Missing assets for ur5 / ur5e
I am trying to load the assets for the ur5 and ur5e robots into Issac Sim. It fails when I load them via the Isaac Sim Asset browser and via Python in the Script Editor, but I am able to successfully load both the ur10 and ur10e.
The assets seem to be missing from the appropriate AWS S3 bucket or have permissions that keep me from accessing them.
To repro:
In the browser, I navigate to robots → universal robots → ur5e and click on the “ur5e” thumbnail. Isaac Sim hangs and I have to force quit it. I get this error:
2025-06-15 21:43:49 [559,123ms] [Error] [omni.kit.browser.folder.core.models.folder_browser_model] Exception when traverse: https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.5/Isaac/Robots, [Errno 13] Permission denied: '/opt/IsaacSim/exts/isaacsim.asset.browser/cache/isaacsim.asset.browser.cache.json'
When I load using this following code in the Script Editor:
usd_path = assets_root_path + "/Isaac/Robots/UR5/ur5e.usd"
add_reference_to_stage(usd_path=usd_path, prim_path=robot_prim_path)
usd_path = assets_root_path + "/Isaac/Robots/UR5/ur5.usd"
I get these errors:
2025-06-15 21:35:06 [35,954ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- In </World/ur5e>: Could not open asset @https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.5/Isaac/Robots/UR5/ur5e.usd@ for reference introduced by @anon:0x7c4ee0004070:World0.usd@</World/ur5e>. (recomposing stage on stage @anon:0x7c4ee0004070:World0.usd@ <0x7c4ee000b3c0>)
2025-06-15 21:35:51 [81,405ms] [Warning] [omni.usd] Warning: in _ReportErrors at line 2890 of /builds/omniverse/usd-ci/USD/pxr/usd/usd/stage.cpp -- In </World/ur5>: Could not open asset @https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.5/Isaac/Robots/UR5/ur5.usd@ for reference introduced by @anon:0x520b9b80:World3.usd@</World/ur5>. (recomposing stage on stage @anon:0x520b9b80:World3.usd@ <0x7c4d2c0075b0>)
looking at the asset paths in the Isaac Sim Assets browser, it appears that the path should be Robots/UniversalRobots/ur5/ur5.usd. maybe it’s worth a try adding UniversalRobots and see if it fixes the issue loading those assets. ur5e seems to be different pathing than what you have shown in the snippet as well, so can take another pass at it.
also, the white overlay/hanging will go away after a few minutes, i think i had to wait 2 or 3 minutes on the first Isaac Sim lunch. don’t think it should last longer than 5 minutes, though. but i haven’t seen that error you first mentioned, so it may be something else entirely.
Closing this topic as it has been inactive for several months. Summarizing the answer from above, with a check on the paths.
The assets are not missing – the path in the script is wrong. The UR5 and UR5e files live under a UniversalRobots folder, not UR5. The two paths in your script (/Isaac/Robots/UR5/ur5e.usd and /Isaac/Robots/UR5/ur5.usd) do not exist on the server, which is why USD reports “Could not open asset”. The correct paths are:
usd_path = assets_root_path + "/Isaac/Robots/UniversalRobots/ur5/ur5.usd"
usd_path = assets_root_path + "/Isaac/Robots/UniversalRobots/ur5e/ur5e.usd"
I requested both files from the 4.5 asset root (https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/4.5/Isaac/) and they are served (HTTP 200), while the Robots/UR5/... paths return 404. The same UniversalRobots/ur5/ur5.usd and UniversalRobots/ur5e/ur5e.usd paths also resolve for 5.0, 5.1, 6.0, 6.1 and 6.2. The 4.5.0 motion generation tests use the same paths (isaacsim.robot_motion.motion_generation/.../tests/test_motion_policy.py, test_rmpflow_ur5 and test_rmpflow_ur5e). The Isaac Sim 5.1.0 robot assets page lists the same two paths.
About the Asset Browser. In the browser, UR5 and UR5e appear under Robots → UniversalRobots. As noted above, the first launch can show a white overlay for a few minutes while the asset listing loads.
The “Permission denied” line. That message is a separate problem. The Asset Browser writes its listing cache to cache/isaacsim.asset.browser.cache.json inside its own extension folder (isaacsim.asset.browser/isaacsim/asset/browser/model.py). Your install is under /opt/IsaacSim, and if that folder is not writable by the user running Isaac Sim, the write fails. I did not reproduce this one. If it still happens after you fix the paths, make that cache folder writable for your user, or run from an install location you own.
If you still hit a problem, please open a new topic and link back to this one.
