MIPI video setting problem
I’m sorry for my poor English. :(
I’m using TX2 with LT28.1
I want to capture video from HD-SDI camera. So I make a board that convert HD-SDI to MIPI with Lattice FPGA.
This board is not use I2C, just pre-configured. 1280x720p60, RGB888.
So I modifed drivers\media\i2c\ov5693.c source.
  1. change defined
#define OV5693_DEFAULT_MODE	OV5693_MODE_1280X720_120FPS //OV5693_MODE_2592X1944 //
#define OV5693_DEFAULT_HDR_MODE	OV5693_MODE_2592X1944_HDR
#define OV5693_DEFAULT_WIDTH	1280 //2592 //
#define OV5693_DEFAULT_HEIGHT	720 //1944 //
#define OV5693_DEFAULT_DATAFMT	 MEDIA_BUS_FMT_RGB888_1X24 //MEDIA_BUS_FMT_SBGGR12_1X12 //
#define OV5693_DEFAULT_CLK_FREQ	24000000
  1. ov5693_read_reg(), ov5693_write_reg(), ov5693_write_table() fuctions do nothing.
    Like this.
static inline int ov5693_read_reg(struct camera_common_data *s_data, u16 addr, u8 *val)
	return 0;
  1. In ov5693_read_otp_bank() funtion,
err = ov5693_write_reg(priv->s_data, OV5693_OTP_LOAD_CTRL_ADDR, 0x01);
	if (err)
		return err;
	usleep_range(10000, 11000);
	err = regmap_bulk_read(priv->regmap, addr, buf, size);
	err = 0;	// <<-- Add this line, for normal return.
	if (err)
		return err;
	err = ov5693_write_table(priv,
			mode_table[OV5693_MODE_STOP_STREAM]);
	if (err)
		return err;
In drivers\media\platform\tegra\camera\camera_common.c
static const struct camera_common_colorfmt camera_common_color_fmts[] = {
		MEDIA_BUS_FMT_SRGGB12_1X12,
		V4L2_COLORSPACE_SRGB,
		V4L2_PIX_FMT_SRGGB12,
		MEDIA_BUS_FMT_SRGGB10_1X10,
		V4L2_PIX_FMT_SRGGB10,
		MEDIA_BUS_FMT_SBGGR10_1X10,
		V4L2_PIX_FMT_SBGGR10,
		MEDIA_BUS_FMT_SRGGB8_1X8,
		V4L2_PIX_FMT_SRGGB8,
	 * The below two formats are not supported by VI4,
	 * keep them at the last to ensure they get discarded
		MEDIA_BUS_FMT_XRGGB10P_3X10,
		V4L2_PIX_FMT_XRGGB10P,
		MEDIA_BUS_FMT_XBGGR10P_3X10,
	{	// <<- Add this block
		MEDIA_BUS_FMT_RGB888_1X24,
		V4L2_PIX_FMT_RGB24,
static int extract_pixel_format(
	const char *pixel_t, u32 *format)
	size_t size = strnlen(pixel_t, OF_MAX_STR_LEN);
	if (strncmp(pixel_t, "bayer_bggr10", size) == 0)
		*format = V4L2_PIX_FMT_SBGGR10;
	else if (strncmp(pixel_t, "bayer_rggb10", size) == 0)
		*format = V4L2_PIX_FMT_SRGGB10;
	else if (strncmp(pixel_t, "bayer_bggr12", size) == 0)
		*format = V4L2_PIX_FMT_SBGGR12;
	else if (strncmp(pixel_t, "bayer_rggb12", size) == 0)
		*format = V4L2_PIX_FMT_SRGGB12;
	else if (strncmp(pixel_t, "bayer_wdr_pwl_rggb12", size) == 0)
	else if (strncmp(pixel_t, "bayer_xbggr10p", size) == 0)
		*format = V4L2_PIX_FMT_XBGGR10P;
	else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
		*format = V4L2_PIX_FMT_XRGGB10P;
	else if (strncmp(pixel_t, "rgb888", size) == 0)	// <<-- Add this block
		*format = V4L2_PIX_FMT_RGB24;
	else {
		pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
		return -EINVAL;
	return 0;
And I make hardware\nvidia\platform\t18x\quill\kernel-dts\camera-dummy.dtsi file.
#include "dt-bindings/clock/tegra186-clock.h"
#define CAM0_RST_L	TEGRA_MAIN_GPIO(R, 5)
#define CAM0_PWDN	TEGRA_MAIN_GPIO(R, 0)
	host1x {
		vi@15700000 {
			num-channels = <1>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					e3326_vi_in0: endpoint {
						status = "okay";
						csi-port = <0>;
						bus-width = <2>;
						remote-endpoint = <&e3326_csi_out0>;
		vi_base: vi@15700000 {
			ports {
				vi_port0: port@0 {
					status = "okay";
					vi_in0: endpoint {
						status = "okay";
		nvcsi@150c0000 {
			num-channels = <1>;
			#size-cells = <0>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						e3326_csi_in0: endpoint@0 {
							status = "okay";
							csi-port = <0>;
							bus-width = <2>;
							remote-endpoint = <&e3326_ov5693_out0>;
					port@1 {
						reg = <1>;
						e3326_csi_out0: endpoint@1 {
							status = "okay";
							remote-endpoint = <&e3326_vi_in0>;
		csi_base: nvcsi@150c0000 {
			csi_chan0: channel@0 {
				status = "okay";
				ports {
					csi_chan0_port0: port@0 {
						status = "okay";
							status = "okay";
					csi_chan0_port1: port@1 {
						status = "okay";
							status = "okay";
	i2c@3180000 {
		ov5693_c@36 {
			compatible = "nvidia,ov5693";
			/* I2C device address */
			reg = <0x36>;
			/* V4L2 device node location */
			devnode = "video0";
			/* Physical dimensions of sensor */
			physical_w = "3.674";
			physical_h = "2.738";
			/* Define any required hw resources needed by driver */
			/* ie. clocks, io pins, power sources */
			avdd-reg = "vana";
			iovdd-reg = "vif";
			/* Sensor output flip settings */
			vertical-flip = "true";
			/* mclk-index indicates the index of the */
			/* mclk-name with in the clock-names array */
			clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>,
					 <&tegra_car TEGRA186_CLK_PLLP_OUT0>;
			clock-names = "extperiph1", "pllp_grtba";
			mclk = "extperiph1";
			clock-frequency = <24000000>;
			reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
			pwdn-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
			vana-supply = <&en_vdd_cam_hv_2v8>;
			vif-supply = <&en_vdd_cam>;
			* A modeX node is required to support v4l2 driver
			* implementation with NVIDIA camera software stack
			* mclk_khz = "";
			* Standard MIPI driving clock, typically 24MHz
			* num_lanes = "";
			* Number of lane channels sensor is programmed to output
			* tegra_sinterface = "";
			* The base tegra serial interface lanes are connected to
			* discontinuous_clk = "";
			* The sensor is programmed to use a discontinuous clock on MIPI lanes
			* dpcm_enable = "true";
			* The sensor is programmed to use a DPCM modes
			* cil_settletime = "";
			* MIPI lane settle time value.
			* A "0" value attempts to autocalibrate based on mclk_multiplier
			* active_w = "";
			* Pixel active region width
			* active_h = "";
			* Pixel active region height
			* pixel_t = "";
			* The sensor readout pixel pattern
			* readout_orientation = "0";
			* Based on camera module orientation.
			* Only change readout_orientation if you specifically
			* Program a different readout order for this mode
			* line_length = "";
			* Pixel line length (width) for sensor mode.
			* This is used to calibrate features in our camera stack.
			* mclk_multiplier = "";
			* Multiplier to MCLK to help time hardware capture sequence
			* TODO: Assign to PLL_Multiplier as well until fixed in core
			* pix_clk_hz = "";
			* Sensor pixel clock used for calculations like exposure and framerate
			* inherent_gain = "";
			* Gain obtained inherently from mode (ie. pixel binning)
			* min_gain_val = ""; (floor to 6 decimal places)
			* max_gain_val = ""; (floor to 6 decimal places)
			* Gain limits for mode
			* min_exp_time = ""; (ceil to integer)
			* max_exp_time = ""; (ceil to integer)
			* Exposure Time limits for mode (us)
			* min_hdr_ratio = "";
			* max_hdr_ratio = "";
			* HDR Ratio limits for mode
			* min_framerate = "";
			* max_framerate = "";
			* Framerate limits for mode (fps)
			mode0 { // OV5693_MODE_2592X1944
				mclk_khz = "24000";
				num_lanes = "2";
				tegra_sinterface = "serial_c";
				discontinuous_clk = "no";
				dpcm_enable = "false";
				cil_settletime = "0";
				active_w = "2592";
				active_h = "1944";
				//pixel_t = "bayer_bggr";
				pixel_t = "rgb888";
				readout_orientation = "90";
				line_length = "2688";
				inherent_gain = "1";
				mclk_multiplier = "6.67";
				pix_clk_hz = "160000000";
				min_gain_val = "1.0";
				max_gain_val = "16";
				min_hdr_ratio = "1";
				max_hdr_ratio = "64";
				min_framerate = "1.816577";
				max_framerate = "30";
				min_exp_time = "34";
				max_exp_time = "550385";
			mode1 { //OV5693_MODE_2592X1458
				mclk_khz = "24000";
				num_lanes = "2";
				active_w = "2592";
				active_h = "1458";
				pixel_t = "rgb888";
			mode2 { //OV5693_MODE_1280X720
				mclk_khz = "24000";
				num_lanes = "2";
				active_w = "1280";
				active_h = "720";
				pixel_t = "rgb888";
				line_length = "1752";
				mclk_multiplier = "3.08";
				pix_clk_hz = "74000000";
				min_framerate = "2.787078";
				max_framerate = "120";
				min_exp_time = "22";
				max_exp_time = "358733";
			ports {
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					e3326_ov5693_out0: endpoint {
						csi-port = <0>;
						bus-width = <2>;
						remote-endpoint = <&e3326_csi_in0>;
		e3326_cam0: ov5693_c@36 {
			status = "okay";
	tegra-camera-platform {
		* tpg_max_iso = <>;
		* Max iso bw for 6 streams of tpg
		* streams * nvcsi_freq * PG_bitrate / RG10 * BPP
		* 6 * 102Mhz * 32 bits/ 10 bits * 2 Bps
		* = 3916.8 MBps
		tpg_max_iso = <3916800>;
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <4>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		max_pixel_rate = <160000>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		* The general guideline for naming badge_info contains 3 parts, and is as follows,
		* The first part is the camera_board_id for the module; if the module is in a FFD
		* platform, then use the platform name for this part.
		* The second part contains the position of the module, ex. “rear” or “front”.
		* The third part contains the last 6 characters of a part number which is found
		* in the module's specsheet from the vender.
		modules {
			module0 {
				badge = "e3326_front_P5V27C";
				position = "front";
				orientation = "0";
				drivernode0 {
					/* Declare PCL support driver (classically known as guid)  */
					pcl_id = "v4l2_sensor";
					/* Driver v4l2 device name */
					devname = "ov5693 2-0036";
					/* Declare the device-tree hierarchy to driver instance */
					proc-device-tree = "/proc/device-tree/i2c@3180000/ov5693_c@36";
	tcp: tegra-camera-platform {
		modules {
			cam_module0: module0 {
				status = "okay";
				cam_module0_drivernode0: drivernode0 {
					status = "okay";
	/* set camera gpio direction to output */
	gpio@2200000 {
		camera-control-input {
			status = "disabled";
		camera-control-output-low {
			gpio-hog;
			gpios = <CAM0_RST_L 0 CAM0_PWDN 0>;
			label = "cam0-rst", "cam0-pwdn";
			output-low;
			status = "okay";
		camera-control-output-high {
Then I modified hardware\nvidia\platform\t18x\quill\kernel-dts\tegra186-quill-p3310-a00-00-base.dts
#include <t18x-common-platforms/tegra186-quill-common-p3310-1000-a00.dtsi>
#include <t18x-common-platforms/tegra186-quill-power-tree-p3310-1000-a00-00.dtsi>
//#include <t18x-common-platforms/tegra186-quill-camera-modules.dtsi> // <<-- comment out
#include <t18x-common-modules/tegra186-display-e3320-1000-a00.dtsi>
/* comms dtsi file should be included after gpio dtsi file */
#include <t18x-common-platforms/tegra186-quill-comms.dtsi>
#include <t18x-common-plugin-manager/tegra186-quill-p3310-1000-a00-plugin-manager.dtsi>
#include <t18x-common-modules/tegra186-super-module-e2614-p2597-1000-a00.dtsi>
#include <t18x-common-plugin-manager/tegra186-quill-display-plugin-manager.dtsi>
#include <t18x-common-prod/tegra186-priv-quill-p3310-1000-a00-prod.dtsi>
//#include <t18x-common-plugin-manager/tegra186-quill-camera-plugin-manager.dtsi> // <<-- comment out
#include <camera-dummy.dtsi> // <<-- Add this line
#include <dt-bindings/linux/driver-info.h>
Then, compile & download.
when run below command
v4l2-ctl --device /dev/video0 --stream-mmap --stream-to=frame0.raw --stream-count=1 --verbose
dmesg is
[ 7554.447351] tegra_mipi_cal 3990000.mipical: Mipi cal timeout,val:8861, lanes:100000
[ 7554.455084] tegra_mipi_cal 3990000.mipical: MIPI_CAL_CTRL                  0x04 0x2a000010
[ 7554.463435] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS            0x0c 0x00008861
[ 7554.471864] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS_2          0x10 0x00000000
[ 7554.480239] tegra_mipi_cal 3990000.mipical: CILA_MIPI_CAL_CONFIG           0x18 0x00200000
[ 7554.488602] tegra_mipi_cal 3990000.mipical: CILB_MIPI_CAL_CONFIG           0x1c 0x00000000
[ 7554.496912] tegra_mipi_cal 3990000.mipical: CILC_MIPI_CAL_CONFIG           0x20 0x00000000
[ 7554.505256] tegra_mipi_cal 3990000.mipical: CILD_MIPI_CAL_CONFIG           0x24 0x00000000
[ 7554.513572] tegra_mipi_cal 3990000.mipical: CILE_MIPI_CAL_CONFIG           0x28 0x00000000
[ 7554.521899] tegra_mipi_cal 3990000.mipical: CILF_MIPI_CAL_CONFIG           0x2c 0x00000000
[ 7554.530211] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG           0x3c 0x00000200
[ 7554.538517] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG           0x40 0x00000200
[ 7554.546834] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG           0x44 0x00000200
[ 7554.555133] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG           0x48 0x00000200
[ 7554.563459] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG0             0x5c 0x00000000
[ 7554.571768] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG1             0x60 0x00000000
[ 7554.580071] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG2             0x64 0x00010010
[ 7554.588367] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG_2         0x68 0x00000002
[ 7554.596660] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG_2         0x6c 0x00000002
[ 7554.604939] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG_2         0x74 0x00000002
[ 7554.613223] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG_2         0x78 0x00000002
[ 7555.619391] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 7556.623394] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 7557.627393] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 7558.631405] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 7559.635373] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
Now, what should I do?
I’ve no idea.
Try to trace notify info.
https://devtalk.nvidia.com/default/topic/1025863/jetson-tx2/how-to-grab-pre-configured-csi-video-stream-without-i2c-/3
@DaLT
Thanks for your help.
command:
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw
Here is the trace info.
dmesg:
[  548.479498] tegra_mipi_cal 3990000.mipical: Mipi cal timeout,val:8861, lanes:100000
[  548.489930] tegra_mipi_cal 3990000.mipical: MIPI_CAL_CTRL                  0x04 0x2a000010
[  548.498277] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS            0x0c 0x00008861
[  548.506646] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS_2          0x10 0x00000000
[  548.515095] tegra_mipi_cal 3990000.mipical: CILA_MIPI_CAL_CONFIG           0x18 0x00200000
[  548.523500] tegra_mipi_cal 3990000.mipical: CILB_MIPI_CAL_CONFIG           0x1c 0x00000000
[  548.531845] tegra_mipi_cal 3990000.mipical: CILC_MIPI_CAL_CONFIG           0x20 0x00000000
[  548.540235] tegra_mipi_cal 3990000.mipical: CILD_MIPI_CAL_CONFIG           0x24 0x00000000
[  548.548574] tegra_mipi_cal 3990000.mipical: CILE_MIPI_CAL_CONFIG           0x28 0x00000000
[  548.556933] tegra_mipi_cal 3990000.mipical: CILF_MIPI_CAL_CONFIG           0x2c 0x00000000
[  548.565248] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG           0x3c 0x00000200
[  548.573598] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG           0x40 0x00000200
[  548.581936] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG           0x44 0x00000200
[  548.590245] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG           0x48 0x00000200
[  548.598575] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG0             0x5c 0x00000000
[  548.606885] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG1             0x60 0x00000000
[  548.615194] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG2             0x64 0x00010010
[  548.623520] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG_2         0x68 0x00000002
[  548.631830] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG_2         0x6c 0x00000002
[  548.640129] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG_2         0x74 0x00000002
[  548.648443] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG_2         0x78 0x00000002
[  549.655683] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  550.659837] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  551.663970] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  552.668121] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  553.672207] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
trace:
root@tegra-ubuntu:/home/nvidia# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 38/38   #P:4
#                              _-----=> irqs-off
#                             / _----=> need-resched
#                            | / _---=> hardirq/softirq
#                            || / _--=> preempt-depth
#                            ||| /     delay
#           TASK-PID   CPU#  ||||    TIMESTAMP  FUNCTION
     kworker/4:1-104   [004] ...1   548.019433: rtos_queue_peek_from_isr_failed: tstamp:17423831037 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   548.019446: rtcpu_start: tstamp:17423832094
     kworker/4:1-104   [004] ...1   548.175458: rtos_queue_peek_from_isr_failed: tstamp:17428832103 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   548.331475: rtos_queue_peek_from_isr_failed: tstamp:17433832547 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   548.487489: rtos_queue_peek_from_isr_failed: tstamp:17438833050 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   548.648429: rtos_queue_peek_from_isr_failed: tstamp:17443833469 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   548.803538: rtos_queue_peek_from_isr_failed: tstamp:17448834062 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   548.959552: rtos_queue_peek_from_isr_failed: tstamp:17453834586 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   549.115576: rtos_queue_peek_from_isr_failed: tstamp:17458835081 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   549.271590: rtos_queue_peek_from_isr_failed: tstamp:17463835585 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   549.427613: rtos_queue_peek_from_isr_failed: tstamp:17468836092 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   549.583628: rtos_queue_peek_from_isr_failed: tstamp:17473836596 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   549.791655: rtos_queue_peek_from_isr_failed: tstamp:17478837118 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   549.947677: rtos_queue_peek_from_isr_failed: tstamp:17483837616 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   550.103699: rtos_queue_peek_from_isr_failed: tstamp:17488838118 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   550.259738: rtos_queue_peek_from_isr_failed: tstamp:17493838631 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   550.415743: rtos_queue_peek_from_isr_failed: tstamp:17498839137 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   550.571757: rtos_queue_peek_from_isr_failed: tstamp:17503839652 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   550.727792: rtos_queue_peek_from_isr_failed: tstamp:17508840148 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   550.883798: rtos_queue_peek_from_isr_failed: tstamp:17513840595 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   551.039818: rtos_queue_peek_from_isr_failed: tstamp:17518841098 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   551.195842: rtos_queue_peek_from_isr_failed: tstamp:17523841677 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   551.351856: rtos_queue_peek_from_isr_failed: tstamp:17528842178 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   551.507879: rtos_queue_peek_from_isr_failed: tstamp:17533842616 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   551.663928: rtos_queue_peek_from_isr_failed: tstamp:17538843187 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   551.871936: rtos_queue_peek_from_isr_failed: tstamp:17543843694 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   552.027941: rtos_queue_peek_from_isr_failed: tstamp:17548844200 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   552.183961: rtos_queue_peek_from_isr_failed: tstamp:17553844707 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   552.339968: rtos_queue_peek_from_isr_failed: tstamp:17558845213 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   552.496027: rtos_queue_peek_from_isr_failed: tstamp:17563845634 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   552.652027: rtos_queue_peek_from_isr_failed: tstamp:17568846226 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   552.808046: rtos_queue_peek_from_isr_failed: tstamp:17573846739 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   552.964062: rtos_queue_peek_from_isr_failed: tstamp:17578847252 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   553.120079: rtos_queue_peek_from_isr_failed: tstamp:17583847754 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   553.276114: rtos_queue_peek_from_isr_failed: tstamp:17588848263 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   553.432121: rtos_queue_peek_from_isr_failed: tstamp:17593848765 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   553.588138: rtos_queue_peek_from_isr_failed: tstamp:17598849269 queue:0x0b4a3c58
     kworker/4:1-104   [004] ...1   553.692180: rtos_queue_peek_from_isr_failed: tstamp:17601924636 queue:0x0b4a3c58
How can I know whether MIPI signal set is right?
  1. Did you enable the trace before launch the camera?
  2. Please probe your mipi signal and make sure it’s mipi spec.
  1. no.
    mipi convertor output signal always when powered.
  2. I don’t know which files modify for mipi spec.
  1. I mean: first enable trace, then run the v4l2-ctl ---- command, and then cat trace.
  2. Are you sure that your input mipi signal is correct?
  1. Yes. I ran below sequence.
    enable trace -> run v4l-ctl command -> cat trace
  2. I don’t know that exactly. Actually, the Lattice FPGA field application engineer made mipi converter. Because I don’t have a measuring instrument for mipi signal probing, I can’t verify the mipi signal is right.
@MinSu, you need to make sure your mipi signal is right and mipi compliance.
Thank you for your advice.
I will check it.
Is there a standard way of doing this?
