Mlnx-en-5.7-1.0.2.0-rhel9.0 - error: /mnt/RPMS: read failed: Is a directory (21)
Hello Forum,
i am trying to install the NVIDIA/MELLANOX drivers from
  1. MLNX_EN-5.7-1.0.2.0/mlnx-en-5.7-1.0.2.0-rhel9.0-x86_64.iso for
  2. ConnectX-5 EN (pure ethernet),
    on CentOS9 or RockyLinux 9.0
    but the included evaluation script “is_kmp_compat.sh” is always failing when attempting to install the packages according to the guide on “https://docs.nvidia.com/networking/display/MLNXENv571020/Installing+MLNX_EN”.
Core error message:
Applied procedure:
  1. wget … MLNX_EN-5.7-1.0.2.0/mlnx-en-5.7-1.0.2.0-rhel9.0-x86_64.iso [abbreviated because not allowed more then 1 link per post]
  2. mount -o ro,loop mlnx-en-5.7-1.0.2.0-rhel9.0-x86_64.iso /mnt
  3. cd /mnt
  4. bash --debug is_kmp_compat.sh --path /mnt/RPMS --kernel $(uname -r)
  5. error: /mnt/RPMS: read failed: Is a directory (21)
I drilled down to where the procedure breaks:
$RPM -i --nodeps --notriggers --noscripts --root $tmpdir "$fff"
Attempting to reproduce it:
rpm -vv --test --nodigest --nosignature -i --nodeps --notriggers --noscripts --root /tmp/kmp_check.a6cssCN /mnt/RPMS
ufdio:       1 reads,    17654 total bytes in 0.000009 secs
D: ============== /mnt/RPMS
ufdio:       1 reads,        0 total bytes in 0.000002 secs
error: /mnt/RPMS cannot be installed
D: 	added source package [0]
D: found 1 source and 0 binary packages
D: Exit status: 1
I doublechecked for the presence of ACLs, SELinux labels or filesystem permissions.
Also tried directories outside of “/tmp” and “/mnt”.
But nothing helped the problem.
I just want to make sure the evaluation skript would not indicate incompatibility for the wrong reasons…
Has anyone an idea what actually is the problem?
Any idea would be highly appreciated.
Best
Hello again,
i just wanted to update, that apparently the error message can be read verbatim:
it simply attempts to read the directory.
Pointing it directly to the files would make it operable:
rpm -vvvvv --test \
--nodigest --nosignature -i --nodeps --notriggers --noscripts \
--root /tmp/kmp_check.a6cssCN /mnt/RPMS/*.rpm
But that format again is not what “is_kmp_compat.sh” expects:
bash --verbose is_kmp_compat.sh -\
-path /mnt/RPMS/*.rpm --kernel $(uname -r)
    -E- Unsupported option: /mnt/RPMS/ibacm-56mlnx40-1.57102.x86_64.rpm
which also would contradict the name of the option (path)…
Do i possibly use the wrong syntax for the options?
Best
Thanks for contacting us.
From looking at the issue and the details you have added these versions of Rocky9.0 or Centos 9.0 have not been tests and are supported yet.
Please visit this link to see which OSs have been tested and supported with the last versions of MOFED 5.7-1.0.2.0
https://network.nvidia.com/products/infiniband-drivers/linux/mlnx_ofed/
Rocky 9 will be supported in future releases.
Thanks and have a great day!
Ilan.
Hi ipavis,
please excuse my late replay.
Thank you very much for your answer.
This will be great, if Rocky will be officially supported in the future, since we haved switched to it completely.
For the time being, the way to go about it seems to be to look up the sources under
Linux InfiniBand Drivers / Community / rpm”
and compile them.
Best
