if you would like try to run :
make run RUN_ARGS="--benchmarks=resnet50 --scenarios=Offline --test_mode=AccuracyOnly"
And then you can compare with my results above to see if you got the same error log. to see if the CUDA-X had change anything or not concerning the plugins.
