Missing veth/macvlan/ipvlan support on NVIDIA DRIVE AGX (Kernel 5.15.122-rt-tegra)
DRIVE OS Version: Provide DRIVE OS ver. 6.0.10
Issue Description:
I am working on a setup on NVIDIA DRIVE AGX, where multiple containerized applications are deployed on a single HPC node.
I am unable to create any form of container network isolation required to simulate inter-ECU communication due to missing kernel networking support.
Specifically:
  1. Docker bridge network fails
failed to add the host (vethXXXX) <=> sandbox (vethXXXX) pair interfaces: operation not supported
  1. macvlan network fails
failed to create the macvlan port: operation not supported
  1. ipvlan network fails
failed to create the ipvlan port: operation not supported
  1. Manual veth creation fails
ip link add veth_cam type veth peer name veth_drow
β†’ Error: Unknown device type
Kernel Investigation:
Kernel version:
5.15.122-rt-tegra
Kernel config:
CONFIG_VETH=m
However, the module is missing:
modprobe veth
β†’ FATAL: Module veth not found in directory /lib/modules/5.15.122-rt-tegra
Also:
/lib/modules/5.15.122-rt-tegra/kernel/drivers/net/
β†’ only contains: can, mdio.ko, usb
(no veth.ko, macvlan.ko, ipvlan.ko)
Impact:
  • Unable to use Docker bridge networking (depends on veth)
  • Unable to use macvlan/ipvlan
  • Unable to create network namespaces for isolation
  • Only --network host is functional
Request:
We would like guidance on the following:
  1. Is it expected that NVIDIA DRIVE AGX kernel does not include:
    • veth
    • macvlan
    • ipvlan modules?
  2. Is there an official way to enable container network isolation on DRIVE AGX?
  3. Is there a supported kernel/modules package that includes:
    • veth.ko
    • macvlan.ko
    • ipvlan.ko
Please check and help.
Dear @amitkumar.nandi1 ,
--network hostoption with Docker, allows containers to use the host network stack. This is the recommended approach for DRIVE AGX Orin. Does that work your case?
@SivaRamaKrishnaNV Thanks for the support.
Yes, --network hostoption with Docker is working fine. But I was trying to communicate via macvlan/ipvlan network also, which is not working. Is there any way to enable those?
Docker on DRIVE is for experimentation purpose and expect to use network via host.
