Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hello guys,
today I flashed my Drive AGX Orin with the latest DriveOS (6.0.10.0). My plan is to run “sample_camera” with the Sekonix SF3324-100.
So I looked up under the following directory “/usr/local/driveworks”. Usually there should be a folder called “data” and there should be a directory with, e.g. the rig files for the camera.
But as you can see in the picture, there are just two files called “DATA_ROOT” and “RESOURCES”.
Can you please advise me how to prepare everything, so that I can run my cameras with ./sample_camera
Dear @0b.d3,
Please install driveworks-data, driveworks-samples debian on target. you can find them on docker /drive/extra/driveworks . Please file a new topic with logs incase you have any issue with sample_camera.
When i execute this command i get the following error:
root@6.0.10.0-0009-build-linux-sdk:/drive/extra/driveworks# scp -r driveworks-data_5.20.24-360336400_all.deb driveworks-samples_5.20.24~linux6.0.10.0-360336400_arm64.deb orin-conti@192.168.1.1 orin-conti@192.168.1.1: No such file or directory
