MIPI partial capture issue
Following up on this issue: RAW8 MIPI CSI capture issue
I have since successfully ported the driver to other platforms and changed the behavior of the camera to have a discontinuous clock. Now I’m using this device tree:
mode0 {
	num_lanes = "2";
	pix_clk_hz = "44007840";
	serdes_pix_clk_hz = "44007840";
	csi_pixel_bit_depth = "8";
	tegra_sinterface = "serial_c";
	phy_mode = "DPHY";
	active_w = "640";
	active_h = "480";
	line_length = "1464";
	pixel_t = "y8";
    lane_polarity = "0";
	gain_factor = "10";
	min_gain_val = "0";             /* 0dB */
	max_gain_val = "480";           /* 48dB */
	step_gain_val = "3";            /* 0.3 */
	default_gain = "0";
	framerate_factor = "1000000";
	default_framerate = "60000000";
	min_framerate = "60000000";
	max_framerate = "60000000";
	step_framerate = "1000000";
	min_exp_time = "30";            /* us */
	max_exp_time = "660000";        /* us */
	step_exp_time = "10";
	default_exp_time = "33334";     /* us */
	exposure_factor = "1";
	cil_settletime = "0";
	embedded_metadata_height = "0";
	discontinuous_clk = "yes";
and still using this kernel patch:
--- a/drivers/media/platform/tegra/camera/camera_common.c
+++ b/drivers/media/platform/tegra/camera/camera_common.c
@@ -129,6 +129,11 @@ static const struct camera_common_colorfmt camera_common_color_fmts[] = {
 		V4L2_COLORSPACE_SRGB,
 		V4L2_PIX_FMT_VYUY,
+		MEDIA_BUS_FMT_Y8_1X8,
+		V4L2_COLORSPACE_RAW,
+		V4L2_PIX_FMT_GREY,
 struct camera_common_csi_io_pad_ctx {
@@ -667,7 +672,8 @@ int camera_common_try_fmt(struct v4l2_subdev *sd, struct v4l2_mbus_framefmt *mf)
 verify_code:
 	mf->field = V4L2_FIELD_NONE;
-	mf->colorspace = V4L2_COLORSPACE_SRGB;
+	//mf->colorspace = V4L2_COLORSPACE_SRGB;
 	mf->xfer_func = V4L2_XFER_FUNC_DEFAULT;
 	mf->ycbcr_enc = V4L2_YCBCR_ENC_DEFAULT;
 	mf->quantization = V4L2_QUANTIZATION_DEFAULT;
--- a/drivers/media/platform/tegra/camera/sensor_common.c
+++ b/drivers/media/platform/tegra/camera/sensor_common.c
@@ -267,6 +267,8 @@ static int extract_pixel_format(
 		*format = V4L2_PIX_FMT_UYVY;
 	else if (strncmp(pixel_t, "yuv_vyuy16", size) == 0)
 		*format = V4L2_PIX_FMT_VYUY;
+	else if (strncmp(pixel_t, "grey_y8", size) == 0)
+		*format = V4L2_PIX_FMT_GREY;
 	else {
 		pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
 		return -EINVAL;
--- a/drivers/media/platform/tegra/camera/vi/vi5_formats.h
+++ b/drivers/media/platform/tegra/camera/vi/vi5_formats.h
@@ -82,6 +82,8 @@ static const struct tegra_video_format vi5_video_formats[] = {
 	/* RAW 7: TODO */
 	/* RAW 8 */
+	TEGRA_VIDEO_FORMAT(RAW8, 8, Y8_1X8, 1, 1, T_R8, RAW8, GREY, "Greyscale 8"),
 	TEGRA_VIDEO_FORMAT(RAW8, 8, SRGGB8_1X8, 1, 1, T_R8,
 				RAW8, SRGGB8, "RGRG.. GBGB.."),
 	TEGRA_VIDEO_FORMAT(RAW8, 8, SGRBG8_1X8, 1, 1, T_R8,
I have also used this to get more traces:
sudo modprobe rtcpu_debug
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 3 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
traces.txt (88.2 KB)
But I get only a partial frame from 20 to 70 lines (not always the same). The same camera works on both rpi4 and imx95 platforms. The lines I see in the image so it looks like a desync issue. Is there is an issue with a clock or some other parameter that I’m missing ?
Your trace log cut the most valuable data to know the problem.
Please using below command to save to file.
sudo su
cat /sys/kernel/debug/tracing/trace > trace.txt
Here is the log using the command you specified:
trace.txt (94.1 KB)
NVCSI reports STREAM_VC status=0x8, which decodes to pd_wc_short_err_vc0 — the CSI packet ended before the expected word count was received. VI then reports CHANSEL_FAULT followed by CHANSEL_SHORT_FRAME, so the frame starts but arrives incomplete. This usually points to a short/truncated input frame caused by sensor/deserializer timing or format mismatch (for example width/height/embedded-data configuration), or by packet corruption on the link.
Best next checks
  • Verify sensor/deserializer mode against expected active size / line length / embedded lines.
  • Confirm VC / DT routing is correct for this stream.
  • Compare with a lower MIPI rate or a test pattern to separate format mismatch from signal integrity.
Ok there was a problem with the word count on the camera side.
Now it is fixed and I get a full image. Although for streaming video I have to reduce the blanking by 1 pixel in the camera and the dt so my new mode is :
mode0 {
	num_lanes = "2";
	pix_clk_hz = "43977780";
	serdes_pix_clk_hz = "43977780";
	phy_mode = "DPHY";
	active_w = "640";
	active_h = "480";
	line_length = "1463";
	pixel_t = "y8";
	gain_factor = "10";
	default_gain = "0";
But even this does not fully fix the problem. Now most of the time the video freezes after a few seconds (100 - 500 frames) with no traces in rtcpu or dmesg.
Sometimes though the video does not freeze (tested for a few minutes).
Here is attached a rtcpu log of such a freeze happening. rtcpu-freeze2.log (2.3 MB)
This is on CAM1 port(CSI2), on CAM0(CSI1) there is no such issue.
This freeze could be caused by an incomplete CSI frame: VI reports forced frame end (CSIMUX_FRAME 0x122) and then CHANSEL_SHORT_FRAME. The fix is to debug sensor/SerDes stream integrity and startup timing.
