To mix the Intel and PGI fortran objects into the same executable, requires
some care. You have to decide which compiler will compile sources with I/O stmts, and which compiler is only going to compile subroutines or functions
with a Fortran 77 ‘pass by address’ argument interface. Difficult to debug.
Linking with C objects should be done using ISO_C_BINDINGs, which both
compilers will support.
It may be better to use OpenACC '-ta=tesla,multicore ’ with PGI compilers, and
see if the Phi runs the multicore part (when you set ENV variables to run
on the host only).
Or, create a source that compiles for Phi with Intel compilers,
and compiles for OpenACC/CUDA Fortran with pgfortran.
