-Mlarge_arrays netcdf 3.6.0-p1
Hi all,
I am trying to compile netCDF with large array support and the fortran 90 interface. However I am miserably failing. My strong suspicion is that the size intrinsic and friends does not return default kind integers when code compiled with -Mlarge_arrays. The f90 interface therefore fails to build. Has anyone managed to get around this problem or any suggestions are welcome.
Cheers
magnus
Hi Magnus,
Are you getting something like this?
pgf90 -c -Msignextend -fastsse -Mlarge_arrays  -Vdev    netcdf.f90
PGF90-S-0095-Expression has wrong data type (./netcdf_text_variables.f90: 57)
  0 inform,   0 warnings,   1 severes, 0 fatal for nf90_put_var_1d_text
Excert from “netcdf_text_variables.f90”:
     integer, dimension(nf90_max_var_dims) :: localStart, localCount, localStride, localMap
     integer                               :: counter
     localStart (:         ) = 1
     localCount ( :numDims+1) = (/ len(values(1)), shape(values) /)
     localCount (numDims+2:) = 0
The problem here that localCount is an integer, however when you use “-Mlarge_arrays”, the data type of array intrinsics, i.e. SHAPE, LBOUND, UBOUND, etc, becomes INTEGER*8. When I change all the SHAPE calls to “int(shape(values))”, NetCDF compiles and the fortran tests run correctly.
Hope this helps,
Mat
