Missing libnvinfer-dev package in OS 6.0.8.1
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
I installed Drive OS using a container on an Ubuntu 22.04 host by referring to the link provided.
To confirm if TensorRT is properly installed, I entered the following command. While other packages are installed, libnvinfer-dev isn’t installed, and there are no header files such as Nvinfer.h.
Is there a way to install libnvinfer-dev ?
Dear @jrlee1,
Can you do the sample development on docker and cross compile the sample as docker has the dev environment and header files are not part of target filesystem
