Missing key(s) in state_dict
We are facing the following issue during server aggregation (after local client training) on 4.0 GA Federated Learning.
Kindly review the configs (especially config_fed_server.json & config_fed_client.json) & logs as attached below.
PS: It seems to be using the default Monai UNet instead of our model
config.zip (14.7 KB)
config_fed_server.json (1005 Bytes)
config_fed_client.json (773 Bytes)
	Missing key(s) in state_dict: "segmenter.0.down.0.conv.weight", "segmenter.0.down.0.conv.bias", "segmenter.0.down.0.res.weight", "segmenter.0.down.0.res.bias", "segmenter.0.down.0.end_seq.1.weight", "segmenter.0.down.0.end_seq.1.bias", "segmenter.0.down.1.conv.weight", "segmenter.0.down.1.conv.bias", "segmenter.0.down.1.res.weight", "segmenter.0.down.1.res.bias", "segmenter.0.down.1.end_seq.1.weight", "segmenter.0.down.1.end_seq.1.bias", "segmenter.0.down.2.conv.weight", "segmenter.0.down.2.conv.bias", "segmenter.0.down.2.res.weight", "segmenter.0.down.2.res.bias", "segmenter.0.down.2.end_seq.1.weight", "segmenter.0.down.2.end_seq.1.bias", "segmenter.0.down.3.conv.weight", "segmenter.0.down.3.conv.bias", "segmenter.0.down.3.res.weight", "segmenter.0.down.3.res.bias", "segmenter.0.down.3.end_seq.1.weight", "segmenter.0.down.3.end_seq.1.bias", "segmenter.0.u.conv.weight", "segmenter.0.u.conv.bias", "segmenter.0.u.res.weight", "segmenter.0.u.res.bias", "segmenter.0.u.end_seq.1.weight", "segmenter.0.u.end_seq.1.bias", "segmenter.0.up.0.conv.weight", "segmenter.0.up.0.conv.bias", "segmenter.0.up.0.res.weight", "segmenter.0.up.0.res.bias", "segmenter.0.up.0.end_seq.1.weight", "segmenter.0.up.0.end_seq.1.bias", "segmenter.0.up.1.conv.weight", "segmenter.0.up.1.conv.bias", "segmenter.0.up.1.res.weight", "segmenter.0.up.1.res.bias", "segmenter.0.up.1.end_seq.1.weight", "segmenter.0.up.1.end_seq.1.bias", "segmenter.0.up.2.conv.weight", "segmenter.0.up.2.conv.bias", "segmenter.0.up.2.res.weight", "segmenter.0.up.2.res.bias", "segmenter.0.up.2.end_seq.1.weight", "segmenter.0.up.2.end_seq.1.bias", "segmenter.0.up.3.conv.weight", "segmenter.0.up.3.conv.bias", "segmenter.0.up.3.res.weight", "segmenter.0.up.3.res.bias", "segmenter.0.up.3.end_seq.1.weight", "segmenter.0.up.3.end_seq.1.bias", "segmenter.1.weight", "segmenter.1.bias".
	Unexpected key(s) in state_dict: "model.0.conv.unit0.conv.weight", "model.0.conv.unit0.conv.bias", "model.0.conv.unit0.adn.N.weight", "model.0.conv.unit0.adn.N.bias", "model.0.conv.unit0.adn.N.running_mean", "model.0.conv.unit0.adn.N.running_var", "model.0.conv.unit0.adn.N.num_batches_tracked", "model.0.conv.unit0.adn.A.weight", "model.0.conv.unit1.conv.weight", "model.0.conv.unit1.conv.bias", "model.0.conv.unit1.adn.N.weight", "model.0.conv.unit1.adn.N.bias", "model.0.conv.unit1.adn.N.running_mean", "model.0.conv.unit1.adn.N.running_var", "model.0.conv.unit1.adn.N.num_batches_tracked", "model.0.conv.unit1.adn.A.weight", "model.0.residual.weight", "model.0.residual.bias", "model.1.submodule.0.conv.unit0.conv.weight", "model.1.submodule.0.conv.unit0.conv.bias", "model.1.submodule.0.conv.unit0.adn.N.weight", "model.1.submodule.0.conv.unit0.adn.N.bias", "model.1.submodule.0.conv.unit0.adn.N.running_mean", "model.1.submodule.0.conv.unit0.adn.N.running_var", "model.1.submodule.0.conv.unit0.adn.N.num_batches_tracked", "model.1.submodule.0.conv.unit0.adn.A.weight", "model.1.submodule.0.conv.unit1.conv.weight", "model.1.submodule.0.conv.unit1.conv.bias", "model.1.submodule.0.conv.unit1.adn.N.weight", "model.1.submodule.0.conv.unit1.adn.N.bias", "model.1.submodule.0.conv.unit1.adn.N.running_mean", "model.1.submodule.0.conv.unit1.adn.N.running_var", "model.1.submodule.0.conv.unit1.adn.N.num_batches_tracked", "model.1.submodule.0.conv.unit1.adn.A.weight", "model.1.submodule.0.residual.weight", "model.1.submodule.0.residual.bias", "model.1.submodule.1.submodule.0.conv.unit0.conv.weight", "model.1.submodule.1.submodule.0.conv.unit0.conv.bias", "model.1.submodule.1.submodule.0.conv.unit0.adn.N.weight", "model.1.submodule.1.submodule.0.conv.unit0.adn.N.bias", "model.1.submodule.1.submodule.0.conv.unit0.adn.N.running_mean", "model.1.submodule.1.submodule.0.conv.unit0.adn.N.running_var", "model.1.submodule.1.submodule.0.conv.unit0.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.0.conv.unit0.adn.A.weight", "model.1.submodule.1.submodule.0.conv.unit1.conv.weight", "model.1.submodule.1.submodule.0.conv.unit1.conv.bias", "model.1.submodule.1.submodule.0.conv.unit1.adn.N.weight", "model.1.submodule.1.submodule.0.conv.unit1.adn.N.bias", "model.1.submodule.1.submodule.0.conv.unit1.adn.N.running_mean", "model.1.submodule.1.submodule.0.conv.unit1.adn.N.running_var", "model.1.submodule.1.submodule.0.conv.unit1.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.0.conv.unit1.adn.A.weight", "model.1.submodule.1.submodule.0.residual.weight", "model.1.submodule.1.submodule.0.residual.bias", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.conv.weight", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.conv.bias", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.adn.N.weight", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.adn.N.bias", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.adn.N.running_mean", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.adn.N.running_var", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.1.submodule.0.conv.unit0.adn.A.weight", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.conv.weight", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.conv.bias", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.adn.N.weight", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.adn.N.bias", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.adn.N.running_mean", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.adn.N.running_var", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.1.submodule.0.conv.unit1.adn.A.weight", "model.1.submodule.1.submodule.1.submodule.0.residual.weight", "model.1.submodule.1.submodule.1.submodule.0.residual.bias", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.conv.weight", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.conv.bias", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.adn.N.weight", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.adn.N.bias", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.adn.N.running_mean", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.adn.N.running_var", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit0.adn.A.weight", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.conv.weight", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.conv.bias", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.adn.N.weight", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.adn.N.bias", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.adn.N.running_mean", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.adn.N.running_var", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.1.submodule.1.submodule.conv.unit1.adn.A.weight", "model.1.submodule.1.submodule.1.submodule.1.submodule.residual.weight", "model.1.submodule.1.submodule.1.submodule.1.submodule.residual.bias", "model.1.submodule.1.submodule.1.submodule.2.0.conv.weight", "model.1.submodule.1.submodule.1.submodule.2.0.conv.bias", "model.1.submodule.1.submodule.1.submodule.2.0.adn.N.weight", "model.1.submodule.1.submodule.1.submodule.2.0.adn.N.bias", "model.1.submodule.1.submodule.1.submodule.2.0.adn.N.running_mean", "model.1.submodule.1.submodule.1.submodule.2.0.adn.N.running_var", "model.1.submodule.1.submodule.1.submodule.2.0.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.1.submodule.2.0.adn.A.weight", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.conv.weight", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.conv.bias", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.adn.N.weight", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.adn.N.bias", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.adn.N.running_mean", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.adn.N.running_var", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.1.submodule.2.1.conv.unit0.adn.A.weight", "model.1.submodule.1.submodule.2.0.conv.weight", "model.1.submodule.1.submodule.2.0.conv.bias", "model.1.submodule.1.submodule.2.0.adn.N.weight", "model.1.submodule.1.submodule.2.0.adn.N.bias", "model.1.submodule.1.submodule.2.0.adn.N.running_mean", "model.1.submodule.1.submodule.2.0.adn.N.running_var", "model.1.submodule.1.submodule.2.0.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.2.0.adn.A.weight", "model.1.submodule.1.submodule.2.1.conv.unit0.conv.weight", "model.1.submodule.1.submodule.2.1.conv.unit0.conv.bias", "model.1.submodule.1.submodule.2.1.conv.unit0.adn.N.weight", "model.1.submodule.1.submodule.2.1.conv.unit0.adn.N.bias", "model.1.submodule.1.submodule.2.1.conv.unit0.adn.N.running_mean", "model.1.submodule.1.submodule.2.1.conv.unit0.adn.N.running_var", "model.1.submodule.1.submodule.2.1.conv.unit0.adn.N.num_batches_tracked", "model.1.submodule.1.submodule.2.1.conv.unit0.adn.A.weight", "model.1.submodule.2.0.conv.weight", "model.1.submodule.2.0.conv.bias", "model.1.submodule.2.0.adn.N.weight", "model.1.submodule.2.0.adn.N.bias", "model.1.submodule.2.0.adn.N.running_mean", "model.1.submodule.2.0.adn.N.running_var", "model.1.submodule.2.0.adn.N.num_batches_tracked", "model.1.submodule.2.0.adn.A.weight", "model.1.submodule.2.1.conv.unit0.conv.weight", "model.1.submodule.2.1.conv.unit0.conv.bias", "model.1.submodule.2.1.conv.unit0.adn.N.weight", "model.1.submodule.2.1.conv.unit0.adn.N.bias", "model.1.submodule.2.1.conv.unit0.adn.N.running_mean", "model.1.submodule.2.1.conv.unit0.adn.N.running_var", "model.1.submodule.2.1.conv.unit0.adn.N.num_batches_tracked", "model.1.submodule.2.1.conv.unit0.adn.A.weight", "model.2.0.conv.weight", "model.2.0.conv.bias", "model.2.0.adn.N.weight", "model.2.0.adn.N.bias", "model.2.0.adn.N.running_mean", "model.2.0.adn.N.running_var", "model.2.0.adn.N.num_batches_tracked", "model.2.0.adn.A.weight", "model.2.1.conv.unit0.conv.weight", "model.2.1.conv.unit0.conv.bias".
2021-06-21 00:27:54,449 - ignite.engine.engine.SupervisedEvaluator - ERROR - Exception: Error(s) in loading state_dict for NewLesionsUNet:
lesion-activity-{Epoch-1,Num_of_rounds-1}-GA-Server.txt (10.6 KB)
lesion-activity-{Epoch-1,Num_of_rounds-1}-GA-ClientA.txt (108.8 KB)
lesion-activity-{Epoch-1,Num_of_rounds-1}-GA-ClientB.txt (91.0 KB)
It appears that the “lesion-activity-clara-fl.NewLesionsUNet.model.NewLesionsUNet” model data didn’t got saved correctly on the server by the “PTFileModelPersistor”. Both clients were not able to load the final global model for validation. Could you please check if the final global model has the correct contents.
Reply 1. Yes. We need ModelPersistor in both server and client. During FL, there is only model parameters pushed and pulled. The model structure is in ModelPersistor, which interprets the parameters and make the complete model for training.
Reply 2. Yes, the reason is same as the previous. we need this function to complete the model for understanding right whole one.
Reply 3. Two arguments that you claimed are correct. I also check the path pointing to your customized model structure. I don’t see the reason why default Unet comes out the right. will check with EE again.
PTFileModelPersistor extracts all the parameters from the model weights then save in the FL_global_model.pt. Can you check if your model also contains these additional parameters from UNet model?
