Hi. I’m having trouble creating a directory as root on one of the Xavier cores. I’m connected to it via ssh.
# echo $USER
root
# pwd
/root
# mkdir test
mkdir: test: No such file or directory
What steps can I take to see what is wrong here?
Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
I have already performed this modification prior to flashing:
Change drive-t186ref-foundation/virtualization/pct/e3550b03-t194 a /qnx/boot_chain_storage_qspi.cfg file to +virtual_storage_ivc_ch=0x8<GID_VSC_SERVER>800623 from -virtual_storage_ivc_ch=0x8<GID_VSC_SERVER>810623
also I removed read-only statements from:
/drive-t186ref-qnx/bsp/device-tree/qnx-device-tree/platform/t19x/common/storage/tegra194-drive-storage-common-qnx-vm1.dtsi
# mkqnx6fs /dev/vblk_mnand1
All files on /dev/vblk_mnand1 will be lost!
Confirm filesystem re-format (y) or (n): y
Format fs-qnx6: 2097148 blocks, 65536 inodes, 8 groups
# mount /dev/vblk_mnand1 /mnt
mount: Can't mount /mnt (type qnx6)
mount: Possible reason: Permission denied
