Missing Nvidia Drivers while Installing CUDA-11 on RHEL8.1
I am having issue installing CUDA-11 on RHEL 8.1.
Followed below instructions
https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html#introduction
After following above instructions “dnf install cuda” returns error.
wget http://developer.download.nvidia.com/compute/cuda/11.0.1/local_installers/cuda-repo-rhel8-11-0-local-11.0.1_450.36.06-1.x86_64.rpm
sudo rpm -i cuda-repo-rhel8-11-0-local-11.0.1_450.36.06-1.x86_64.rpm
sudo dnf clean all
sudo dnf -y module install nvidia-driver:latest-dkms
sudo dnf -y install cuda
The command “dnf install cuda” return below error.
Last metadata expiration check: 0:03:44 ago on Mon 29 Jun 2020 10:37:45 PM UTC.
NOTE: Skipping kernel installation since no NVIDIA driver kernel module package kmod-nvidia-450.36.06-4.18.0-147.8.1 for kernel kernel-4.18.0-147.8.1.el8_1.x86_64 and driver nvidia-driver-3:450.36.06-1.el8.x86_64 could be found
Could you please post this in the CUDA forum:
https://forums.developer.nvidia.com/c/accelerated-computing/cuda/cuda-setup-and-installation/8
