# R35 (release), REVISION: 3.1, GCID: 32827747, BOARD: t186ref, EABI: aarch64, DATE: Sun Mar 19 15:19:21 UTC 2023
I am attempting to use the gen_luks.sh script as outlined in the NVIDIA Developer Guide. However, I am unable to locate the gen_luks.sh script and the /opt/nvidia/cryptluks file on my system.
Is there a way to download the gen_luks.sh script and the necessary files for cryptluks?
Additionally, I purchased this Orin NX from Neousys-Tech.
assume you’ve download Jetpack release image via SDKManager. gen_luks.sh it’s actually installed to your local host as following,
for instance, ~/nvidia/nvidia_sdk/JetPack_xxx/Linux_for_Tegra/rootfs/usr/sbin/gen_luks.sh
it looks you’re going to enable disk encryption, it’s a must to update EKS image if you’re using a customize key,
please refer to L4T developer guide, Tool for EKB Generation, you may also visit jetson-linux-r3531 to download the [Driver Package (BSP) Sources] package, see-also below to run the EKB generation tool.
for instance, $public_sources/r35.3.1/Linux_for_Tegra/source/public/atf_and_optee/optee/samples/hwkey-agent/host/tool/gen_ekb/example.sh
