resolver registered
[    1.592893] Registered cp15_barrier emulation handler
[    1.592914] Registered setend emulation handler
[    1.593738] registered taskstats version 1
[    1.596194] isp 15600000.isp: initialized
[    1.599336] nvcsi 150c0000.nvcsi: initialized
[    1.600233] tegra-vi4 15700000.vi: using default number of vi channels,15
[    1.602739] Wake83 for irq=51
[    1.602821] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[    1.602956] input: gpio-keys as /devices/gpio-keys/input/input2
[    1.604079] tegra-vi4 15700000.vi: initialized
[    1.605030] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--2 bound
[    1.605111] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[    1.611617] usb 2-2: New USB device found, idVendor=05e3, idProduct=0620
[    1.611622] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.611625] usb 2-2: Product: USB3.2 Hub
[    1.611627] usb 2-2: Manufacturer: GenesysLogic
[    1.614265] hub 2-2:1.0: USB hub found
[    1.614902] hub 2-2:1.0: 2 ports detected
[    1.616683] usb 1-2: usb_suspend_both: status 0
[    1.633332] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:43 UTC (946688443)
[    1.634182] mmcblk mmc0:0001: Card claimed for testing.
[    1.651612] bpmp: mounted debugfs mirror
[    1.652474] bwmgr: missing cdev-type property
[    1.656489] ALSA device list:
[    1.656494]   #0: tegra-hda at 0x3518000 irq 377
[    1.656495]   #1: tegra-snd-t186ref-mobile-rt565x
[    1.658919] Freeing unused kernel memory: 8640K
[    1.680791] Root device found: mmcblk0p1
[    1.681875] Found dev node: /dev/mmcblk0p1
[    1.700623] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.702445] Rootfs mounted over mmcblk0p1
[    1.704872] usb usb1: usb_suspend_both: status 0
[    1.710691] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    1.722178] Switching from initrd to actual rootfs
[    1.768685] usb 2-2: usb_suspend_both: status 0
[    1.768791] usb usb2: usb_suspend_both: status 0
[    1.803141] systemd[1]: System time before build time, advancing clock.
[    1.819765] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.828627] cgroup: cgroup2: unknown option "nsdelegate"
[    1.839818] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.840532] systemd[1]: Detected architecture arm64.
[    1.858709] systemd[1]: Set hostname to <tx2nx-desktop>.
[    1.943466] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    1.943475] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.054485] random: systemd: uninitialized urandom read (16 bytes read)
[    2.054516] systemd[1]: Reached target Mounting snaps.
[    2.054687] random: systemd: uninitialized urandom read (16 bytes read)
[    2.056027] systemd[1]: Created slice User and Session Slice.
[    2.056072] random: systemd: uninitialized urandom read (16 bytes read)
[    2.056717] systemd[1]: Created slice System Slice.
[    2.056945] systemd[1]: Listening on udev Control Socket.
[    2.056983] systemd[1]: Reached target Slices.
[    2.112708] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[    2.114764] tegra-pcie 10003000.pcie-controller: link 0 down, ignoring
[    2.115555] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.227137] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[    2.227143] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.227146] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[    2.227149] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[    2.227153] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.227182] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[    2.227294] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[    2.227466] iommu: Adding device 0000:00:03.0 to group 52
[    2.227474] arm-smmu: forcing sodev map for 0000:00:03.0
[    2.227540] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.227710] pci 0000:01:00.0: [8086:24fd] type 00 class 0x028000
[    2.227802] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[    2.228278] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    2.228532] iommu: Adding device 0000:01:00.0 to group 53
[    2.228536] arm-smmu: forcing sodev map for 0000:01:00.0
[    2.236896] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    2.236945] pci 0000:00:03.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
[    2.236951] pci 0000:01:00.0: BAR 0: assigned [mem 0x40100000-0x40101fff 64bit]
[    2.236999] pci 0000:00:03.0: PCI bridge to [bus 01]
[    2.237007] pci 0000:00:03.0:   bridge window [mem 0x40100000-0x401fffff]
[    2.237677] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[    2.237681] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.237688] pcie_pme 0000:00:03.0:pcie001: service driver pcie_pme loaded
[    2.237771] aer 0000:00:03.0:pcie002: service driver aer loaded
[    2.244091] systemd-journald[2115]: Received request to flush runtime journal from PID 1
[    2.969677] Intel(R) Wireless WiFi driver for Linux
[    2.969680] Copyright(c) 2003- 2015 Intel Corporation
[    2.970016] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[    2.978075] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[    2.978671] using random self ethernet address
[    2.978673] using random host ethernet address
[    3.013263] iwlwifi 0000:01:00.0: Falling back to user helper
[    3.063758] random: systemd: uninitialized urandom read (16 bytes read)
[    3.096433] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    3.106822] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    3.328710] random: crng init done
[    3.332143] random: 183 urandom warning(s) missed due to ratelimiting
[    3.644181] Mass Storage Function, version: 2009/09/11
[    3.644188] LUN: removable file: (no medium)
[    3.649944] using random self ethernet address
[    3.662519] using random host ethernet address
[    3.681295] bcpu-throttle-alert cooling device registered.
[    3.681561] mcpu-throttle-alert cooling device registered.
[    3.681965] gpu-throttle-alert cooling device registered.
[    3.724216] rndis0: HOST MAC 7a:fe:f9:f1:7d:ec
[    3.726058] rndis0: MAC 7a:fe:f9:f1:7d:ed
[    3.728387] usb0: HOST MAC 7a:fe:f9:f1:7d:ee
[    3.728418] usb0: MAC 7a:fe:f9:f1:7d:ef
[    3.728447] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[    3.736535] l4tbr0: port 1(rndis0) entered blocking state
[    3.736541] l4tbr0: port 1(rndis0) entered disabled state
[    3.737418] device rndis0 entered promiscuous mode
[    3.744089] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    3.753025] l4tbr0: port 2(usb0) entered blocking state
[    3.753029] l4tbr0: port 2(usb0) entered disabled state
[    3.753570] device usb0 entered promiscuous mode
[    3.775868] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    3.805502] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    3.845883] android_work: did not send uevent (0 0           (null))
[    3.882369] android_work: sent uevent USB_STATE=CONNECTED
[    3.917228] tegra-xusb 3530000.xhci: entering ELPG
[    3.919728] tegra-xusb 3530000.xhci: entering ELPG done
[    4.125769] gpio tegra-gpio-aon wake51 for gpio=47(AA:7)
[    4.131518] net eth0: get_configure_l3v4_filter -->
[    4.134148] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.186865] android_work: sent uevent USB_STATE=DISCONNECTED
[    4.221679] android_work: sent uevent USB_STATE=CONNECTED
[    4.233429] zram: Added device: zram0
[    4.237247] zram: Added device: zram1
[    4.238980] zram: Added device: zram2
[    4.241270] zram: Added device: zram3
[    4.244096] configfs-gadget gadget: high-speed config #1: c
[    4.244142] tegra-xudc-new 3550000.xudc: ep 5 (type: 3, dir: in) enabled
[    4.244161] tegra-xudc-new 3550000.xudc: ep 3 (type: 2, dir: in) enabled
[    4.244179] tegra-xudc-new 3550000.xudc: ep 2 (type: 2, dir: out) enabled
[    4.244289] tegra-xudc-new 3550000.xudc: ep 9 (type: 3, dir: in) enabled
[    4.244308] tegra-xudc-new 3550000.xudc: ep 7 (type: 2, dir: in) enabled
[    4.244325] tegra-xudc-new 3550000.xudc: ep 4 (type: 2, dir: out) enabled
[    4.244368] tegra-xudc-new 3550000.xudc: ep 15 (type: 3, dir: in) enabled
[    4.244391] tegra-xudc-new 3550000.xudc: ep 11 (type: 2, dir: in) enabled
[    4.244418] tegra-xudc-new 3550000.xudc: ep 6 (type: 2, dir: out) enabled
[    4.244609] IPv6: ADDRCONF(NETDEV_CHANGE): rndis0: link becomes ready
[    4.244824] android_work: sent uevent USB_STATE=CONFIGURED
[    4.251336] zram: Added device: zram4
[    4.255514] zram: Added device: zram5
[    4.285495] tegra-xudc-new 3550000.xudc: setup request failed: -22
[    4.292690] tegra-xudc-new 3550000.xudc: ep 13 (type: 2, dir: in) enabled
[    4.292710] tegra-xudc-new 3550000.xudc: ep 8 (type: 2, dir: out) enabled
[    4.292919] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[    4.317541] zram0: detected capacity change from 0 to 334258176
[    4.361898] Adding 326420k swap on /dev/zram0.  Priority:5 extents:1 across:326420k SS
[    4.368135] configfs-gadget gadget: Wrong NDP SIGN
[    4.368512] zram1: detected capacity change from 0 to 334258176
[    4.390002] Adding 326420k swap on /dev/zram1.  Priority:5 extents:1 across:326420k SS
[    4.409849] zram2: detected capacity change from 0 to 334258176
[    4.431267] Adding 326420k swap on /dev/zram2.  Priority:5 extents:1 across:326420k SS
[    4.436377] configfs-gadget gadget: Wrong NDP SIGN
[    4.445062] zram3: detected capacity change from 0 to 334258176
[    4.464434] Adding 326420k swap on /dev/zram3.  Priority:5 extents:1 across:326420k SS
[    4.478337] zram4: detected capacity change from 0 to 334258176
[    4.513935] Adding 326420k swap on /dev/zram4.  Priority:5 extents:1 across:326420k SS
[    4.521279] zram5: detected capacity change from 0 to 334258176
[    4.541320] Adding 326420k swap on /dev/zram5.  Priority:5 extents:1 across:326420k SS
[    4.561770] configfs-gadget gadget: Wrong NDP SIGN
[    4.790767] configfs-gadget gadget: Wrong NDP SIGN
[    4.790817] configfs-gadget gadget: Wrong NDP SIGN
[    5.013988] Bridge firewalling registered
[    5.058060] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    5.284966] configfs-gadget gadget: Wrong NDP SIGN
[    5.350874] Netfilter messages via NETLINK v0.30.
[    5.354320] ctnetlink v0.93: registering with nfnetlink.
[    5.439516] configfs-gadget gadget: Wrong NDP SIGN
[    5.502292] tegradc 15200000.nvdisplay: blank - powerdown
[    5.502306] tegradc 15200000.nvdisplay: unblank
[    5.539773] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[    5.627207] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.627211] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    5.676720] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.676723] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    5.728762] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.728766] tegradc 15200000.nvdisplay: timeout waiting for postcomp init state to promote
[    5.779210] configfs-gadget gadget: Wrong NDP SIGN
[    5.780712] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    5.780716] tegradc 15200000.nvdisplay: timeout waiting for win assignments to promote
[    5.780719] tegradc 15200000.nvdisplay: tegra_nvdisp_head_enable, failed head enable
[    5.812062] configfs-gadget gadget: Wrong NDP SIGN
[    5.813280] configfs-gadget gadget: Wrong NDP SIGN
[    5.813845] configfs-gadget gadget: Wrong NDP SIGN
[    5.832015] configfs-gadget gadget: Wrong NDP SIGN
[    5.832882] configfs-gadget gadget: Wrong NDP SIGN
[    5.833180] configfs-gadget gadget: Wrong NDP SIGN
[    5.833271] configfs-gadget gadget: Wrong NDP SIGN
[    5.833611] configfs-gadget gadget: Wrong NDP SIGN
[    5.833733] configfs-gadget gadget: Wrong NDP SIGN
[    5.834807] configfs-gadget gadget: Wrong NDP SIGN
[    5.835158] configfs-gadget gadget: Wrong NDP SIGN
[    5.835733] configfs-gadget gadget: Wrong NDP SIGN
[    5.835969] configfs-gadget gadget: Wrong NDP SIGN
[    5.836105] configfs-gadget gadget: Wrong NDP SIGN
[    5.912346] tegradc 15200000.nvdisplay: unblank
[    6.032591] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.032595] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    6.078006] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[    6.078009] iwlwifi 0000:01:00.0: Falling back to user helper
[    6.080708] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.080712] tegradc 15200000.nvdisplay: dc timeout waiting for DC to stop
[    6.132720] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.132724] tegradc 15200000.nvdisplay: timeout waiting for postcomp init state to promote
[    6.183207] iwlwifi 0000:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[    6.183211] iwlwifi 0000:01:00.0: Falling back to user helper
[    6.184696] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    6.184700] tegradc 15200000.nvdisplay: timeout waiting for win assignments to promote
[    6.184703] tegradc 15200000.nvdisplay: tegra_nvdisp_head_enable, failed head enable
I just did a quick search in your device tree but just found sor are not disabled?
Hi Wayne,
Sorry that i upload the old decive-tree.
I attached the new dts.
No matter how I add attachments, they are still old from before, so I put them in the code…
Previously, it was because the forum system could not upload multiple different txt files in one post (all of which would become the oldest one), so you can see that sor/sor1 is enabled. Therefore, I packaged it as a zip file and uploaded it
dsi dts new.zip (35.9 KB)
But the SORs are still enabled even with that zip file attachment…
Hi Wayne,
Sorry i upload the old file…
I directly upload the sor status in system and dmesg
tx2nx@tx2nx-desktop:~$ cat /sys/firmware/devicetree/base/host1x/sor/status
disabled
tx2nx@tx2nx-desktop:~$ cat /sys/firmware/devicetree/base/host1x/sor1/status
disabled
tx2nx@tx2nx-desktop:~$ sudo dmesg
[sudo] password for tx2nx:
[    0.000000] Booting Linux on physical CPU 0x100
[    0.000000] Linux version 4.9.337-tegra (buildbrain@mobile-u64-5499-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Tue Jun 11 16:10:01 PDT 2024
[    0.000000] Boot CPU: AArch64 Processor [411fd073]
[    0.000000] OF: fdt:memory scan node memory@80000000, reg size 80,
[    0.000000] OF: fdt: - 80000000 ,  70000000
[    0.000000] OF: fdt: - f0200000 ,  85600000
[    0.000000] OF: fdt: - 175e00000 ,  200000
[    0.000000] OF: fdt: - 176600000 ,  200000
[    0.000000] OF: fdt: - 177000000 ,  200000
[    0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[    0.000000] bootconsole [uart8250] enabled
[    0.000000] Found tegra_fbmem: 00800000@96085000
[    0.000000] Found lut_mem: 00002008@96081000
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] On node 0 totalpages: 1004541
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 521725 pages, LIFO batch:31
[    0.000000]   Normal zone: 7624 pages used for memmap
[    0.000000]   Normal zone: 482816 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57816 r8192 d32296 u98304
[    0.000000] pcpu-alloc: s57816 r8192 d32296 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: enabling workaround for Spectre-BHB
[    0.000000] CPU features: enabling workaround for ARM erratum 1742098
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 988725
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2  video=tegrafb earlycon=uart8250,mmio32,0x3100000 nvdumper_reserved=0x1772e0000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0x96085000 lut_mem=0x2008@0x96081000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x175840000 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 isolcpus=1-2
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 163840 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29624(90%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Memory: 3147688K/4018164K available (15486K kernel code, 2982K rwdata, 6716K rodata, 8640K init, 614K bss, 116812K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0x        (ptrval) - 0x        (ptrval)   ( 15488 KB)
[    0.000000]     .rodata : 0x        (ptrval) - 0x        (ptrval)   (  6784 KB)
[    0.000000]       .init : 0x        (ptrval) - 0x        (ptrval)   (  8640 KB)
[    0.000000]       .data : 0x        (ptrval) - 0x        (ptrval)   (  2983 KB)
[    0.000000]        .bss : 0x        (ptrval) - 0x        (ptrval)   (   615 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf03dc8000   (    61 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc0f7200000   (  3954 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.000939] Console: colour dummy device 80x25
[    0.000944] console [tty0] enabled
[    0.000947] bootconsole [uart8250] disabled
[    0.000955] kmemleak: Kernel memory leak detector disabled
[    0.000965] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.000972] pid_max: default: 32768 minimum: 301
[    0.001300] Security Framework initialized
[    0.001468] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001472] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002053] ftrace: allocating 47298 entries in 185 pages
[    0.132186] sched-energy: Sched-energy-costs installed from DT
[    0.140547] ASID allocator initialised with 65536 entries
[    0.164722] tegra-id: chipid=21817.
[    0.164728] tegra-id: opt_subrevision=1.
[    0.164749] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[    0.164757] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/lanai/kernel-dts/tegra186-p3636-0001-p3509-0000-a01.dts
[    0.164762] DTB Build time: <unknown>
[    0.214630] CPU1: Booted secondary processor [4e0f0030]
[    0.246020] CPU2: Booted secondary processor [4e0f0030]
[    0.277018] CPU3: Booted secondary processor [411fd073]
[    0.308979] CPU4: Booted secondary processor [411fd073]
[    0.340973] CPU5: Booted secondary processor [411fd073]
[    0.341026] Brought up 6 CPUs
[    0.341030] SMP: Total of 6 processors activated.
[    0.341035] CPU features: detected feature: 32-bit EL0 Support
[    0.342563] CPU: All CPU(s) started at EL2
[    0.342641] alternatives: patching kernel code
[    0.344976] devtmpfs: initialized
[    0.367611] Initilizing CustomIPI irq domain
[    0.367752] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.367760] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.376676] pinctrl core: initialized pinctrl subsystem
[    0.376918] OS set in device tree is not L4T.
[    0.377105] regulator-dummy: no parameters
[    0.377245] Initializing plugin-manager
[    0.377302] Plugin module not found
[    0.377336] Plugin-manager status disabled
[    0.378532] NET: Registered protocol family 16
[    0.379465] pstore: using zlib compression
[    0.379478] console [pstore-1] enabled
[    0.379481] pstore: Registered ramoops as persistent store backend
[    0.379484] ramoops: attached 0x200000@0x175880000, ecc: 0/0
[    0.393031] cpuidle: using governor menu
[    0.393899] bpmp: waiting for handshake
[    0.393903] bpmp: handshake completed
[    0.393921] bpmp: synchronizing channels
[    0.393928] bpmp: channels synchronized
[    0.393932] bpmp: mail init ok
[    0.395328] arm-smmu 12000000.iommu: probing hardware configuration...
[    0.395333] arm-smmu 12000000.iommu: SMMUv2 with:
[    0.395337] arm-smmu 12000000.iommu: 	stage 1 translation
[    0.395340] arm-smmu 12000000.iommu: 	stage 2 translation
[    0.395343] arm-smmu 12000000.iommu: 	nested translation
[    0.395349] arm-smmu 12000000.iommu: 	stream matching with 128 register groups, mask 0x7f80
[    0.395354] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.395358] arm-smmu 12000000.iommu: 	64 context banks (0 stage-2 only)
[    0.395362] arm-smmu 12000000.iommu: 	Stage-1: 39-bit VA -> 48-bit IPA
[    0.395366] arm-smmu 12000000.iommu: 	Stage-2: 39-bit IPA -> 48-bit PA
[    0.397148] vdso: 2 pages (1 code @         (ptrval), 1 data @         (ptrval))
[    0.397161] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.400452] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.401384] Registering BPMP clocks...
[    0.401451] tegra_bpmp_clk_init: clock init ok (638 clks)
[    0.401928] Serial: AMBA PL011 UART driver
[    0.402826] tegra_powergate_init: DONE
[    0.402833] DTS File Name: /home/greetrix/nvidia/nvidia_sdk/JetPack_4.6.5_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/source/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t18x/lanai/kernel-dts/tegra186-p3636-0001-p3509-0000-a01.dts
[    0.402838] DTB Build time: <unknown>
[    0.404073] Tegra reboot handler registered.
[    0.405204] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.405262] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.405275] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
[    0.405277] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
[    0.405280] tegra-pmc: ### PMC reset status reg: 0x0
[    0.405427] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.405436] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.405699] iommu: Adding device 3460000.sdhci to group 0
[    0.406822] iommu: Adding device 3160000.i2c to group 1
[    0.407205] iommu: Adding device c240000.i2c to group 2
[    0.407490] iommu: Adding device 3180000.i2c to group 3
[    0.407759] iommu: Adding device 3190000.i2c to group 4
[    0.408121] iommu: Adding device 31b0000.i2c to group 5
[    0.408416] iommu: Adding device 31c0000.i2c to group 6
[    0.408692] iommu: Adding device c250000.i2c to group 7
[    0.408970] iommu: Adding device 31e0000.i2c to group 8
[    0.410410] iommu: Adding device 3210000.spi to group 9
[    0.410688] iommu: Adding device c260000.spi to group 10
[    0.411323] iommu: Adding device 3100000.serial to group 11
[    0.411611] iommu: Adding device 3110000.serial to group 12
[    0.411901] iommu: Adding device 3130000.serial to group 13
[    0.413058] iommu: Adding device 2490000.ether_qos to group 14
[    0.413070] arm-smmu: forcing sodev map for 2490000.ether_qos
[    0.413884] iommu: Adding device b000000.rtcpu to group 15
[    0.415576] iommu: Adding device 13e10000.host1x to group 16
[    0.415869] iommu: Adding device 13e10000.host1x:ctx0 to group 17
[    0.416147] iommu: Adding device 13e10000.host1x:ctx1 to group 18
[    0.416416] iommu: Adding device 13e10000.host1x:ctx2 to group 19
[    0.416694] iommu: Adding device 13e10000.host1x:ctx3 to group 20
[    0.417013] iommu: Adding device 13e10000.host1x:ctx4 to group 21
[    0.417296] iommu: Adding device 13e10000.host1x:ctx5 to group 22
[    0.417572] iommu: Adding device 13e10000.host1x:ctx6 to group 23
[    0.417856] iommu: Adding device 13e10000.host1x:ctx7 to group 24
[    0.418267] iommu: Adding device 150c0000.nvcsi to group 25
[    0.418817] iommu: Adding device 15700000.vi to group 26
[    0.419117] iommu: Adding device 15600000.isp to group 27
[    0.419323] iommu: Adding device 15200000.dc_common to group 28
[    0.419366] platform 15200000.dc_common: OF IOVA linear map 0x96085000 size (0x800000)
[    0.419402] platform 15200000.dc_common: OF IOVA linear map 0x96081000 size (0x2008)
[    0.419857] iommu: Adding device 15200000.nvdisplay to group 29
[    0.420291] iommu: Adding device 15340000.vic to group 30
[    0.420483] iommu: Adding device 154c0000.nvenc to group 31
[    0.420676] iommu: Adding device 15480000.nvdec to group 32
[    0.420969] iommu: Adding device 15380000.nvjpg to group 33
[    0.421190] iommu: Adding device 15500000.tsec to group 34
[    0.421389] iommu: Adding device 15100000.tsecb to group 35
[    0.421585] iommu: Adding device 15810000.se to group 36
[    0.421778] iommu: Adding device 15820000.se to group 37
[    0.421960] iommu: Adding device 15830000.se to group 38
[    0.422143] iommu: Adding device 15840000.se to group 39
[    0.422889] iommu: Adding device smmu_test to group 40
[    0.423456] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c10000
[    0.423467] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c20000
[    0.423477] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c30000
[    0.423489] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c40000
[    0.423499] mc: mapped MMIO address: 0x        (ptrval) -> 0x2c50000
[    0.423507] nv-tegra-mc 2c10000.mc: No mssnvlink node
[    0.423516] mc-err: mcerr ops are set to t18x
[    0.423651] dram-ecc: DRAM ECC disabled-MC_ECC_CONTROL:0x0000000c
[    0.424340] iommu: Adding device 3530000.xhci to group 41
[    0.424352] arm-smmu: forcing sodev map for 3530000.xhci
[    0.424747] iommu: Adding device 3550000.xudc to group 42
[    0.424758] arm-smmu: forcing sodev map for 3550000.xudc
[    0.425285] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[    0.425292] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    0.425296] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    0.425883] iommu: Adding device 17000000.gp10b to group 43
[    0.426786] tegra-reset 5000000.clock: registered 193 resets.
[    0.428602] iommu: Adding device d000000.bpmp to group 44
[    0.428794] bpmp: ping status is 0
[    0.428868] bpmp d000000.bpmp: firmware tag is 91572a54614f84d0fd0c270beec2c56f
[    0.430431] bpmp d000000.bpmp: probe ok
[    0.432900] iommu: Adding device 2600000.dma to group 45
[    0.433741] GPIO line 424 (camera-control-output-low) hogged as output/low
[    0.433772] GPIO line 427 (camera-control-output-low) hogged as output/low
[    0.433816] GPIO line 408 (w-disable1) hogged as output/high
[    0.433852] GPIO line 410 (w-disable2) hogged as output/high
[    0.434009] gpiochip_setup_dev: registered GPIOs 320 to 511 on device: gpiochip0 (tegra-gpio)
[    0.437931] gpiochip_setup_dev: registered GPIOs 256 to 319 on device: gpiochip1 (tegra-gpio-aon)
[    0.439478] iommu: Adding device 10003000.pcie-controller to group 46
[    0.439493] arm-smmu: forcing sodev map for 10003000.pcie-controller
[    0.439788] iommu: Adding device sound to group 47
[    0.440095] iommu: Adding device 3510000.hda to group 48
[    0.446601] iommu: Adding device c1a0000.aon to group 49
[    0.447120] vdd-1v8-ap: 1800 mV
[    0.447311] vdd-ac-bat: 5000 mV
[    0.447507] vdd-3v3-disp-cvb: 3300 mV
[    0.447776] vdd-3v3-cvb: 3300 mV
[    0.447961] vdd-1v8-cvb: 1800 mV
[    0.448151] vdd-fan: 5000 mV
[    0.448334] vdd-hdmi-5v0: 5000 mV
[    0.448514] vdd_sys_en: 1200 mV
[    0.473440] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.475932] eventlib_kernel: keventlib is initialized, test id: 0
[    0.476129] SCSI subsystem initialized
[    0.476228] libata version 3.00 loaded.
[    0.476377] usbcore: registered new interface driver usbfs
[    0.476409] usbcore: registered new interface driver hub
[    0.476434] usbcore: registered new device driver usb
[    0.485515] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[    0.489261] vddio-ddr: at 1125 mV
[    0.493029] avdd_dsi_csi: 1200 mV
[    0.497028] vdd-1v8: 1800 mV
[    0.500541] vdd-3v3-sys: 3300 mV
[    0.501419] spmic-ldo0: at 1800 mV
[    0.502054] spmic-ldo1: at 800 mV
[    0.504546] vddio-3v3: 3300 mV
[    0.505216] vddio-sdmmc1: 1800 <--> 3300 mV at 3300 mV
[    0.508544] vdd-rtc: at 800 mV
[    0.509212] avdd-ts-hv: 1800 <--> 3300 mV at 1800 mV
[    0.512543] spmic-ldo6: at 800 mV
[    0.516541] vdd-pex-1v00: 1000 mV
[    0.517136] dvdd-pex: 1000 mV
[    0.519100] GPIO line 253 (spmic_gpio_input) hogged as input
[    0.519229] GPIO line 254 (spmic_gpio_input) hogged as input
[    0.519386] gpiochip_setup_dev: registered GPIOs 248 to 255 on device: gpiochip2 (max77620-gpio)
[    0.519567] max77620 4-003c: max77620 probe successful
[    0.519924] media: Linux media interface: v0.10
[    0.519953] Linux video capture interface: v2.00
[    0.522195] pps_core: LinuxPPS API ver. 1 registered
[    0.522198] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.522212] PTP clock support registered
[    0.522426] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    0.522613] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    0.522631] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    0.523675] trusty trusty: trusty version: Built: 16:08:32 Jun 11 2024
[    0.523688] trusty trusty: selected api version: 3 (requested 3)
[    0.524397] Advanced Linux Sound Architecture Driver Initialized.
[    0.524760] Bluetooth: Core ver 2.22
[    0.524822] NET: Registered protocol family 31
[    0.524825] Bluetooth: HCI device and connection manager initialized
[    0.524832] Bluetooth: HCI socket layer initialized
[    0.524836] Bluetooth: L2CAP socket layer initialized
[    0.524849] Bluetooth: SCO socket layer initialized
[    0.525418] vdd-sys-bl: 3300 mV
[    0.527086] camchar: rtcpu character device driver loaded
[    0.527621] gpio tegra-gpio wake61 for gpio=92(L:4)
[    0.527690] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:1
[    0.528658] clocksource: Switched to clocksource arch_sys_counter
[    0.551036] VFS: Disk quotas dquot_6.6.0
[    0.551113] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.551367] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.551790] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    0.551899] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    0.551903] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    0.551913] nvmap: nvmap_select_cache_ops() nvmap cache ops set to roc
[    0.551918] nvmap_page_pool_init: Total RAM pages: 975338
[    0.551921] nvmap_page_pool_init: nvmap page pool size: 121917 pages (476 MB)
[    0.551994] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.552443] misc nvmap: created heap vpr base 0x        (ptrval) size (688128KiB)
[    0.554439] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[    0.560025] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[    0.560214] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[    0.560551] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[    0.560656] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.560804] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    0.561017] la/ptsa driver initialized.
[    0.561026] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[    0.561028] pre_t19x_iso_plat_init(): max_iso_bw=23040000KB
[    0.561356] NET: Registered protocol family 2
[    0.561437] IP idents hash table entries: 65536 (order: 7, 524288 bytes)
[    0.580800] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.580955] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.581252] TCP: Hash tables configured (established 32768 bind 32768)
[    0.581302] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.581361] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.581625] NET: Registered protocol family 1
[    0.582000] RPC: Registered named UNIX socket transport module.
[    0.582003] RPC: Registered udp transport module.
[    0.582006] RPC: Registered tcp transport module.
[    0.582008] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.582014] PCI: CLS 0 bytes, default 64
[    0.582131] Trying to unpack rootfs image as initramfs...
[    0.794412] Freeing initrd memory: 7068K
[    0.808875] host1x 13e10000.host1x: initialized
[    0.810124] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    0.812166] audit: initializing netlink subsys (disabled)
[    0.812193] audit: type=2000 audit(0.696:1): initialized
[    0.812588] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.818998] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.819962] ntfs: driver 2.1.32 [Flags: R/W].
[    0.820479] 9p: Installing v9fs 9p2000 file system support
[    0.822569] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    0.822626] io scheduler noop registered
[    0.822839] io scheduler cfq registered (default)
[    0.825639] gic 2a41000.agic-controller: GIC IRQ controller registered
[    0.886868] iommu: Adding device aconnect@2a41000:adsp_audio to group 50
[    0.906910] iommu: Adding device 2993000.adsp to group 51
[    0.907480] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    0.912113] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    0.912985] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[    0.913759] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[    0.914521] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    0.916382] tegra-pcie 10003000.pcie-controller: 2x1, 1x1, 1x1 configuration
[    0.917077] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[    0.917358] tegra-pcie 10003000.pcie-controller: probing port 0, using 2 lanes
[    0.917570] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    0.917670] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[    0.919506] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[    0.919670] tsec 15500000.tsec: initialized
[    0.920530] tsec 15100000.tsecb: initialized
[    0.922670] nvdec 15480000.nvdec: initialized
[    0.926276] falcon 15340000.vic: initialized
[    0.927349] falcon 154c0000.nvenc: initialized
[    0.928340] falcon 15380000.nvjpg: initialized
[    0.930205] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    0.931568] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    0.932955] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    0.934315] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    0.935692] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    0.937075] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    0.938442] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    0.939813] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    0.942244] tegradccommon 15200000.dc_common: host1x channel mapped
[    0.942251] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    0.942286] tegradccommon 15200000.dc_common: dma mapping done
[    0.942931] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/dsi
[    0.943038] tegradc 15200000.nvdisplay: No hpd-gpio in DT
[    0.943080] tegradc 15200000.nvdisplay: DT parsed successfully
[    0.943101] tegradc 15200000.nvdisplay: Display dc.        (ptrval) registered with id=0
[    0.948649] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[    0.948652] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[    0.948655] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[    0.948832] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
[    0.948838] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
[    0.952053] tegradc 15200000.nvdisplay: Force clock continuous mode
[    0.953163] tegradc 15200000.nvdisplay: probed
[    0.954982] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    0.955593] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    0.955613] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    0.955974] kfuse 3830000.kfuse: initialized
[    0.957230] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[    0.957342] tegra-pcie 10003000.pcie-controller: PCI host bridge to bus 0000:00
[    0.957348] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.957352] pci_bus 0000:00: root bus resource [mem 0x40100000-0x47ffffff]
[    0.957357] pci_bus 0000:00: root bus resource [mem 0x48000000-0x7fffffff pref]
[    0.957364] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.957396] pci 0000:00:01.0: [10de:10e5] type 01 class 0x060400
[    0.957519] pci 0000:00:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.957732] iommu: Adding device 0000:00:01.0 to group 52
[    0.957742] arm-smmu: forcing sodev map for 0000:00:01.0
[    0.957819] pci 0000:00:03.0: [10de:10e6] type 01 class 0x060400
[    0.957931] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.958104] iommu: Adding device 0000:00:03.0 to group 53
[    0.958109] arm-smmu: forcing sodev map for 0000:00:03.0
[    0.958161] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.958175] pci 0000:00:03.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.958333] pci 0000:01:00.0: [1e0f:0001] type 00 class 0x010802
[    0.958412] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[    0.958856] pci 0000:01:00.0: PME# supported from D0 D3hot
[    0.959110] iommu: Adding device 0000:01:00.0 to group 54
[    0.959115] arm-smmu: forcing sodev map for 0000:01:00.0
[    0.961996] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.964115] console [ttyS0] disabled
[    0.964142] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 33, base_baud = 25500000) is a Tegra
[    0.964178] console [ttyS0] enabled
[    0.965374] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 34, base_baud = 0) is a TEGRA_UART
[    0.965548] serial-tegra 3130000.serial: RX in PIO mode
[    0.966112] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 35, base_baud = 0) is a TEGRA_UART
[    0.967001] [drm] Initialized
[    0.968782] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    0.968811] Console: switching to colour frame buffer device 160x50
[    0.968980] pci 0000:02:00.0: [8086:24fd] type 00 class 0x028000
[    0.969071] pci 0000:02:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[    0.969538] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[    0.969838] iommu: Adding device 0000:02:00.0 to group 55
[    0.969846] arm-smmu: forcing sodev map for 0000:02:00.0
[    0.972954] tegradc 15200000.nvdisplay: fb registered
[    0.973384] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[    0.973434] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[    0.975674] brd: module loaded
[    0.978922] loop: module loaded
[    0.978967] tegra_profiler: version: 1.145, samples/io: 49/28
[    0.979042] tegra_profiler: auth: init
[    0.979592] THERMAL EST: found 3 subdevs
[    0.979595] THERMAL EST num_resources: 0
[    0.979600] [THERMAL EST subdev 0]
[    0.979604] [THERMAL EST subdev 1]
[    0.979607] [THERMAL EST subdev 2]
[    0.979616] THERMAL EST: Found 2 profiles, default profile is quiet
[    0.979866] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[    0.979868] THERMAL EST: thz register success.
[    0.979950] THERMAL EST: end of probe, return err: 0
[    0.980536] sd: No Scsi addr parsed to reserve index
[    0.980557] hisi_sas: driver version v1.6
[    0.980810] pci_bus 0000:02: busn_res: [bus 02-ff] end is updated to 02
[    0.980885] pci 0000:00:01.0: BAR 14: assigned [mem 0x40100000-0x401fffff]
[    0.980891] pci 0000:00:03.0: BAR 14: assigned [mem 0x40200000-0x402fffff]
[    0.980898] pci 0000:01:00.0: BAR 0: assigned [mem 0x40100000-0x40103fff 64bit]
[    0.980938] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.980947] pci 0000:00:01.0:   bridge window [mem 0x40100000-0x401fffff]
[    0.980962] pci 0000:02:00.0: BAR 0: assigned [mem 0x40200000-0x40201fff 64bit]
[    0.981008] pci 0000:00:03.0: PCI bridge to [bus 02]
[    0.981016] pci 0000:00:03.0:   bridge window [mem 0x40200000-0x402fffff]
[    0.981660] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[    0.981664] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    0.981672] pcie_pme 0000:00:01.0:pcie001: service driver pcie_pme loaded
[    0.981760] aer 0000:00:01.0:pcie002: service driver aer loaded
[    0.981988] pcieport 0000:00:03.0: Signaling PME through PCIe PME interrupt
[    0.981992] pci 0000:02:00.0: Signaling PME through PCIe PME interrupt
[    0.982000] pcie_pme 0000:00:03.0:pcie001: service driver pcie_pme loaded
[    0.982083] aer 0000:00:03.0:pcie002: service driver aer loaded
[    0.982658] nvme nvme0: pci function 0000:01:00.0
[    0.982946] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    0.986185] tun: Universal TUN/TAP device driver, 1.6
[    0.986188] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    0.986779] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    0.986782] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.986819] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    0.986822] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.986855] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    0.986857] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.986890] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    0.986892] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    1.099020]  nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[    1.108624] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    1.115219] tegradc 15200000.nvdisplay: timeout waiting for postcomp init state to promote
[    1.172623] tegradc 15200000.nvdisplay: dc_poll_register 0x41: timeout
[    1.179199] tegradc 15200000.nvdisplay: timeout waiting for win assignments to promote
[    1.187172] tegradc 15200000.nvdisplay: tegra_nvdisp_head_enable, failed head enable
[    1.228747] eqos 2490000.ether_qos: can't get pllrefe_vcoout clk (-2)
[    1.230714] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[    1.231152] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3b 70 f5
[    1.231175] Using phyrst_lpmode = 1 from DT
[    1.233323] PPP generic driver version 2.4.2
[    1.233440] PPP BSD Compression module registered
[    1.233443] PPP Deflate Compression module registered
[    1.233458] PPP MPPE Compression module registered
[    1.233462] NET: Registered protocol family 24
[    1.233501] usbcore: registered new interface driver r8152
[    1.233530] usbcore: registered new interface driver asix
[    1.233561] usbcore: registered new interface driver ax88179_178a
[    1.233588] usbcore: registered new interface driver cdc_ether
[    1.233614] usbcore: registered new interface driver net1080
[    1.233642] usbcore: registered new interface driver cdc_subset
[    1.233668] usbcore: registered new interface driver zaurus
[    1.233707] usbcore: registered new interface driver cdc_ncm
[    1.233848] VFIO - User Level meta-driver version: 0.3
[    1.234608] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.234618] ehci-pci: EHCI PCI platform driver
[    1.234647] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.234652] ohci-pci: OHCI PCI platform driver
[    1.234677] ohci-platform: OHCI generic platform driver
[    1.238016] tegra-xusb 3530000.xhci: USB2 port 0 has OTG_CAP
[    1.239426] tegra-xusb 3530000.xhci: extcon 0:         (ptrval) id
[    1.239784] usbcore: registered new interface driver uas
[    1.239819] usbcore: registered new interface driver usb-storage
[    1.239879] usbcore: registered new interface driver usbserial
[    1.242034] tegra-xusb 3530000.xhci: Firmware timestamp: 2020-07-06 13:39:28 UTC, Version: 55.18 release
[    1.242119] tegra-xusb 3530000.xhci: xHCI Host Controller
[    1.242136] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 1
[    1.242738] tegra-xudc-new 3550000.xudc: device count: 1
[    1.242865] tegra-xusb 3530000.xhci: hcc params 0x0184fd25 hci version 0x100 quirks 0x00050810
[    1.242894] tegra-xusb 3530000.xhci: irq 64, io mem 0x03530000
[    1.243029] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.243034] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.243038] usb usb1: Product: xHCI Host Controller
[    1.243041] usb usb1: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.243045] usb usb1: SerialNumber: 3530000.xhci
[    1.243378] hub 1-0:1.0: USB hub found
[    1.243407] hub 1-0:1.0: 4 ports detected
[    1.243771] tegra-xudc-new 3550000.xudc: USB charger detection disabled
[    1.243778] tegra-xudc-new 3550000.xudc: vbus state: 1
[    1.243780] tegra-xusb 3530000.xhci: xHCI Host Controller
[    1.243788] tegra-xusb 3530000.xhci: new USB bus registered, assigned bus number 2
[    1.243790] tegra-xudc-new 3550000.xudc: device mode on: 0
[    1.243925] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    1.243929] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.243932] usb usb2: Product: xHCI Host Controller
[    1.243935] usb usb2: Manufacturer: Linux 4.9.337-tegra xhci-hcd
[    1.243938] tegra-xudc-new 3550000.xudc: active: 0 => 1
[    1.243941] usb usb2: SerialNumber: 3530000.xhci
[    1.244244] hub 2-0:1.0: USB hub found
[    1.244310] hub 2-0:1.0: 3 ports detected
[    1.244434] mousedev: PS/2 mouse device common for all mice
[    1.244485] usbcore: registered new interface driver xpad
[    1.244892] Wake76 for irq=199
[    1.244894] Wake77 for irq=199
[    1.244896] Wake78 for irq=199
[    1.244898] Wake79 for irq=199
[    1.244900] Wake80 for irq=199
[    1.244901] Wake81 for irq=199
[    1.244903] Wake82 for irq=199
[    1.244929] tegra-xusb 3530000.xhci: Upgrade port 0 to USB3.0
[    1.244934] tegra-xusb 3530000.xhci: Upgrade port 1 to USB3.0
[    1.368941] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    1.369948] Wake73 for irq=42
[    1.371187] rtc rtc1: alarm rtc device
[    1.371198] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    1.371211] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    1.371354] i2c /dev entries driver
[    1.372855] i2c i2c-2: Added multiplexed i2c bus 9
[    1.373170] i2c i2c-2: Added multiplexed i2c bus 10
[    1.373175] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[    1.373559] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[    1.396857] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    1.396896] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.404508] imx219 9-0010: board setup failed
[    1.408951] imx219: probe of 9-0010 failed with error -121
[    1.409249] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[    1.432450] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[    1.432495] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[    1.440172] imx219 10-0010: board setup failed
[    1.444696] imx219: probe of 10-0010 failed with error -121
[    1.445816] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[    1.450196] parse_throttle_dt_data: Num cap clks = 4
[    1.450201] parse_throttle_dt_data: clk=mcpu type=1
[    1.450204] parse_throttle_dt_data: clk=bcpu type=2
[    1.450210] parse_throttle_dt_data: clk=gpu type=4
[    1.450213] parse_throttle_dt_data: clk=emc type=3
[    1.450910] tegra_throttle_probe: probe successful. #cdevs=4
[    1.451434] FAN dev name: pwm-fan
[    1.451485] FAN:gpio request success.
[    1.451494] FAN: can't find tach_gpio
[    1.451502] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    1.451521] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    1.451730] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    1.451735] pwm_fan_driver pwm-fan: tach period: 1000
[    1.452178] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    1.452182] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[    1.452186] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[    1.452190] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[    1.452193] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    1.452197] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    1.452200] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    1.452204] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    1.452208] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    1.452211] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    1.452775] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    1.453791] device-mapper: uevent: version 1.0.3
[    1.454163] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    1.454393] CPU EMC frequency mapping table: from device tree
[    1.456223] cpufreq: platform driver Initialization: pass
[    1.456837] cpuidle: Initializing cpuidle driver init for Denver cluster
[    1.456955] cpuidle: Initializing cpuidle driver init for A57 cluster
[    1.457752] sdhci: Secure Digital Host Controller Interface driver
[    1.457753] sdhci: Copyright(c) Pierre Ossman
[    1.457755] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.458723] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    1.460268] CMDQ: cmdq_platfm_init successful
[    1.461126] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[    1.461141] CQE: CMD_TIMING bit set for R1B DCMD
[    1.470256] tegra-se-nvhost 15810000.se: initialized
[    1.471302] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    1.471759] tegra-se-nvhost 15820000.se: initialized
[    1.472709] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    1.473154] tegra-se-nvhost 15830000.se: initialized
[    1.473950] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    1.474387] tegra-se-nvhost 15840000.se: initialized
[    1.475266] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    1.475937] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    1.476052] hidraw: raw HID events driver (C) Jiri Kosina
[    1.477018] usbcore: registered new interface driver usbhid
[    1.477020] usbhid: USB HID core driver
[    1.479665] ashmem: initialized
[    1.481843] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[    1.483472] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xbfef0000-0xbfefdb7f size=56192
[    1.483674] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[    1.483794] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[    1.483860] tegra186-cam-rtcpu b000000.rtcpu: no priority specified, using 99 as default
[    1.484524] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[    1.484596] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[    1.484667] tegra-capture-ivc ivc-b000000.rtcpu:ivccontrol@52c0: no priority specified, using 99 as default
[    1.484722] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[    1.484770] tegra-capture-ivc ivc-b000000.rtcpu:ivccapture@72c0: no priority specified, using 99 as default
[    1.484814] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[    1.484912] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x8192]=0x9180-0xb200 TX[1x8192]=0xb200-0xd280
[    1.485194] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (48)
[    1.485197] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[    1.485690] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=5 sha1=bf12e2c549579b8fe7e0596d313688814d0c34ea
[    1.487268] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    1.487660] tegra186-aondbg aondbg: aondbg driver probe() OK
[    1.488045] register_ari_mca_banks: Registered MCA ROC:IOB
[    1.488345] register_ari_mca_banks: Registered MCA ROC:CCE
[    1.488657] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[    1.489124] tegra18-bridge 2390000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489127] tegra18-bridge 2390000.axi2apb: enabled timeout = 9894000
[    1.489129] tegra18-bridge 2390000.axi2apb: bridge probed OK
[    1.489176] tegra18-bridge 23a0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489179] tegra18-bridge 23a0000.axi2apb: enabled timeout = 9894000
[    1.489181] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[    1.489223] tegra18-bridge 23b0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489225] tegra18-bridge 23b0000.axi2apb: enabled timeout = 9894000
[    1.489227] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[    1.489272] tegra18-bridge 23c0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489274] tegra18-bridge 23c0000.axi2apb: enabled timeout = 9894000
[    1.489276] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[    1.489317] tegra18-bridge 23d0000.axi2apb: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489319] tegra18-bridge 23d0000.axi2apb: enabled timeout = 9894000
[    1.489321] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[    1.489363] tegra18-bridge 2100000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489368] tegra18-bridge 2100000.axip2p: enabled timeout = 9894000
[    1.489370] tegra18-bridge 2100000.axip2p: bridge probed OK
[    1.489409] tegra18-bridge 2110000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489414] tegra18-bridge 2110000.axip2p: enabled timeout = 9894000
[    1.489416] tegra18-bridge 2110000.axip2p: bridge probed OK
[    1.489456] tegra18-bridge 2120000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489461] tegra18-bridge 2120000.axip2p: enabled timeout = 9894000
[    1.489463] tegra18-bridge 2120000.axip2p: bridge probed OK
[    1.489503] tegra18-bridge 2130000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489508] tegra18-bridge 2130000.axip2p: enabled timeout = 9894000
[    1.489510] tegra18-bridge 2130000.axip2p: bridge probed OK
[    1.489549] tegra18-bridge 2140000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489551] tegra18-bridge 2140000.axip2p: enabled timeout = 9894000
[    1.489553] tegra18-bridge 2140000.axip2p: bridge probed OK
[    1.489600] tegra18-bridge 2150000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489606] tegra18-bridge 2150000.axip2p: enabled timeout = 9894000
[    1.489607] tegra18-bridge 2150000.axip2p: bridge probed OK
[    1.489651] tegra18-bridge 2160000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489657] tegra18-bridge 2160000.axip2p: enabled timeout = 9894000
[    1.489658] tegra18-bridge 2160000.axip2p: bridge probed OK
[    1.489698] tegra18-bridge 2170000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489704] tegra18-bridge 2170000.axip2p: enabled timeout = 9894000
[    1.489706] tegra18-bridge 2170000.axip2p: bridge probed OK
[    1.489747] tegra18-bridge 2180000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489753] tegra18-bridge 2180000.axip2p: enabled timeout = 9894000
[    1.489755] tegra18-bridge 2180000.axip2p: bridge probed OK
[    1.489795] tegra18-bridge 2190000.axip2p: axi_cbb clk rate = 102 MHZ, timeout = 97000 useconds
[    1.489799] tegra18-bridge 2190000.axip2p: enabled timeout = 9894000
[    1.489801] tegra18-bridge 2190000.axip2p: bridge probed OK
[    1.489853] **** A57 ECC: Enabled
[    1.489855] tegra18_a57_serr_init: on CPU 5 a A57 Core
[    1.489912] tegra18x_actmon d230000.actmon: in actmon_register()...
[    1.490266] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[    1.490630] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[    1.490740] denver_knobs_init:MTS_VERSION:66340021
[    1.493097] nvpmodel: initialized successfully
[    1.493838] trusty-virtio trusty:virtio: initializing
[    1.493935] trusty_ipc virtio0: vring0: va(pa)          (ptrval)(0) qsz 32 notifyid 1
[    1.493943] trusty_ipc virtio0: vring1: va(pa)          (ptrval)(0) qsz 32 notifyid 2
[    1.494006] trusty-virtio trusty:virtio: initializing done
[    1.494087] trusty_ipc virtio0: is online
[    1.495497] usbcore: registered new interface driver snd-usb-audio
[    1.504651] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    1.508842] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[    1.509143] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    1.509330] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    1.512575] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[    1.512578] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.512581] usb 1-2: Product: USB2.1 Hub
[    1.512583] usb 1-2: Manufacturer: GenesysLogic
[    1.513283] hub 1-2:1.0: USB hub found
[    1.513562] hub 1-2:1.0: 2 ports detected
[    1.550298] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    1.565612] mmc0: periodic cache flush enabled
[    1.565620] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    1.566822] OPE platform probe
[    1.566892] OPE platform probe successful
[    1.569292] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[    1.569448] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[    1.569596] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[    1.569788] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[    1.574604]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33
[    1.618521] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    1.618616] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    1.618684] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    1.618752] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    1.618817] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    1.618885] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    1.618949] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    1.619015] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    1.619084] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    1.619151] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    1.619226] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    1.619292] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    1.619358] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    1.619424] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    1.619499] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    1.619565] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    1.619633] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    1.619697] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    1.619763] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    1.619830] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    1.629062] usb 2-2: new SuperSpeed USB device number 2 using tegra-xusb
[    1.639092] u32 classifier
[    1.639095]     Actions configured
[    1.639154] Initializing XFRM netlink socket
[    1.639712] NET: Registered protocol family 10
[    1.640308] NET: Registered protocol family 17
[    1.640317] NET: Registered protocol family 15
[    1.640379] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.640416] Bluetooth: RFCOMM socket layer initialized
[    1.640425] Bluetooth: RFCOMM ver 1.11
[    1.640429] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.640433] Bluetooth: HIDP socket layer initialized
[    1.640448] 9pnet: Installing 9P2000 support
[    1.640480] Key type dns_resolver registered
[    1.640799] Registered cp15_barrier emulation handler
[    1.640812] Registered setend emulation handler
[    1.641648] registered taskstats version 1
[    1.644164] isp 15600000.isp: initialized
[    1.647182] nvcsi 150c0000.nvcsi: initialized
[    1.648046] tegra-vi4 15700000.vi: using default number of vi channels,15
[    1.650522] Wake83 for irq=51
[    1.650617] gpio tegra-gpio-aon wake29 for gpio=56(FF:0)
[    1.650783] input: gpio-keys as /devices/gpio-keys/input/input2
[    1.651653] usb 2-2: New USB device found, idVendor=05e3, idProduct=0620
[    1.651657] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.651660] usb 2-2: Product: USB3.2 Hub
[    1.651663] usb 2-2: Manufacturer: GenesysLogic
[    1.652015] tegra-vi4 15700000.vi: initialized
[    1.652914] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--2 bound
[    1.653001] tegra-vi4 15700000.vi: subdev 150c0000.nvcsi--1 bound
[    1.654338] hub 2-2:1.0: USB hub found
[    1.655012] hub 2-2:1.0: 2 ports detected
[    1.656635] usb 1-2: usb_suspend_both: status 0
[    1.681268] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:00:09 UTC (946688409)
[    1.682096] mmcblk mmc0:0001: Card claimed for testing.
[    1.699405] bpmp: mounted debugfs mirror
[    1.700270] bwmgr: missing cdev-type property
[    1.704106] ALSA device list:
[    1.704110]   #0: tegra-hda at 0x3518000 irq 377
[    1.704112]   #1: tegra-snd-t186ref-mobile-rt565x
[    1.706537] Freeing unused kernel memory: 8640K
[    1.728036] Root device found: mmcblk0p1
[    1.729157] Found dev node: /dev/mmcblk0p1
[    1.740780] usb usb1: usb_suspend_both: status 0
[    1.748008] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[    1.749815] Rootfs mounted over mmcblk0p1
[    1.774054] Switching from initrd to actual rootfs
[    1.816631] usb 2-2: usb_suspend_both: status 0
[    1.816740] usb usb2: usb_suspend_both: status 0
[    1.857647] systemd[1]: System time before build time, advancing clock.
[    1.874637] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.883411] cgroup: cgroup2: unknown option "nsdelegate"
[    1.894879] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    1.895625] systemd[1]: Detected architecture arm64.
[    1.914195] systemd[1]: Set hostname to <tx2nx-desktop>.
[    1.997710] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    1.997719] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.054765] systemd[1]: /lib/systemd/system/rc-local.service:24: Support for option SysVStartPriority= has been removed and it is ignored
[    2.112323] random: systemd: uninitialized urandom read (16 bytes read)
[    2.113786] systemd[1]: Created slice User and Session Slice.
[    2.114009] random: systemd: uninitialized urandom read (16 bytes read)
[    2.114937] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.114988] random: systemd: uninitialized urandom read (16 bytes read)
[    2.115662] systemd[1]: Created slice System Slice.
[    2.115834] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    2.175225] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[    2.381822] systemd-journald[2143]: Received request to flush runtime journal from PID 1
[    2.974609] Intel(R) Wireless WiFi driver for Linux
[    2.974613] Copyright(c) 2003- 2015 Intel Corporation
[    2.974957] iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
[    2.980099] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[    2.990525] iwlwifi 0000:02:00.0: Falling back to user helper
[    3.019572] using random self ethernet address
[    3.031445] using random host ethernet address
[    3.112706] random: systemd: uninitialized urandom read (16 bytes read)
[    3.119802] random: systemd-journal: uninitialized urandom read (16 bytes read)
[    3.131023] random: systemd: uninitialized urandom read (16 bytes read)
[    3.327206] bcpu-throttle-alert cooling device registered.
[    3.328260] mcpu-throttle-alert cooling device registered.
[    3.329404] gpu-throttle-alert cooling device registered.
[    3.422947] random: crng init done
[    3.430709] random: 182 urandom warning(s) missed due to ratelimiting
[    3.746453] Mass Storage Function, version: 2009/09/11
[    3.746458] LUN: removable file: (no medium)
[    3.757144] using random self ethernet address
[    3.761775] using random host ethernet address
[    3.788216] rndis0: HOST MAC 7a:fe:f9:f1:7d:ec
[    3.788476] rndis0: MAC 7a:fe:f9:f1:7d:ed
[    3.793426] usb0: HOST MAC 7a:fe:f9:f1:7d:ee
[    3.793691] usb0: MAC 7a:fe:f9:f1:7d:ef
[    3.793789] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[    3.804095] l4tbr0: port 1(rndis0) entered blocking state
[    3.804100] l4tbr0: port 1(rndis0) entered disabled state
[    3.806888] device rndis0 entered promiscuous mode
[    3.814159] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[    3.822570] l4tbr0: port 2(usb0) entered blocking state
[    3.822575] l4tbr0: port 2(usb0) entered disabled state
[    3.825345] device usb0 entered promiscuous mode
[    3.842536] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[    3.916668] tegra-xusb 3530000.xhci: entering ELPG
[    3.919415] tegra-xusb 3530000.xhci: entering ELPG done
[    4.282592] zram: Added device: zram0
[    4.297289] zram: Added device: zram1
[    4.301475] zram: Added device: zram2
[    4.305014] zram: Added device: zram3
[    4.307949] zram: Added device: zram4
[    4.310515] zram: Added device: zram5
[    4.377176] zram0: detected capacity change from 0 to 334258176
[    4.439658] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.453185] Adding 326420k swap on /dev/zram0.  Priority:5 extents:1 across:326420k SS
[    4.465560] zram1: detected capacity change from 0 to 334258176
[    4.485068] Adding 326420k swap on /dev/zram1.  Priority:5 extents:1 across:326420k SS
[    4.492390] zram2: detected capacity change from 0 to 334258176
[    4.526841] Adding 326420k swap on /dev/zram2.  Priority:5 extents:1 across:326420k SS
[    4.539584] zram3: detected capacity change from 0 to 334258176
[    4.577585] Adding 326420k swap on /dev/zram3.  Priority:5 extents:1 across:326420k SS
[    4.589733] zram4: detected capacity change from 0 to 334258176
[    4.631098] Adding 326420k swap on /dev/zram4.  Priority:5 extents:1 across:326420k SS
[    4.636916] zram5: detected capacity change from 0 to 334258176
[    4.658312] Adding 326420k swap on /dev/zram5.  Priority:5 extents:1 across:326420k SS
[    4.753823] gpio tegra-gpio-aon wake51 for gpio=47(AA:7)
[    4.757413] net eth0: get_configure_l3v4_filter -->
[    4.757958] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    5.233740] Bridge firewalling registered
[    5.258581] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    5.477359] Netfilter messages via NETLINK v0.30.
[    5.480526] ctnetlink v0.93: registering with nfnetlink.
[    5.623101] IPv6: ADDRCONF(NETDEV_UP): docker0: link is not ready
[    6.093346] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[    6.103924] iwlwifi 0000:02:00.0: Falling back to user helper
[    6.195997] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[    6.205378] iwlwifi 0000:02:00.0: Falling back to user helper
[    6.209912] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[    6.209915] iwlwifi 0000:02:00.0: Falling back to user helper
[    6.227586] iwlwifi 0000:02:00.0: loaded firmware version 22.391740.0 op_mode iwlmvm
[    6.289703] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
[    6.291838] iwlwifi 0000:02:00.0: L1 Enabled - LTR Enabled
[    6.292602] iwlwifi 0000:02:00.0: L1 Enabled - LTR Enabled
[    6.413476] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    6.414605] thermal thermal_zone6: failed to read out thermal zone (-5)
[    6.421392] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type iwlwifi_1
[    6.491825] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.494139] iwlwifi 0000:02:00.0: L1 Enabled - LTR Enabled
[    6.494430] iwlwifi 0000:02:00.0: L1 Enabled - LTR Enabled
[    6.612755] iwlwifi 0000:02:00.0: L1 Enabled - LTR Enabled
[    6.613159] iwlwifi 0000:02:00.0: L1 Enabled - LTR Enabled
[    6.673355] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    6.757183] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   10.084947] wlan0: authenticate with 24:cf:24:ab:48:b1
[   10.094242] wlan0: send auth to 24:cf:24:ab:48:b1 (try 1/3)
[   10.130161] wlan0: authenticated
[   10.132694] wlan0: associate with 24:cf:24:ab:48:b1 (try 1/3)
[   10.148163] wlan0: RX AssocResp from 24:cf:24:ab:48:b1 (capab=0x31 status=0 aid=3)
[   10.152227] wlan0: associated
[   11.412031] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   31.821175] vdd-3v3-disp-cvb: disabling
[   31.821189] vdd-3v3-cvb: disabling
[   31.821199] vdd-1v8-cvb: disabling
[   31.821210] vdd-hdmi-5v0: disabling
[   31.821219] vdd_sys_en: disabling
[   31.821243] spmic-ldo1: disabling
[   31.821461] vddio-sdmmc1: disabling
[   31.821628] vdd-sys-bl: disabling
[   36.086121] tegra-i2c 3160000.i2c: no acknowledge from address 0x50
[   36.093128] tegra-i2c c240000.i2c: no acknowledge from address 0x50
[   36.099788] tegra-i2c 3180000.i2c: no acknowledge from address 0x50
tx2nx@tx2nx-desktop:~$ cat /sys/firmware/devicetree/base/host1x/sor1/dp-display/status
disabled
tx2nx@tx2nx-desktop:~$ cat /sys/firmware/devicetree/base/host1x/sor/dp-display/status
disabled
Just to clarify. I am talking about the status of “sor” and “sor1”. I already knew you disabled status of “dp-display” since the beginning.
I also attach the status before…Can you test it?
I don’t know what test you want here.
If SOR is also disabled, there is nothing to control the HPD pin there.
Maybe you could configure the pinmux and set the HPD to GPIO and make it output high.
Hi Wayne.
We need to use the DSI to display.Due to HPD problem, it stuck DSI. HPD in our PCB is floating. We need to resolve it.
I already provided the answer previously. You could change the pinmux of that HPD pin to GPIO and set that GPIO to always output high.
If you cannot understand what I mean, please just tell.
