MLNX_ofed 23.07 and Rocky Linux 9.2
When using OFED dnf/yum repository I’m getting the following error when installing mlnx-ofed-all package:
Error:
Problem: package mlnx-ofed-all-23.07-0.5.1.2.rhel9.2.noarch requires kmod-isert >= 23.07-OFED.23.07.0.5.1.1.rhel9u2, but none of the providers can be installed
  • conflicting requests
  • nothing provides kernel(iscsit_check_dataout_hdr) = 0xb89b39c3 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_handle_task_mgt_cmd) = 0xdbc3ab34 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_logout_post_handler) = 0x3c58c6e4 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_build_text_rsp) = 0x610bf65d needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_setup_nop_out) = 0xcbb2fab5 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_setup_text_cmd) = 0xaef8a564 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_process_nop_out) = 0xba888983 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_build_reject) = 0x97920840 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_build_logout_rsp) = 0x79c57adb needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_set_unsolicited_dataout) = 0xcf2e6bde needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_process_scsi_cmd) = 0x9304d343 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_build_nopin_rsp) = 0xe9cf820a needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_build_task_mgt_rsp) = 0xfd03a74f needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_process_text_cmd) = 0xfdd940f7 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_build_rsp_pdu) = 0xe300c1ed needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_setup_scsi_cmd) = 0xb27bbafd needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_check_dataout_payload) = 0xc28e9ec1 needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
  • nothing provides kernel(iscsit_handle_logout_cmd) = 0x835fd1ef needed by kmod-isert-23.07-OFED.23.07.0.5.1.1.rhel9u2.x86_64
Kernel version: kernel-5.14.0-284.30.1.el9_2.x86_64
cat /etc/os-release
NAME=“Rocky Linux”
VERSION=“9.2 (Blue Onyx)”
ID=“rocky”
ID_LIKE=“rhel centos fedora”
VERSION_ID=“9.2”
PLATFORM_ID=“platform:el9”
PRETTY_NAME=“Rocky Linux 9.2 (Blue Onyx)”
ANSI_COLOR=“0;32”
LOGO=“fedora-logo-icon”
CPE_NAME=“cpe:/o:rocky:rocky:9::baseos”
HOME_URL=“https://rockylinux.org/
BUG_REPORT_URL=“https://bugs.rockylinux.org/
SUPPORT_END=“2032-05-31”
ROCKY_SUPPORT_PRODUCT=“Rocky-Linux-9”
ROCKY_SUPPORT_PRODUCT_VERSION=“9.2”
REDHAT_SUPPORT_PRODUCT=“Rocky Linux”
REDHAT_SUPPORT_PRODUCT_VERSION=“9.2”
Thanks for your question.
The kmod-isert package is present in the repository and should be available.
https://linux.mellanox.com/public/repo/mlnx_ofed/latest-23.07/rhel9.2/x86_64/
I would suggest to double-check if no leftovers from previous installation are present on the system, and it definitely booted to the correct kernel when you are trying to install OFED.
Otherwise we will need to perform a deeper check of your system and installation logs, which may require to open a support case in Nvidia portal, and it will be handled according to the entitlement.
Best Regards,
Anatoly
