I’ve been trying to use tensorrt for a few days now on the Isaac ROS Dev Base docker image, available here. I’ve pulled it on an Orin AGX to run a project that was working previously on a l4t docker image with humble installed on top.
From what I’ve seen in the Dockerfile here, everything is already installed and the paths are all already set. But when I run import tensorrt
the package is not found. I’ve tried following the install instruction from the installation guide, I’ve also tried multiple other ways to install tensorrt:
apt update && apt upgrade
apt install nvidia-tensorrt
pip3 install nvidia-pyindex
pip3 install tensorrt
My Orin AGX is running JetPack 5.1.1 and if I search for tensorrt using dpkg -L
all I have is results in /usr/share/doc. There is also an executable in /usr/src/tensorrt/bin but I’m not sure what to do of it.
