Missing ranks
• Hardware (T4/V100/Xavier/Nano/etc)
H100
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
LPRnet
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
5.0.0-tf1.15.5
• Training spec file(If have, please share here)
random_seed: 42
lpr_config {
  hidden_units: 512
  max_label_length: 12
  arch: "baseline"
  nlayers: 18 #setting nlayers to be 10 to use baseline10 model
training_config {
  batch_size_per_gpu: 2048
  num_epochs: 150
  learning_rate {
  soft_start_annealing_schedule {
    min_learning_rate: 1e-6
    max_learning_rate: 1e-5
    soft_start: 0.001
    annealing: 0.5
  regularizer {
    type: L2
    weight: 5e-4
eval_config {
  validation_period_during_training: 5
  batch_size: 1
augmentation_config {
    output_width: 100
    output_height: 48
    output_channel: 3
    max_rotate_degree: 5
    rotate_prob: 0.5
    gaussian_kernel_size: 5
    gaussian_kernel_size: 7
    gaussian_kernel_size: 15
    blur_prob: 0.5
    reverse_color_prob: 0.5
    keep_original_prob: 0.3
dataset_config {
  data_sources: {
    label_directory_path: "/workspace/tao-training/LPRnet_training/dataset/char/train/labels"
    image_directory_path: "/workspace/tao-training/LPRnet_training/dataset/char/train/images"
  characters_list_file: "/workspace/tao-training/LPRnet_training/us_lp_characters.txt"
  validation_data_sources: {
    label_directory_path: "/workspace/tao-training/LPRnet_training/dataset/char/val/labels"
    image_directory_path: "/workspace/tao-training/LPRnet_training/dataset/char/val/images"
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Missing ranks:
0: [training/DistributedSGD_Allreduce/cond/HorovodAllreduce_training_DistributedSGD_gradients_gradients_AddN_58_0, training/DistributedSGD_Allreduce/cond_1/HorovodAllreduce_training_DistributedSGD_gradients_gradients_AddN_57_0, training/DistributedSGD_Allreduce/cond_10/HorovodAllreduce_training_DistributedSGD_gradients_gradients_AddN_53_0, training/DistributedSGD_Allreduce/cond_11/HorovodAllreduce_training_DistributedSGD_gradients_gradients_AddN_51_0, training/DistributedSGD_Allreduce/cond_12/HorovodAllreduce_training_DistributedSGD_gradients_gradients_bn2a_branch1_FusedBatchNormV3_grad_FusedBatchNormGradV3_1, training/DistributedSGD_Allreduce/cond_13/HorovodAllreduce_training_DistributedSGD_gradients_gradients_bn2a_branch1_FusedBatchNormV3_grad_FusedBatchNormGradV3_2 ...]
This is the error I am facing when I trained it and saved in the fifith epoch
Does the training hang? Please share the full log.
Is it running with multi gpus? If yes, please check if one gpu can work.
