Missing GL directory CMake on snow leopard
I am trying to port some code to OSx and it is based on cuda and opengl.
The problem I am having is that the glu.h is not located in a GL directory but directly in /System/Library/Frameworks/OpenGL.framework/Headers
bash-3.2$ ls /System/Library/Frameworks/OpenGL.framework/Headers
CGLContext.h OpenGL.h
CGLCurrent.h gl.h
CGLDevice.h glext.h
CGLIOSurface.h gliContext.h
CGLMacro.h gliDispatch.h
CGLProfiler.h glu.h
CGLProfilerFunctionEnum.h gluContext.h
CGLRenderers.h gluMacro.h
CGLTypes.h
Using CMake search function, I can find automatically /System/Library/Frameworks/OpenGL.framework/Headers by using find_package(OpenGL) and ${OPENGL_INLCUDE_DIR}
All this lead to the following problem
/Developer/GPU Computing/C/common/inc/GL/glut.h:59:19: error: GL/gl.h: No such file or directory
It seems that it is a classic problem http://www.blender.org/forum/viewtopic.php…d1b424be80586fc
Any headers on how to fix this ? without modifying glut.h
Cheers,
Koubiak
This is what we do in one of our projects:
#ifdef __APPLE__
#  include <GLUT/glut.h>
#else
#  include <GL/glut.h>
#endif
void display()
int main(int argc, char* argv[])
  glutInit(&argc, argv);
  glutInitDisplayMode(GLUT_RGB | GLUT_SINGLE);
  glutCreateWindow("OSX test");
  glutDisplayFunc(display);
  glutMainLoop();
return 0;
Then the CMake code looks like this:
cmake_minimum_required(VERSION 2.6)
project(glut-compile)
# As of CMake 2.6 policies were introduced in order to provide a mechanism for
# adding backwards compatibility one feature at a time.  We will just specify
# that all policies will use version 2.6 symantics.
cmake_policy(VERSION 2.6)
find_package(OpenGL REQUIRED)
find_package(GLUT REQUIRED)
# Some systems don't need Xmu for glut.  Remove it if it wasn't found.
if( DEFINED GLUT_Xmu_LIBRARY AND NOT GLUT_Xmu_LIBRARY)
  list(REMOVE_ITEM GLUT_LIBRARIES ${GLUT_Xmu_LIBRARY})
endif()
add_executable(glut-compile glut-compile.cpp)
target_link_libraries(glut-compile ${GLUT_LIBRARIES} ${OPENGL_LIBRARIES})
#ifdef __APPLE__
#else
#endif
void display()
  glutMainLoop();
return 0;
endif()
Thanks I will try this out!
Just a quick update.
It worked like a charm!
Thanks a lot and go utes ;)
