I’m running the following:
Windows 10.0.19044
WSL Ubuntu 22.04.1. LTS
Jetson Linux 35.1.0
I’ve got some limitations and am unable to get a linux system on bare metal, so I’m using WSL as a stand-in. I created a back up of my Jetson and am seeking to create a sparse image that I can later flash to another Jetson.
I am following the Quick Start Guide and do not get a success statement when I run the apply_binaries script. Instead, I get the following error message chroot: failed to run command ‘dpkg’: Exec format error. I made sure that qemu-user-static is installed on this system.
user@host:~$ ls
Jetson_Linux_R35.1.0_aarch64.tbz2 Linux_for_Tegra Tegra_Linux_Sample-Root-Filesystem_R35.1.0_aarch64.tbz2 jetsonimage nvidia.txt old
user@host:~$ tar xf Jetson_Linux_R35.1.0_aarch64.tbz2
user@host:~$ cd Linux_for_Tegra/rootfs/
user@host:~/Linux_for_Tegra/rootfs$ sudo tar xpf …/…/Tegra_Linux_Sample-Root-Filesystem_R35.1.0_aarch64.tbz2
user@host:~/Linux_for_Tegra/rootfs$ cd …
user@host:~/Linux_for_Tegra$ sudo ./apply_binaries.sh
Using rootfs directory of: /home/user/Linux_for_Tegra/rootfs
Installing extlinux.conf into /boot/extlinux in target rootfs
/home/user/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
Root file system directory is /home/user/Linux_for_Tegra/rootfs
Copying public debian packages to rootfs
Start L4T BSP package installation
QEMU binary is not available, looking for QEMU from host system
Found /usr/bin/qemu-aarch64-static
Installing QEMU binary in rootfs
/home/user/Linux_for_Tegra/rootfs /home/user/Linux_for_Tegra
Installing BSP Debian packages in /home/user/Linux_for_Tegra/rootfs
Probably for related reasons the ./mksparse command also does not work and spits back this error.
user@host:~/Linux_for_Tegra/bootloader$ sudo ./mksparse -v --fillpattern=0 ~/jetsonimage/20220811wavijet.raw ~/jetsonimage/system.img
./mksparse: 1: Syntax error: “(” unexpected
Any guidance on this issue would be greatly appreciated
