Hi, NV_WORKSPACE is faced the delemma of visiblity on SYSTEM or USER level.
If on SYSTEM level, such as put NV_WORKSPACE=/path in /etc/environment, then what’s about multi-users?
If on USER level, what’s about other softwares which need to sudo privilege? e.g. Ubuntu offical Software Updater.
But please don’t ask user input NV_WORKSPACE path at least. You can warning users and refuse to config/update/run if NV_WORKSPACE is missing or the path is not existed.
In short, please don’t set NV_WORKSPACE interactively.
Dear @Keelung,
Are you installing the DRIVE OS 6.0.4 on host manually? If so, may I know why you are not using sdkmanager? We recommend to use sdkmanager manager for installation and flashing.
Hi @SivaRamaKrishnaNV ,
If what I understand isn’t wrong, SDK Manager 1.8.3 can’t handle PDK? I compared the count of packages in PDK and SDK, they are 60 vs 30 almostly
Hi @Keelung
PDK isn’t supported throught the forum. If you have PDK access, you should get support throught other channel.
If you’re not aware of the channel, please contact your nv representative. Thanks.
