Missing config.py file need for UFF conversion in DeepStream
**• Hardware Platform Xavier AGX
**• DeepStream Version DeepStream 6.2
**• JetPack Version JetPack 5.1
**• TensorRT Version 11.4
I’m doing a UFF conversion of a SSD detector following the instructions in the /opt/nvidia/deepstream/deepstream/sources/objectDetector_SSD. According to the README the conversion process requires a file config.py the no longer exists in the reference directory /usr/src/tensorrt/samples/sampleUffSSD/. The questions is where can I find the config.py. I check the python directory in tensorrt/samples and its not there either. Thank you for you help.
The latest version has been removed. Could you check the open source demo to see if it meets your needs?
https://github.com/NVIDIA-AI-IOT/deepstream_tao_apps
First off thank you for this very helpful link. I was able to put my own config.py together. So now able to convert mobilenetSSD v1 and v2 models to TensorRT models
