Hi Steve,
sorry for not answering, but I was out of the office.
The NIC type according to lspci is MT27700
The command I used:
sudo mlnx_qos -i enp6s0f1 -p 0,1,2,3,4,5,6,7
The output: Netlink error: Bad value. see dmesg.
And the output of dmesg related to mlx
11.872656] mlx5_core 0000:06:00.0: firmware version: 12.21.2010
[ 13.604119] mlx5_core 0000:06:00.0: Port module event: module 0, Cable plugged
[ 13.614789] mlx5_core 0000:06:00.1: firmware version: 12.21.2010
[ 15.059230] mlx5_core 0000:06:00.1: Port module event: module 1, Cable plugged
[ 15.148425] mlx5_core 0000:06:00.0: MLX5E: StrdRq(0) RqSz(1024) StrdSz(1) RxCqeCmprss(0)
[ 15.442744] mlx5_core 0000:06:00.1: MLX5E: StrdRq(0) RqSz(1024) StrdSz(1) RxCqeCmprss(0)
[ 15.762845] mlx5_core 0000:06:00.0 enp6s0f0: renamed from eth0
[ 15.820204] mlx5_core 0000:06:00.1 enp6s0f1: renamed from eth1
[ 28.629317] mlx5_ib: Mellanox Connect-IB Infiniband driver v4.2-1.2.0
[ 215.304044] mlx5_core 0000:06:00.1 enp6s0f1: mlx5e_update_carrier:153: Link up
And I also attach the output of mlxconfig.
Device #1:
Device type: ConnectX4
Description: N/A
Device: /dev/mst/mt4115_pciconf0
Configurations: Next Boot
MEMIC_BAR_SIZE 0
MEMIC_SIZE_LIMIT _256KB(1)
ROCE_NEXT_PROTOCOL 254
NON_PREFETCHABLE_PF_BAR False(0)
NUM_OF_VFS 32
FPP_EN True(1)
SRIOV_EN True(1)
PF_LOG_BAR_SIZE 5
VF_LOG_BAR_SIZE 0
NUM_PF_MSIX 63
NUM_VF_MSIX 11
INT_LOG_MAX_PAYLOAD_SIZE AUTOMATIC(0)
CQE_COMPRESSION BALANCED(0)
IP_OVER_VXLAN_EN False(0)
LRO_LOG_TIMEOUT0 6
LRO_LOG_TIMEOUT1 7
LRO_LOG_TIMEOUT2 8
LRO_LOG_TIMEOUT3 12
LOG_DCR_HASH_TABLE_SIZE 14
DCR_LIFO_SIZE 16384
ROCE_CC_PRIO_MASK_P1 255
ROCE_CC_ALGORITHM_P1 ECN(0)
ROCE_CC_PRIO_MASK_P2 255
ROCE_CC_ALGORITHM_P2 ECN(0)
CLAMP_TGT_RATE_AFTER_TIME_INC_P1 True(1)
CLAMP_TGT_RATE_P1 False(0)
RPG_TIME_RESET_P1 300
RPG_BYTE_RESET_P1 32767
RPG_THRESHOLD_P1 1
RPG_MAX_RATE_P1 0
RPG_AI_RATE_P1 5
RPG_HAI_RATE_P1 50
RPG_GD_P1 11
RPG_MIN_DEC_FAC_P1 50
RPG_MIN_RATE_P1 1
RATE_TO_SET_ON_FIRST_CNP_P1 0
DCE_TCP_G_P1 1019
DCE_TCP_RTT_P1 1
RATE_REDUCE_MONITOR_PERIOD_P1 4
INITIAL_ALPHA_VALUE_P1 1023
MIN_TIME_BETWEEN_CNPS_P1 0
CNP_802P_PRIO_P1 6
CNP_DSCP_P1 48
CLAMP_TGT_RATE_AFTER_TIME_INC_P2 True(1)
CLAMP_TGT_RATE_P2 False(0)
RPG_TIME_RESET_P2 300
RPG_BYTE_RESET_P2 32767
RPG_THRESHOLD_P2 1
RPG_MAX_RATE_P2 0
RPG_AI_RATE_P2 5
RPG_HAI_RATE_P2 50
RPG_GD_P2 11
RPG_MIN_DEC_FAC_P2 50
RPG_MIN_RATE_P2 1
RATE_TO_SET_ON_FIRST_CNP_P2 0
DCE_TCP_G_P2 1019
DCE_TCP_RTT_P2 1
RATE_REDUCE_MONITOR_PERIOD_P2 4
INITIAL_ALPHA_VALUE_P2 1023
MIN_TIME_BETWEEN_CNPS_P2 0
CNP_802P_PRIO_P2 6
CNP_DSCP_P2 48
LLDP_NB_DCBX_P1 False(0)
LLDP_NB_RX_MODE_P1 OFF(0)
LLDP_NB_TX_MODE_P1 OFF(0)
LLDP_NB_DCBX_P2 False(0)
LLDP_NB_RX_MODE_P2 OFF(0)
LLDP_NB_TX_MODE_P2 OFF(0)
DCBX_IEEE_P1 True(1)
DCBX_CEE_P1 True(1)
DCBX_WILLING_P1 True(1)
DCBX_IEEE_P2 True(1)
DCBX_CEE_P2 True(1)
DCBX_WILLING_P2 True(1)
KEEP_ETH_LINK_UP_P1 True(1)
KEEP_IB_LINK_UP_P1 False(0)
KEEP_LINK_UP_ON_BOOT_P1 False(0)
KEEP_LINK_UP_ON_STANDBY_P1 False(0)
KEEP_ETH_LINK_UP_P2 True(1)
KEEP_IB_LINK_UP_P2 False(0)
KEEP_LINK_UP_ON_BOOT_P2 False(0)
KEEP_LINK_UP_ON_STANDBY_P2 False(0)
NUM_OF_VL_P1 _4_VLs(3)
NUM_OF_TC_P1 _8_TCs(0)
NUM_OF_PFC_P1 8
NUM_OF_VL_P2 _4_VLs(3)
NUM_OF_TC_P2 _8_TCs(0)
NUM_OF_PFC_P2 8
DUP_MAC_ACTION_P1 LAST_CFG(0)
SRIOV_IB_ROUTING_MODE_P1 False(0)
IB_ROUTING_MODE_P1 LID(1)
DUP_MAC_ACTION_P2 LAST_CFG(0)
SRIOV_IB_ROUTING_MODE_P2 False(0)
IB_ROUTING_MODE_P2 LID(1)
MULTI_PORT_VHCA_EN False(0)
PORT_OWNER True(1)
ALLOW_RD_COUNTERS True(1)
RENEG_ON_CHANGE True(1)
TRACER_ENABLE False(0)
IP_VER IPv4(0)
UEFI_HII_EN True(1)
BOOT_VLAN 1
LEGACY_BOOT_PROTOCOL PXE(1)
BOOT_RETRY_CNT NONE(0)
BOOT_LACP_DIS False(0)
BOOT_VLAN_EN False(0)
BOOT_PKEY 0
UEFI_BOOT_DBG_LOG_TCP DISABLE(0)
UEFI_BOOT_DBG_LOG_TCPIP DISABLE(0)
UEFI_BOOT_DBG_LOG_IP DISABLE(0)
UEFI_BOOT_DBG_LOG_IPV6 DISABLE(0)
UEFI_BOOT_DBG_LOG_DRIVER_SETTINGS DISABLE(0)
UEFI_BOOT_DBG_LOG_STATUS DISABLE(0)
UEFI_BOOT_DBG_LOG_PXE_UNDI DISABLE(0)
ADVANCED_PCI_SETTINGS False(0)
