Isaac sim ver 4.2
Followed the Omni.Anim.People tutorial, I can not find the “navigation”
Also, I check the extension, the navigation core extension is loaded.
Isaac sim ver 4.2
Hey @Yen_Yan! Did you enable navigation related extensions? Here are the extensions that you can try to enable
Hey @Yen_Yan! That means you have that extension installed. Now you need to enable it. To enable it, please click on the small button by “DISABLED”. Once you click on it, it will turn into green “ENABLED” as shown in the image (circled in red). You can also check “AUTOLOAD” to automatically enable this extension every time you open Isaac Sim 4.2. Otherwise this extension is disabled by default.
Hey @Yen_Yan Thanks for your screenshots. Please also install and enable the following two extensions:
@zhengwang Sorry, this leads to the previous reply that I can not install them since it says
“[omni.ext.plugin] Can’t pull extension: ‘omni.anim.navigation.bundle-106.1.0’, it is already available locally.”
Never mind, maybe I need reinstall the issac sim.
Hey @Yen_Yan! It should have already been installed on your machine locally according to your previous screenshot (it says “it is already available locally”). You just need to enable them.
I will close this topic since there is no new replies. But please feel free to open a new one if the issue still persists.
