I’ve been following https://support.mellanox.com/s/article/howto-configure-sr-iov-for-connect-ib-connectx-4-with-kvm–infiniband-x so I already know about these instructions.
I’m on step 6 where the GUID, port and policy are set.
However the target ‘directory’ that holds the VF configurations is missing:
[root@hostname ~]# ls -l /sys/class/infiniband/mlx5_0/device/sriov
ls: cannot access '/sys/class/infiniband/mlx5_0/device/sriov': No such file or directory
total 0
-r--r--r-- 1 root root 4096 Mar 22 04:10 aer_dev_correctable
-r--r--r-- 1 root root 4096 Mar 22 04:10 aer_dev_fatal
-r--r--r-- 1 root root 4096 Mar 22 04:10 aer_dev_nonfatal
-r--r--r-- 1 root root 4096 Mar 22 04:10 ari_enabled
-rw-r--r-- 1 root root 4096 Mar 22 04:10 broken_parity_status
-r--r--r-- 1 root root 4096 Mar 22 04:09 class
-rw-r--r-- 1 root root 4096 Mar 22 04:09 config
-r--r--r-- 1 root root 4096 Mar 22 04:10 consistent_dma_mask_bits
-r--r--r-- 1 root root 4096 Mar 22 04:09 current_link_speed
-r--r--r-- 1 root root 4096 Mar 22 04:09 current_link_width
-rw-r--r-- 1 root root 4096 Mar 22 04:10 d3cold_allowed
-r--r--r-- 1 root root 4096 Mar 22 04:09 device
-r--r--r-- 1 root root 4096 Mar 22 04:10 dma_mask_bits
lrwxrwxrwx 1 root root 0 Mar 22 04:09 driver -> ../../../../bus/pci/drivers/mlx5_core
-rw-r--r-- 1 root root 4096 Mar 22 04:10 driver_override
-rw-r--r-- 1 root root 4096 Mar 22 04:10 enable
drwxr-xr-x 3 root root 0 Mar 22 04:09 infiniband
drwxr-xr-x 4 root root 0 Mar 22 04:09 infiniband_mad
drwxr-xr-x 3 root root 0 Mar 22 04:09 infiniband_verbs
lrwxrwxrwx 1 root root 0 Mar 22 04:10 iommu -> ../../../virtual/iommu/dmar4
lrwxrwxrwx 1 root root 0 Mar 22 04:10 iommu_group -> ../../../../kernel/iommu_groups/23
-r--r--r-- 1 root root 4096 Mar 22 04:09 irq
drwxr-xr-x 2 root root 0 Mar 22 04:10 link
-r--r--r-- 1 root root 4096 Mar 22 04:10 local_cpulist
-r--r--r-- 1 root root 4096 Mar 22 04:09 local_cpus
-r--r--r-- 1 root root 4096 Mar 22 04:10 max_link_speed
-r--r--r-- 1 root root 4096 Mar 22 04:10 max_link_width
-r--r--r-- 1 root root 4096 Mar 22 04:10 modalias
-rw-r--r-- 1 root root 4096 Mar 22 04:10 msi_bus
drwxr-xr-x 2 root root 0 Mar 22 04:09 msi_irqs
drwxr-xr-x 3 root root 0 Mar 22 04:09 net
-rw-r--r-- 1 root root 4096 Mar 22 04:09 numa_node
-r--r--r-- 1 root root 4096 Mar 22 04:10 pools
drwxr-xr-x 2 root root 0 Mar 22 04:10 power
drwxr-xr-x 3 root root 0 Mar 22 04:09 ptp
--w--w---- 1 root root 4096 Mar 22 04:10 remove
--w------- 1 root root 4096 Mar 22 04:10 rescan
--w------- 1 root root 4096 Mar 22 04:10 reset
-r--r--r-- 1 root root 4096 Mar 22 04:09 resource
-rw------- 1 root root 33554432 Mar 22 04:10 resource0
-rw------- 1 root root 33554432 Mar 22 04:10 resource0_wc
-r--r--r-- 1 root root 4096 Mar 22 04:10 revision
-rw------- 1 root root 1048576 Mar 22 04:10 rom
-rw-r--r-- 1 root root 4096 Mar 22 04:10 sriov_drivers_autoprobe
-rw-r--r-- 1 root root 4096 Mar 22 04:09 sriov_numvfs
-r--r--r-- 1 root root 4096 Mar 22 04:10 sriov_offset
-r--r--r-- 1 root root 4096 Mar 22 04:10 sriov_stride
-r--r--r-- 1 root root 4096 Mar 22 04:10 sriov_totalvfs
-r--r--r-- 1 root root 4096 Mar 22 04:10 sriov_vf_device
lrwxrwxrwx 1 root root 0 Mar 22 04:09 subsystem -> ../../../../bus/pci
-r--r--r-- 1 root root 4096 Mar 22 04:09 subsystem_device
-r--r--r-- 1 root root 4096 Mar 22 04:09 subsystem_vendor
-rw-r--r-- 1 root root 4096 Mar 22 04:09 uevent
-r--r--r-- 1 root root 4096 Mar 22 04:09 vendor
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn0 -> ../0000:18:00.1
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn1 -> ../0000:18:00.2
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn10 -> ../0000:18:01.3
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn11 -> ../0000:18:01.4
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn12 -> ../0000:18:01.5
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn13 -> ../0000:18:01.6
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn14 -> ../0000:18:01.7
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn15 -> ../0000:18:02.0
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn2 -> ../0000:18:00.3
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn3 -> ../0000:18:00.4
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn4 -> ../0000:18:00.5
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn5 -> ../0000:18:00.6
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn6 -> ../0000:18:00.7
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn7 -> ../0000:18:01.0
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn8 -> ../0000:18:01.1
lrwxrwxrwx 1 root root 0 Mar 22 04:10 virtfn9 -> ../0000:18:01.2
-rw------- 1 root root 0 Mar 22 04:10 vpd
We have a subnet manager running elsewhere, but have tried with opensmd running and not running with the same resullt.
The base system is CentOS8:
[root@hostname ~]# uname -a
Linux asn011 4.18.0-240.15.1.el8_3.x86_64 #1 SMP Mon Mar 1 17:16:16 UTC 2021 x86_64 x86_64 x86_64 GNU/Linu
The driver version is:
[root@hostname ~]# rpm -qa | grep mlnx-ofed
mlnx-ofed51-modules-5.1.2.5.8.0.x86_64
We are not going to upgrade the drivers to 5.2.x as we have other systems on CentOS7 and older drivers with working SR-IOV, so we’re just trying to work through the CentOS8 changes first.
