Thank you for your response,
The modification works for me, I can see that the Downlink packets in the special slot do not use more than 12 symbols.
However, the UE now can not become “in-sync” with the gnb anymore.
[NR_MAC] Frame.Slot 384.0
[NR_MAC] Frame.Slot 512.0
[NR_MAC] RACH.indication put_queue successfull
[NR_MAC] 597.19 UE RA-RNTI 010b TC-RNTI cab7: Activating RA process index 0
[NR_MAC] UE cab7: Msg3 scheduled at 598.18 (598.7 TDA 2)
[NR_MAC] UE cab7: 598.7 Generating RA-Msg2 DCI, RA RNTI 0x10b, state 1, CoreSetType 0, preamble_index(RAPID) 43, timing_offset = 13 (estimated distance 507.8 [m])
[NR_MAC] 598.7 Send RAR to RA-RNTI 010b
[NR_MAC] Couldn't identify UE connected with current UL HARQ process
[NR_MAC] 59910: RA RNTI cab7 CC_id 0 Scheduling retransmission of Msg3 in (599,18)
[NR_MAC] 60010: RA RNTI cab7 CC_id 0 Scheduling retransmission of Msg3 in (600,18)
[NR_MAC] 60110: RA RNTI cab7 CC_id 0 Scheduling retransmission of Msg3 in (601,18)
[NR_MAC] Random Access 0 failed at state WAIT_Msg3 (Reached msg3 max harq rounds)
[NR_MAC] Frame.Slot 640.0
[NR_MAC] Frame.Slot 768.0
[NR_MAC] 858.19 UE RA-RNTI 010b TC-RNTI 7e96: Activating RA process index 0
[NR_MAC] UE 7e96: Msg3 scheduled at 859.18 (859.7 TDA 2)
[NR_MAC] UE 7e96: 859.7 Generating RA-Msg2 DCI, RA RNTI 0x10b, state 1, CoreSetType 0, preamble_index(RAPID) 2, timing_offset = 0 (estimated distance 0.0 [m])
[NR_MAC] 859.7 Send RAR to RA-RNTI 010b
[NR_MAC] 86010: RA RNTI 7e96 CC_id 0 Scheduling retransmission of Msg3 in (860,18)
[NR_MAC] 86110: RA RNTI 7e96 CC_id 0 Scheduling retransmission of Msg3 in (861,18)
[NR_MAC] 86210: RA RNTI 7e96 CC_id 0 Scheduling retransmission of Msg3 in (862,18)
[NR_MAC] 869.19 UE RA-RNTI 010b TC-RNTI a280: Activating RA process index 0
[NR_MAC] UE a280: Msg3 scheduled at 870.18 (870.7 TDA 2)
[NR_MAC] UE a280: 870.7 Generating RA-Msg2 DCI, RA RNTI 0x10b, state 1, CoreSetType 0, preamble_index(RAPID) 38, timing_offset = 0 (estimated distance 0.0 [m])
[NR_MAC] 870.7 Send RAR to RA-RNTI 010b
[NR_MAC] 87110: RA RNTI a280 CC_id 0 Scheduling retransmission of Msg3 in (871,18)
[NR_MAC] 87210: RA RNTI a280 CC_id 0 Scheduling retransmission of Msg3 in (872,18)
[NR_MAC] 87310: RA RNTI a280 CC_id 0 Scheduling retransmission of Msg3 in (873,18)
[NR_MAC] 881.19 UE RA-RNTI 010b TC-RNTI 107d: Activating RA process index 0
[NR_MAC] UE 107d: Msg3 scheduled at 882.18 (882.7 TDA 2)
[NR_MAC] UE 107d: 882.7 Generating RA-Msg2 DCI, RA RNTI 0x10b, state 1, CoreSetType 0, preamble_index(RAPID) 26, timing_offset = 0 (estimated distance 0.0 [m])
[NR_MAC] 882.7 Send RAR to RA-RNTI 010b
[NR_MAC] 88310: RA RNTI 107d CC_id 0 Scheduling retransmission of Msg3 in (883,18)
[NR_MAC] 88410: RA RNTI 107d CC_id 0 Scheduling retransmission of Msg3 in (884,18)
[NR_MAC] 88510: RA RNTI 107d CC_id 0 Scheduling retransmission of Msg3 in (885,18)
[NR_MAC] 892.19 UE RA-RNTI 010b TC-RNTI 205e: Activating RA process index 0
[NR_MAC] UE 205e: Msg3 scheduled at 893.18 (893.7 TDA 2)
[NR_MAC] UE 205e: 893.7 Generating RA-Msg2 DCI, RA RNTI 0x10b, state 1, CoreSetType 0, preamble_index(RAPID) 56, timing_offset = 0 (estimated distance 0.0 [m])
[NR_MAC] 893.7 Send RAR to RA-RNTI 010b
[NR_MAC] 89410: RA RNTI 205e CC_id 0 Scheduling retransmission of Msg3 in (894,18)
[NR_MAC] 89510: RA RNTI 205e CC_id 0 Scheduling retransmission of Msg3 in (895,18)
[NR_MAC] Frame.Slot 896.0
[NR_MAC] 89610: RA RNTI 205e CC_id 0 Scheduling retransmission of Msg3 in (896,18)
[NR_MAC] Frame.Slot 0.0
Previously, the UE could successfully connect to the 5G system in a few cases.
Could you help with this?
Thank you
