hello albinraj.c0519,
there’re two phases you may looking to for issue debug.
from the hardware side,
may I know is it possible to arrange hardware resources for probing the MIPI signaling? it could helps to narrow down the issue by checking whether sensor is actually streaming or not.
is not, you should check the regulator settings or clock source for the sensor modules. -
from the software side,
please refer to Supported Modes and Power Efficiency to configure system as maximum performance mode.
you may also refer to Sensor Pixel Clock session to review yourpix_clk_hzproperty setting.
thanks
