Hi administrator! I work MIPI display using for JTX1!
have any find MIPI DSC display code relate some of document?
or anyting please?
Hello, wee:
For chip level information, you can refer to Tegra_X1_TRM_DP07225001_v1.1p.pdf, which can be downloaded from http://developer.download.nvidia.com and that document describes detailed information for TX1 modules.
From software part, you can refer to the driver code from TX1 kernel source code.
br
ChenJian
Hi wee,
Unfortunately MIPI is a closed club like PCIe. There is no way to read an original documentation if you are not a member.
On the other hand it is possible to connect a MPI DSI display to TX1 looking only on a panel datasheet, driver samples, device tree samples and TRM.
Please look at a driver source code and related device tree records of the panel-a-wuxga-8-0. It is useful for many LCDs.
One of the most important issues is initial register sequence and power sequencing. You should follow the datasheet of the LCD or ask a manufacturer.
Best regards,
Alex
It seems DSC is not supported by Tx1
https://devtalk.nvidia.com/default/topic/920663/jetson-tx1-dsc-of-mipi-dsi-/
