Mixing PyNitros and ComposableNode in a same pipeline problem
hi,
I’m testing NVIDIA NITROS like:
  1. Create local camera capturing video NITROS node, publis to topic, second node grab the message and republish, view the raw image.
Custom camera NITROS Node (NITROS message) → Custom forward node (NITROS message, enable_ros_publish=True) → Image View
  1. Create local camera capturing video NITROS node, create launch file for Resize node, second node grab the message and republish, view the raw image
Custom camera NITROS Node (NITROS message) → ResizeNode → Custom forward node (NITROS message, enable_ros_publish=True) → Image View
In the first case all works fine messages are published correctly and I can view the image.
In the second case I do have error and ResizeNode looks like not reciving the messages and nore resizing
Custom image publisher
# local_camera_publisher_node.py
import rclpy
from rclpy.node import Node
from sensor_msgs.msg import Image
from isaac_ros_pynitros.isaac_ros_pynitros_publisher import PyNitrosPublisher
from isaac_ros_pynitros.pynitros_type_builders.pynitros_image_builder import PyNitrosImageBuilder
from isaac_ros_nitros_bridge_interfaces.msg import NitrosBridgeImage
from isaac_ros_nitros_bridge_interfaces.msg import NitrosBridgeImage, NitrosBridgeTensorList
from std_msgs.msg import Header
import cv2
import cupy as cp
class LocalCameraPublisherNode(Node):
    def __init__(self):
        super().__init__('local_camera_publisher_node')
        # Initialize OpenCV VideoCapture for direct camera access
        # self.camera = cv2.VideoCapture(0)  # Use camera index 0 (default camera)
        self.camera = cv2.VideoCapture("video/test.mp4")  # Use camera index 0 (default camera)
        if not self.camera.isOpened():
            self.get_logger().error("Failed to open the camera!")
            return
        # Initialize image builder
        self.pynitros_image_builder = PyNitrosImageBuilder()
        # Initialize NITROS Publisher for scaled images
        # self.pynitros_publisher = PyNitrosPublisher(self, NitrosBridgeImage, '/camera/image', '/camera/image_raw')
        self.pynitros_publisher = PyNitrosPublisher(self, NitrosBridgeImage, '/input_image', '/input_image_raw')
        # Create a timer to periodically capture and process frames
        # self.timer = self.create_timer(0.033, self.capture_and_process_frame)  # ~30 FPS
        self.timer = self.create_timer(0.016, self.capture_and_process_frame)  # ~30 FPS
    def capture_and_process_frame(self):
        """Capture a frame from the camera, process it on the GPU, and publish it."""
        # ret, frame = self.camera.read()
        if not ret:
            self.get_logger().error("Failed to capture frame from the camera!")
            return
        try:
            # Convert frame to GPU array (BGR to RGB conversion)
            rgb_frame = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
            gpu_frame = cp.asarray(rgb_frame, dtype=cp.uint8)
            # Build and publish NITROS message
            nitros_msg = self.build_nitros_image(gpu_frame)
            self.pynitros_publisher.publish(nitros_msg)
        except Exception as e:
            self.get_logger().error(f"Error processing image: {e}")
    def gpu_resize(self, frame, target_size):
        """Resize the image on the GPU."""
        return cp.resize(frame, target_size)
    def build_nitros_image(self, gpu_data):
        """Build a NITROS-compatible Image message."""
        header = Header()
        header.frame_id = "camera_frame"  # Set frame ID
        header.stamp = self.get_clock().now().to_msg()  # Set timestamp
        built_image = self.pynitros_image_builder.build(gpu_data[0].data.ptr,
                                                        int(gpu_data.shape[0]),
                                                        int(gpu_data.shape[1]),
                                                        int(gpu_data.shape[1] * 3),
                                                        # 'rgb8',
                                                        'nitros_image_bgr8',
                                                        header,
                                                        0,
                                                        False)
        return built_image
    def destroy_node(self):
        """Release resources when shutting down the node."""
        if hasattr(self, 'camera') and self.camera.isOpened():
            self.camera.release()
        super().destroy_node()
def main(args=None):
    rclpy.init(args=args)
    node = LocalCameraPublisherNode()
    try:
        rclpy.spin(node)
    except KeyboardInterrupt:
        pass
    finally:
        node.destroy_node()
        # only shut down if context is active
        if rclpy.ok():
            rclpy.shutdown()
if __name__ == '__main__':
    main()
import launch
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
def generate_launch_description():
    resize_node = ComposableNode(
        package='isaac_ros_image_proc',
        plugin='nvidia::isaac_ros::image_proc::ResizeNode',
        name='resize',
        parameters=[{
            'output_width': 480,
            'output_height': 288,
            'enable_isp': False
        remappings=[
            ('image', 'input_image'),
            ('camera_info', 'input_image_info'),
            ('resize/image', '/resized_image'),
    resize_container = ComposableNodeContainer(
        package='rclcpp_components',
        name='resize_container',
        namespace='',
        executable='component_container_mt',
        composable_node_descriptions=[
            resize_node,
        output='screen'
    return launch.LaunchDescription([resize_container])
Node forwarding the image
# SPDX-FileCopyrightText: NVIDIA CORPORATION & AFFILIATES
# Copyright (c) 2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
# SPDX-License-Identifier: Apache-2.0
from isaac_ros_pynitros.isaac_ros_pynitros_subscriber import PyNitrosSubscriber
import rclpy
import torch
class PyNITROSImageForwardNode(Node):
    """A PyNITROS node listens to image message and publish it again."""
    def __init__(self, name='local_camera_crop_publisher_node'):
        super().__init__(name)
        self.pynitros_subscriber = PyNitrosSubscriber(
            self, NitrosBridgeImage, '/resized_image',
            enable_ros_subscribe=False)
        self.pynitros_subscriber.create_subscription(self.listener_callback)
        #     self, NitrosBridgeImage, '/camera/forward/image', '/camera/forward/image_raw')
            self, NitrosBridgeImage, '/forward_image', '/forward_image_raw')
            num_buffer=40, timeout=5)
    def listener_callback(self, pynitros_image_view):
        # Build Image
        header = Header()
        header.frame_id = pynitros_image_view.get_frame_id()
        header.stamp.sec = pynitros_image_view.get_timestamp_seconds()
        header.stamp.nanosec = pynitros_image_view.get_timestamp_nanoseconds()
        # Get data as tensor, or any other data type supports __cuda_array_interface__
        # image_tensor = torch.as_tensor(pynitros_image_view, dtype=torch.uint8, device=gpu)
        built_image = self.pynitros_image_builder.build(pynitros_image_view.get_buffer(),
                                                        pynitros_image_view.get_height(),
                                                        pynitros_image_view.get_width(),
                                                        pynitros_image_view.get_stride(),
                                                        pynitros_image_view.get_encoding(),
                                                        header,
                                                        0,
                                                        True)
        # Publish
        self.pynitros_publisher.publish(built_image)
    try:
        node = PyNITROSImageForwardNode()
        rclpy.spin(node)
        pass
    finally:
        node.destroy_node()
        if rclpy.ok():
            rclpy.shutdown()
    main()
and the error
ros2 launch test_suite test_suite.launch.py
[INFO] [launch]: All log files can be found below /home/user/.ros/log/2025-03-24-15-45-30-946514-atoMix-54525
[INFO] [launch]: Default logging verbosity is set to INFO
[INFO] [component_container_mt-1]: process started with pid [54537]
[component_container_mt-1] [INFO] [1742827531.255290320] [resize_container]: Load Library: /home/user/workspaces/isaac_ros-dev/install/isaac_ros_image_proc/lib/libresize_node.so
[component_container_mt-1] [INFO] [1742827531.272925262] [resize_container]: Found class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ResizeNode>
[component_container_mt-1] [INFO] [1742827531.272955478] [resize_container]: Instantiate class: rclcpp_components::NodeFactoryTemplate<nvidia::isaac_ros::image_proc::ResizeNode>
[component_container_mt-1] [INFO] [1742827531.300563007] [resize]: [NitrosNode] Initializing NitrosNode
[component_container_mt-1] [INFO] [1742827531.300968872] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/std/libgxf_std.so
[component_container_mt-1] [INFO] [1742827531.301786731] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_gxf_helpers.so
[component_container_mt-1] [INFO] [1742827531.303415861] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_sight.so
[component_container_mt-1] [INFO] [1742827531.306175445] [NitrosContext]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_atlas.so
[component_container_mt-1] 2025-03-24 15:45:31.311 WARN  gxf/std/program.cpp@538: No GXF scheduler specified.
[component_container_mt-1] [INFO] [1742827531.311454549] [resize]: [NitrosNode] Starting NitrosNode
[component_container_mt-1] [INFO] [1742827531.316294430] [resize]: [NitrosNode] Loading extensions
[component_container_mt-1] [INFO] [1742827531.316566185] [resize]: [NitrosContext] Loading extension: gxf/lib/multimedia/libgxf_multimedia.so
[component_container_mt-1] [INFO] [1742827531.316816811] [resize]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_message_compositor.so
[component_container_mt-1] [INFO] [1742827531.317189871] [resize]: [NitrosContext] Loading extension: gxf/lib/cuda/libgxf_cuda.so
[component_container_mt-1] [INFO] [1742827531.318703945] [resize]: [NitrosContext] Loading extension: gxf/lib/libgxf_isaac_tensorops.so
[component_container_mt-1] [INFO] [1742827531.321281178] [resize]: [NitrosNode] Loading graph to the optimizer
[component_container_mt-1] [INFO] [1742827531.323157165] [resize]: [NitrosNode] Running optimization
[component_container_mt-1] [INFO] [1742827531.428042102] [resize]: [NitrosNode] Obtaining graph IO group info from the optimizer
[component_container_mt-1] [INFO] [1742827531.433741423] [resize]: [NitrosNode] Starting negotiation...
[INFO] [launch_ros.actions.load_composable_nodes]: Loaded node '/resize' in container '/resize_container'
[component_container_mt-1] [INFO] [1742827532.434250317] [resize]: [NitrosNode] Starting post negotiation setup
[component_container_mt-1] [INFO] [1742827532.434393958] [resize]: [NitrosNode] Getting data format negotiation results
[component_container_mt-1] [INFO] [1742827532.434430127] [resize]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1742827532.434447084] [resize]: [NitrosPublisher] Use only the compatible publisher: topic_name="/resized_image", data_format="nitros_image_bgr8"
[component_container_mt-1] [INFO] [1742827532.434463143] [resize]: [NitrosPublisher] Negotiation ended with no results
[component_container_mt-1] [INFO] [1742827532.434475937] [resize]: [NitrosPublisher] Use only the compatible publisher: topic_name="/resize/camera_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1742827532.434497427] [resize]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1742827532.434512038] [resize]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/input_image", data_format="nitros_image_bgr8"
[component_container_mt-1] [INFO] [1742827532.434530921] [resize]: [NitrosSubscriber] Negotiation ended with no results
[component_container_mt-1] [INFO] [1742827532.434543030] [resize]: [NitrosSubscriber] Use the compatible subscriber: topic_name="/input_image_info", data_format="nitros_camera_info"
[component_container_mt-1] [INFO] [1742827532.434885703] [resize]: [NitrosNode] Exporting the final graph based on the negotiation results
[component_container_mt-1] [INFO] [1742827532.441369046] [resize]: [NitrosNode] Wrote the final top level YAML graph to "/tmp/isaac_ros_nitros/graphs/JONFMGFGAI/JONFMGFGAI.yaml"
[component_container_mt-1] [INFO] [1742827532.441390308] [resize]: [NitrosNode] Loading application
[component_container_mt-1] [INFO] [1742827532.442987107] [resize]: [ResizeNode] postLoadGraphCallback().
[component_container_mt-1] [INFO] [1742827532.443031528] [resize]: [NitrosNode] Initializing and running GXF graph
[component_container_mt-1] [INFO] [1742827532.562866051] [resize]: [NitrosNode] Node was started
Any advise what the problem can be?
Hi @atanasko.mitrev
Thank you for your post.
Looking at your logs, there may be a reason that the resize node doesn’t receive any synced pair message from camera_info and doesn’t publish anything.
Please check if the topics are publishing the messages.
Best,
Raffaello
Hi @Raffaello,
Thanks for your support! Is it possible at all to send camera_info message of type NitrosCameraInfo using PyNitros? I’m trying to prototype POC and implement camera image publisher using PyNitoros but PyNitoros may not be mature enough for this.
Hi @atanasko.mitrev
PyNITROS currently supports only images and TensorList, which contain large amounts of data. However, you can use any ROS message types in conjunction with PyNITROS messages by utilizing the PyNitrosMessageFilter.
This example can be used to synchronize the PyNITROS image with the ROS camera info.
Best,
Raffaello
Hi @Raffaello,
Thank you! I will have a look and test this.
Best regards,
Atanasko
