Hey,
I’ve created an algorithm using python and I understood that in order to use it inside the deepstream pipe I need to wrap it as a plugin. is that correct ? is there other way? how can I create this plugin?
our deepstream pipeline is written in cpp, will be possible to use the python plugin inside the cpp pipeline?
1.If it is just an algorithm for processing data and does not consume too much performance, you can just add a probe function to process the data.
If you want write a new plugin, you should write a c/c++ plugin first and do some binding work for python.
2.No. We suggest you use the cpp plugin directly.
