Missing Extensions in Kit App Template 107.0
I recently installed kit‑app‑template version 107.0 and noticed that several skeletal animation-related extensions are not visible in the extension window. Specifically, I cannot find:
  • omni.anim.skeljoint
  • omni.anim.graph.core
  • omni.anim.graph.ui
Could you please clarify if these extensions have been deprecated, restructured, or integrated into other modules in the latest release? Any guidance on how to access the skeletal animation functionalities in 107.0 would be greatly appreciated.
Thank you for your support!
We actually discovered a slight bug with our registry code this morning, so some of the extensions may not be showing up correctly. Can you flush and re-built kit 107 and try again please.
I checked the extensions I wanted after the update. Thank you for your help.
