We are using MLX90640 thermal camera sensor as an I2C device able to detect it as an i2c device, while running the above application the temperature values are changing with drastic changes.
We assume this is not the expected behaviour of the application
can you please suggest any other application to test the MLX90640 thermal camera on AGX-xavier.
by checking the MLX90640 datasheets for Melexis’ 32x24 infrared (IR) sensor array.
this isn’t using CSI interface. it’s using i2c protocol to communicate with the device directly.
please refer to 1_mlx90640.py to extract the thermal data.
