Complete information regarding my setup:
- Hardware Platform: Jetson Orin NX 16 GB
- DeepStream Version: 7.0
- JetPack Version: 6.0
- TensorRT Version: 8.6.2.3
- Issue Type: Question / Bug
I need to create a Docker image with DeepStream by compiling and building the Python bindings in order to address another bug reported here. However, I am encountering issues with the cmake command options:
# 2. Compiling the bindings
# 2.2 Quick build 2 (Jetson-ubuntu-22.04 | python 3.10 | Deepstream 7.0)
RUN cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings && \
mkdir build && cd build && \
cmake .. -DPYTHON_MAJOR_VERSION=3 -DPYTHON_MINOR_VERSION=10 \
-DPIP_PLATFORM=linux_aarch64 \
-DDS_PATH=/opt/nvidia/deepstream/deepstream && \
make -j$(nproc)
The output I get is:
CMake Error at CMakeLists.txt:92 (message):
Missing libnvbufsurface.so at
/opt/nvidia/deepstream/deepstream/lib/libnvbufsurface.so
please make sure that DeepStream is installed
But, actually, inside the container the file exists:
root@orin-desktop:/opt# ls /opt/nvidia/deepstream/deepstream/lib/libnvbufsurface.so
Here is my Dockerfile:
# Use NVIDIA DeepStream 7.0 base image with multi-architecture support
FROM nvcr.io/nvidia/deepstream:7.0-samples-multiarch
# Set non-interactive mode to avoid prompts during package installs and configure timezone
ENV DEBIAN_FRONTEND=noninteractive TZ=Europe/Rome
# Update package lists, upgrade system packages, and install dependencies
# Required for building and running DeepStream Python bindings on ARM64
RUN apt update && \
apt upgrade -y && \
apt install -y vim && \
apt install -y python3-opencv && \
apt install -y ffmpeg && \
apt install -y graphviz
# Compile and Build DeepStream python bindings
# - commands-source: https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/tree/v1.1.11/bindings
# - reason: https://forums.developer.nvidia.com/t/issue-with-parallel-branches-in-deepstream-pipeline/343499/11?u=vic01
# 1. Prerequisites
# 1.2 Base dependencies: dependencies need to be met in order to compile bindings
RUN apt install -y python3-gi python3-dev python3-gst-1.0 \
python-gi-dev git meson python3 python3-pip python3.10-dev \
cmake g++ build-essential libglib2.0-dev libglib2.0-dev-bin \
libgstreamer1.0-dev libtool m4 autoconf automake libgirepository1.0-dev libcairo2-dev \
libgstrtspserver-1.0-dev gstreamer1.0-rtsp
# 1.3 Initialization of submodules (DeepStream SDK 7.0)
RUN git clone -b v1.1.11 https://github.com/NVIDIA-AI-IOT/deepstream_python_apps.git \
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps && \
cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/ && \
git submodule update --init
# 1.4 Installing Gst-python: Build and install gst-python
RUN apt-get install -y apt-transport-https ca-certificates -y && \
update-ca-certificates && \
cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/3rdparty/gstreamer/subprojects/gst-python/ && \
meson setup build && \
cd build && \
ninja && \
ninja install
# Fix the file bindnvdsinfer.cpp (to support unique_id in segmeta) file as in:
# https://forums.developer.nvidia.com/t/issue-with-parallel-branches-in-deepstream-pipeline/343499/11?u=vic01
RUN sed -i '256a .def_readonly("unique_id", &NvDsInferSegmentationMeta::unique_id)' \
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/src/bindnvdsinfer.cpp
make -j$(nproc)
# 3. Installing the bindings
RUN cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build && \
python3 -m pip install --upgrade pip && \
pip3 install ./pyds-1.1.11-py3-none*.whl
# Install additional packages that might be necessary to use all of the DeepStreamSDK features
RUN pip3 install cuda-python==12.8.0 && \
/opt/nvidia/deepstream/deepstream/user_additional_install.sh
I have seen a similar problem reported here, and the suggested solution was to use prebuilt bindings. Unfortunately, I cannot do that because I need to recompile the bindings.
How can I resolve this issue?
Thank you in advance for your support!
