Missing files with source_sync.sh -k jetson_34.1.1 -t jetson_34.1.1
We are using L4T34.1.1 provided script to download kernel driver and dtb sources . After compare with puiblic_source.tgz, we found some files/folders were missing with using following command:
The missing folders are:
  1. hardware/nvidia/t23x/common/bct
  2. hardware/nvidia/t23x/common/kernel-dts
  3. kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm
without these folders, we can’t build successful , please help fix this, thanks
Please wait for the next JetPack 5.0.2 release. Thanks
Hi ,
Jetpack 5.0.2 was released. I downloaded the kernel driver and dtb sources with command and compare with puiblic_source.tgz. Still missing files and can’t build successful but public_sources.tgz can. Could you help check your git server ? Thanks
source_sync.sh -k jetson_35.1 -t jetson_35.1
There are some issues at server to be resolved, please use the source package instead for now.
On L4T34.1.1 , we use the nvmassflashgen.sh to create emmc image. But L4T35.1 doesn’t have this script , could you tell us how to create the emmc image for L4T35.1 ?
command is :
sudo BOARDID=3668 BOARDSKU=0001 FAB=100 FUSELEVEL=fuselevel_production ./nvmassflashgen.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
The massflash tool has been deprecated and move to initrd flash. Please refer to the initrd flash first.
Hi.
Could you help provide the full command to generate EMMC image? Thanks
May I kown the server issues were resolved or not ? We need to based on kernel git to create porting branch
Please re-arrange the order in the source_sync.sh as below and try again to see if can work.
-k:kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm:nv-tegra.nvidia.com/kernel/nvethernetrm.git:
k:kernel/nvgpu:nv-tegra.nvidia.com/linux-nvgpu.git:
k:kernel/nvidia:nv-tegra.nvidia.com/linux-nvidia.git:
+k:kernel/nvidia/drivers/net/ethernet/nvidia/nvethernet/nvethernetrm:nv-tegra.nvidia.com/kernel/nvethernetrm.git:
The issue was resolved , thanks for the support
