mlnxofedinstall of 4.3-3.0.2.1-rhel7.5alternate-aarch64 has some checking bug need to be fixed
It seems that the RedHat has changed the naming conventions of some RPM packages. In the file “centos-release-7-5.*aarch64” rpm packages, the letter “a” is used instead of the full name “alternate”.
So in the script, the checking will fail and refuse to install the package.
# } elsif ($dist_rpm =~ /redhat-release-.*-7.5.*el7a|sl-release-7.5.*el7a|centos-release-7-5.*el7.centos.altarch/) {
} elsif ($dist_rpm =~ /redhat-release-.*-7.5.*el7a|sl-release-7.5.*el7a|centos-release-7-5.el7.centos.a/) {
I tried this WA. Would you please give some official solution for this?
Can you show me your output of
rpm -qf /etc/issue on your Centos 7.4 and 7.5 to see the difference
dist_rpm use this output to check after the lines you refer to.
Marc
I have here a machine with Centos 7.5 on ARM and cannot see the same output.
I would like to investigate it even if you already a workaround.
For this purpose, I need you to open a case at support@mellanox.com mailto:support@mellanox.com
Thanks in advance
Marc
Hi Marc,
rpm -qf /etc/issue
centos-release-7-5.1804.el7.centos.a.aarch64
In the CentOS 7.5 release
http://mirror.centos.org/altarch/7.5.1804/updates/aarch64/Packages/centos-release-7-5.1804.el7.centos.a.2.aarch64.rpm http://mirror.centos.org/altarch/7.5.1804/updates/aarch64/Packages/centos-release-7-5.1804.el7.centos.a.2.aarch64.rpm
In the last release
Index of /altarch/7.4.1708/updates/aarch64/Packages http://vault.centos.org/altarch/7.4.1708/updates/aarch64/Packages/
centos-release-7-4.1708.el7.centos.altarch.1.aarch64.rpm http://vault.centos.org/altarch/7.4.1708/updates/aarch64/Packages/centos-release-7-4.1708.el7.centos.altarch.1.aarch64.rpm
You can see that the the naming conventions are a little different of altarch aarch64. I have no idea of this package’s name on the Power. Many thanks
