Hii, I have been using Jetson xavier NX board and i have misplaced one diode from it so that diode is at type B usb port so i need the exact specs of the diode so i can order it.
Hi, do you mean devkit or your custom board? Please provide diode info.
No, it is the dev kit jetson xavier NX
Which diode do you mean? Please provide its info.
The diode is situated at the port where we connect our type-B USB port.
Can you share a photo or the part number of the diode?
The diode D6 in the image is missing. So i need the exact specs of the diode so i can order it and solder it.
