Missing onnx model files for foundationpose, only etlt
After following the instructions in the website, it reports error when running the API launch command for foundationpose (replaced the path with correct path):
Command
ros2 launch isaac_ros_foundationpose isaac_ros_foundationpose.launch.py refine_model_file_path:=<path to refine onnx model> refine_engine_file_path:=<path to refine model .plan> score_model_file_path:=<path to score onnx model> score_engine_file_path:=<path to score model .plan> mesh_file_path:=<path to object mesh file> texture_path:=<path to texture map> launch_rviz:=<enable rviz> launch_bbox_to_mask:=<enable bbox to mask converter> mask_height:=<converted mask height> mask_width:=<converted mask width>
Error
[component_container_mt-1] 2024-06-17 20:32:37.319 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@151: TRT ERROR: ModelImporter.cpp:733: Failed to parse ONNX model from file: /tmp/score_model.onnx
[component_container_mt-1] 2024-06-17 20:32:37.319 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@472: Failed to parse ONNX file /tmp/score_model.onnx
[component_container_mt-1] 2024-06-17 20:32:37.442 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@287: Failed to create engine plan for model /tmp/score_model.onnx.
The downloaded model files have no onnx files. May I know how we can get it? Thanks
Hi @kcz
I think you have successfully run the Issac ROS foundation point example, and now you are trying to make your own launch file.
If not, please check point 4 in isaac_ros_foundationpose — isaac_ros_docs documentation
This command will start the foundationpose demo.
If you are working with this command
like is written, you need to change the <path to refine onnx model>, <path to refine model .plan>, <path to score onnx model>, <path to score model .plan>, <path to object mesh file>, <path to texture map>, <enable rviz>, <enable bbox to mask converter>, <converted mask height>, <converted mask width> with the right path.
Here is an example you can follow
Thanks for the quick response and the instructions. Actually, I replaced the placeholder path with the correct ones (but not putting them in this thread). The problem is that I don’t have the onnx model files after following the instructions on the website. It only has the etlt and trt engine.
  1. Download the pre-trained FoundationPose models from NGC:
wget --content-disposition https://api.ngc.nvidia.com/v2/models/nvidia/isaac/foundationpose/versions/1.0.0/zip -O foundationpose_1.0.0.zip
  1. Copy the models to the required directory:
mkdir -p ${ISAAC_ROS_WS}/isaac_ros_assets/models/foundationpose && \ unzip foundationpose_1.0.0.zip -d ${ISAAC_ROS_WS}/isaac_ros_assets/models/foundationpose
Can you be advise how to get the onnx files? Thanks
Hi @Raffaello, could you please take a look at the problem again? Thanks
Hi @kcz
I tested again running the command on my desktop:
and
and everything looks normal.
Do you have some errors when you download the foundationpose_1.0.0.zip file? or when you unpack the zip file?
@Raffaello Thanks for checking but it seems that you missed the point of the issue.
After downloading the model files, there are NO onnx model files, which is REQUIRED when running the launch file of foundationpose. There are only etlt model files and trt engine files.
Can you please take a look? Thanks
Hi @kcz
I forwarded your question to the engineers.
If you follow the tutorial to finish the model preparation, you should have the trt engines under isaac_ros_assets and you can pass the trt engine files to the launch file and ignore the onnx file.
Let me know if the demo starts again.
Best,
Raffaello
For me it also happened. I have just tried to follow the tutorial and after unzipping there is no files such ‘model.onnx’ and I also receive errors:
[component_container_mt-1] Could not open file model.onnx
[component_container_mt-1] 2024-06-24 16:08:58.393 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@151: TRT ERROR: ModelImporter.cpp:733: Failed to parse ONNX model from file: model.onnx
[component_container_mt-1] 2024-06-24 16:08:58.393 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@472: Failed to parse ONNX file model.onnx
[component_container_mt-1] 2024-06-24 16:08:58.502 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@287: Failed to create engine plan for model model.onnx.
Was that issue solved locally by anyone?
This demo does not require the ONNX file. If you follow the quickstart, the files are converted to .etlt files and loaded on the foundationpose launch file.
https://nvidia-isaac-ros.github.io/repositories_and_packages/isaac_ros_pose_estimation/isaac_ros_foundationpose/index.html#build-package-name
We are working to update the documentation to make more simple to usage the provided launch file.
Best,
Raffaello
@grdec Have you solved the issue, I’m encountering the same issue!
[component_container_mt-1] 2024-08-23 23:51:56.340 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@151: TRT ERROR: ModelImporter.cpp:730: Failed to parse ONNX model from file: /tmp/refine_model.onnx
[component_container_mt-1] 2024-08-23 23:51:56.340 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@472: Failed to parse ONNX file /tmp/refine_model.onnx
[component_container_mt-1] 2024-08-23 23:51:56.634 ERROR ./gxf/extensions/tensor_rt/tensor_rt_inference.cpp@287: Failed to create engine plan for model /tmp/refine_model.onnx.
[component_container_mt-1] 2024-08-23 23:51:56.634 WARN  gxf/std/entity_executor.cpp@495: Failed to start entity [OXJWUVBWKM_refine_inference]
[component_container_mt-1] 2024-08-23 23:51:56.634 WARN  gxf/std/multi_thread_scheduler.cpp@342: Error while executing entity E449 named 'OXJWUVBWKM_refine_inference': GXF_FAILURE
[component_container_mt-1] 2024-08-23 23:51:56.640 ERROR gxf/std/entity_executor.cpp@586: Entity [OXJWUVBWKM_refine_inference] must be in Started, Tick Pending, Ticking or Idle stage before stopping. Current state is StartPending
[component_container_mt-1] 2024-08-23 23:51:57.373 ERROR gxf/std/entity_executor.cpp@210: Entity with eid 330 not found!
[component_container_mt-1] [WARN] [1724437317.373317852] [foundationpose_node]: [NitrosNode] The heartbeat entity (eid=330) was stopped. The graph may have been terminated.
[component_container_mt-1] [INFO] [1724437317.404714505] [foundationpose_node]: [NitrosNode] Terminating the running application
[component_container_mt-1] [INFO] [1724437317.404749612] [foundationpose_node]: [NitrosContext] Interrupting GXF...
[component_container_mt-1] 2024-08-23 23:51:57.404 ERROR gxf/core/runtime.cpp@1468: Graph interrupt failed with error: GXF_FAILURE
[component_container_mt-1] [ERROR] [1724437317.404849844] [foundationpose_node]: [NitrosContext] GxfGraphInterrupt Error: GXF_FAILURE
[component_container_mt-1] [INFO] [1724437317.404853876] [foundationpose_node]: [NitrosContext] Waiting on GXF...
[component_container_mt-1] 2024-08-23 23:51:57.404 ERROR gxf/std/program.cpp@574: wait failed. Deactivating...
[component_container_mt-1] |==================================================================================================================================================================|
[component_container_mt-1] |                                           Job Statistics Report (regular)        |
[component_container_mt-1] | Name                                               |   Count | Time (Median - 90% - Max) [ms] | Load (%) | Exec(ms) | Variation (Median - 90% - Max) [ns]        |
[component_container_mt-1] |------------------------------------------------------------------------------------------------------------------------------------------------------------------|
[component_container_mt-1] |                                           Entity Statistics Report (regular)        |
[component_container_mt-1] | Entity Name             | Entity State             |   Count | Time (Median - 90% - Max) [ms]        |
[component_container_mt-1] 2024-08-23 23:51:57.458 WARN  gxf/std/entity_warden.cpp@464: Component of type nvidia::gxf::MultiThreadScheduler, cid 574 failed to deinitialize with code GXF_FAILURE
[component_container_mt-1] 2024-08-23 23:51:57.458 ERROR gxf/core/runtime.cpp@751: Could not deinitialize entity 'OXJWUVBWKM_utils' (E572): GXF_FAILURE
[component_container_mt-1] 2024-08-23 23:51:57.458 ERROR gxf/std/program.cpp@576: Deactivation failed.
[component_container_mt-1] 2024-08-23 23:51:57.458 ERROR gxf/core/runtime.cpp@1476: Graph wait failed with error: GXF_FAILURE
