• Jetson Nano
**• Deepstream 6.0 **
• JetPack Version 4.6
• Missing Header
• Write a Dockerfile based on deepstream-l4t:6.0 and make the lib nvdsinfer_custom_impl_Yolo
**• nvdsinfer_custom_impl_Yolo and docker image deepstream 6.0 **
I found an issue when I build a docker image with the version 6.0.- ( I don’t have the issue with docker image deepstream 7.0 and deepstream 6.0 in local on my jetson nano)
during the build I have a error of a missing header during the build of nvdsinfer_custom_impl_Yolo ( GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 7.0 / 6.4 / 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 / 5.1 implementation for YOLO models )
here the output :
ARG DEEPSTREAM_TAG=6.0-samples
FROM --platform=linux/arm64/v8 nvcr.io/nvidia/deepstream-l4t:${DEEPSTREAM_TAG}
# Install dependencies and clean up in a single RUN command to reduce image layers
RUN apt-get update && apt-get install -y --no-install-recommends \
software-properties-common \
&& add-apt-repository ppa:ubuntu-toolchain-r/test \
cmake \
build-essential \
g++-11 \
libssl-dev \
gstreamer1.0-tools \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
libgstreamer1.0-dev \
libgstreamer-plugins-base1.0-dev \
&& rm -rf /var/lib/apt/lists/*
# Set working directory
WORKDIR /app
COPY ./vision/ .
ARG CUDA_VER=10.2
ENV CUDA_VER=${CUDA_VER}
# Build custom libs
RUN make -C ./models/custom_lib/nvdsinfer_custom_impl_Yolo clean
Here the error output :
> [vision 12/14] RUN make -C ./models/custom_lib/nvdsinfer_custom_impl_Yolo:
0.294 make: Entering directory '/app/models/custom_lib/nvdsinfer_custom_impl_Yolo'
0.294 g++ -c -o utils.o -Wall -std=c++11 -shared -fPIC -Wno-error=deprecated-declarations -I/opt/nvidia/deepstream/deepstream/sources/includes -I/usr/local/cuda-10.2/include utils.cpp
0.552 In file included from utils.cpp:26:0:
0.552 utils.h:36:10: fatal error: NvInfer.h: No such file or directory
0.552 #include "NvInfer.h"
0.552 ^~~~~~~~~~~
0.552 compilation terminated.
0.559 Makefile:81: recipe for target 'utils.o' failed
0.560 make: *** [utils.o] Error 1
0.560 make: Leaving directory '/app/models/custom_lib/nvdsinfer_custom_impl_Yolo'
failed to solve: process "/bin/sh -c make -C ./models/custom_lib/nvdsinfer_custom_impl_Yolo" did not complete successfully: exit code: 2
for additionnal information, here the makefile of nvdsinfer_custom_impl_Yolo :
CUDA_VER?=
ifeq ($(CUDA_VER),)
$(error "CUDA_VER is not set")
endif
OPENCV?=
ifeq ($(OPENCV),)
OPENCV=0
endif
GRAPH?=
ifeq ($(GRAPH),)
GRAPH=0
endif
CC:= g++
NVCC:=/usr/local/cuda-$(CUDA_VER)/bin/nvcc
CFLAGS:= -Wall -std=c++11 -shared -fPIC -Wno-error=deprecated-declarations
CFLAGS+= -I/opt/nvidia/deepstream/deepstream/sources/includes -I/usr/local/cuda-$(CUDA_VER)/include
ifeq ($(OPENCV), 1)
COMMON+= -DOPENCV
CFLAGS+= $(shell pkg-config --cflags opencv4 2> /dev/null || pkg-config --cflags opencv)
LIBS+= $(shell pkg-config --libs opencv4 2> /dev/null || pkg-config --libs opencv)
endif
ifeq ($(GRAPH), 1)
COMMON+= -DGRAPH
endif
CUFLAGS:= -I/opt/nvidia/deepstream/deepstream/sources/includes -I/usr/local/cuda-$(CUDA_VER)/include
LIBS+= -lnvinfer_plugin -lnvinfer -lnvparsers -lnvonnxparser -L/usr/local/cuda-$(CUDA_VER)/lib64 -lcudart -lcublas -lstdc++fs
LFLAGS:= -shared -Wl,--start-group $(LIBS) -Wl,--end-group
INCS:= $(wildcard *.h)
SRCFILES:= $(filter-out calibrator.cpp, $(wildcard *.cpp))
ifeq ($(OPENCV), 1)
SRCFILES+= calibrator.cpp
endif
SRCFILES+= $(wildcard layers/*.cpp)
SRCFILES+= $(wildcard *.cu)
TARGET_LIB:= libnvdsinfer_custom_impl_Yolo.so
TARGET_OBJS:= $(SRCFILES:.cpp=.o)
TARGET_OBJS:= $(TARGET_OBJS:.cu=.o)
all: $(TARGET_LIB)
%.o: %.cpp $(INCS) Makefile
$(CC) -c $(COMMON) -o $@ $(CFLAGS) $<
%.o: %.cu $(INCS) Makefile
$(NVCC) -c -o $@ --compiler-options '-fPIC' $(CUFLAGS) $<
$(TARGET_LIB) : $(TARGET_OBJS)
$(CC) -o $@ $(TARGET_OBJS) $(LFLAGS)
clean:
rm -rf $(TARGET_LIB)
rm -rf $(TARGET_OBJS)
Thanks for any help !
This image is for deployment or demonstration purposes only, So it means there are no header file or some toolkit such as nvcc
If you want to use it for development, please use nvcr.io/nvidia/deepstream-l4t:6.0-triton
Here my output using 6.0.1-triton :
root@0ea75f83b893:/app/models/custom_lib/nvdsinfer_custom_impl_Yolo# make clean
rm -rf libnvdsinfer_custom_impl_Yolo.so
rm -rf utils.o yolo.o nvdsinfer_yolo_engine.o nvdsinitinputlayers_Yolo.o nvdsparsebbox_Yolo.o yoloPlugins.o layers/convolutional_layer.o layers/route_layer.o layers/shortcut_layer.o layers/slice_layer.o layers/pooling_layer.o layers/reorg_layer.o layers/batchnorm_layer.o layers/activation_layer.o layers/channels_layer.o layers/sam_layer.o layers/deconvolutional_layer.o layers/upsample_layer.o layers/implicit_layer.o yoloForward_v2.o yoloForward.o yoloForward_nc.o nvdsparsebbox_Yolo_cuda.o
root@0ea75f83b893:/app/models/custom_lib/nvdsinfer_custom_impl_Yolo# find / -name "NvInfer.h"
NvInfer.h does not exist
How to you start docker ? Can you share the command line ?
Try the following command line.
docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream-l4t:6.0-triton
Some libraries are shared between docker and host on the jetson platform.Nvinfer.h
is header of tensorrt, so make sure tensorrt is installed properly in host.
tensorrt is correctly installed on host and the library build well on it, here my docker start command :
vision:
build:
context: .
dockerfile: ./vision/Dockerfile
args:
CUDA_VER: 10.2
DEEPSTREAM_TAG: 6.0-triton
container_name: vision
image: bedrock/vision
runtime: nvidia
network_mode: host
volumes:
- /tmp/.X11-unix:/tmp/.X11-unix
- ./data:/data
- ./vision/cfg:/app/cfg
devices:
- /dev/video0
environment:
- DISPLAY=${DISPLAY}
- TZ=Europe/Berlin
- CUDA_VER=10.2
working_dir: /app
command: ./build/vision ./cfg/pipeline_cfg/pipeline_main_jpeg_fps.yaml
restart: always
I don’t use startup command of course for debugging
I have the feeling that the header of tensorrT are not installed in 6.0-triton, the header are not in /usr/include/aarch64-linux-gnu/NvInfer.h like on host.
I would like to build without hosting the build on a local nano (via a github worflows for example) like I do on deepstream-l4t:7.0*.
how can I install tensorRT on the docker image (I don’t really understand why a image for dev don’t have tensorRT) ?
If you use the command above to test, does it work? If it does, please compare the difference with the configuration file
Do you mean ds-6.0? Jetson can only support ds-6.0 at most.
This is unnecessary.
As I mentioned above, these libraries and headers on Jetson are shared between the host and docker.
Considering the size of docker images, these libraries are not installed in the docker image.
No, I meant it; my build works on Jetson Orin and x86 with DeepStream 7.0 without any problem. I’m working on both Jetson Orin and Nano.
It shares resources, but at runtime, I want to build the library during the Docker build. Additionally, the path you mounted is not the path where the TensorRT library like nvinfer is located.
Your command doesn’t make any difference; that’s normal because the missing libraries come from /usr/lib/aarch64-linux-gnu
and /usr/include/aarch64-linux-gnu/ on host
Sorry for the long delay because a holiday.
TensorRT is only mapped to the container at runtime.
If you want to include Nvinfer.h
when building the image, you can add the COPY
instruction in the Dockerfile
to copy Nvinfer.h
from the host to the docker image.
the only solution I found without using self host was to push the nano *.so prebuilt for it to work
system
Closed
October 23, 2024, 1:23pm
11
