I am currently working with Jetpack 5.1.3 and have encountered an issue related to the Video4Linux2 (V4L2) sub-device callbacks.
In Jetpack 4.6.2, specifically in the file located at /Linux_for_Tegra/source/public/kernel/kernel-5.10/include/media/subdev.h
, I found the g_parm
and s_parm
callbacks defined within the struct v4l2_subdev_video_ops
. These callbacks are used for handling %VIDIOC_G_PARM
and %VIDIOC_S_PARM
ioctl operations, respectively.
However, after upgrading to Jetpack 5.1.3, I noticed that these callback functions are missing from the updated kernel source. This change is impacting our ability to handle video streaming parameters as we did previously.
- Are
g_parm
ands_parm
callbacks still supported in Jetpack 5.1.3?** If so, could you provide guidance on where to find these definitions or the updated mechanisms for handling video parameters in the new version? - If these callbacks have been removed or replaced,** what is the recommended approach for managing video stream parameters in Jetpack 5.1.3?
Any insights or recommendations would be greatly appreciated as they will help us adapt our codebase to the new version of Jetpack.
Thank you!
Best regards,
Anandhu
