MlxNdPerf.exe successfully ran on one computer but failed on the second computer
2 computers are connected via fiber optics and can ping itself and other.
MlxNdPerf.exe cannot started as Server on one computer: MlxNdPerf.exe error message below:
ERROR: ndStartUp failed, Could not load provider, hr = 0xc00000bb
Any idea where I can look to resolve this problem?
Looks like you not install ND provider.
Run “ndinstall -l” to see a list of installed ND Providers:
Current providers:
0000001001 - Hyper-V RAW
0000001006 - MSAFD Tcpip [TCP/IP]
0000001007 - MSAFD Tcpip [UDP/IP]
0000001008 - MSAFD Tcpip [RAW/IP]
0000001009 - MSAFD Tcpip [TCP/IPv6]
0000001010 - MSAFD Tcpip [UDP/IPv6]
0000001011 - MSAFD Tcpip [RAW/IPv6]
0000001016 - RSVP TCPv6 Service Provider
0000001017 - RSVP TCP Service Provider
0000001018 - RSVP UDPv6 Service Provider
0000001019 - RSVP UDP Service Provider
0000001055 - NDv1 Provider for Mellanox WinOF-2
0000001056 - NDv2 Provider for Mellanox WinOF-2
Run “ndinstall -i” to install all available NVIDIA® ND Providers.
Installing mlx5nd provider: successful
Installing mlx5nd2 provider: successful
Current providers:
Thank you very much for your reply. I am using the Mellanox NIC on a different project with another system disk that does not have the same problem. I will reboot from the problem system disk to check and confirm your suggestion. My strong impression is that your suggestion will solve the problem based on the error code which I looked up from the NetDirect winDDK source code.
Hi, I reboot from the ‘problem’ system disk. This is what I got:
ndinstall -l
Current providers:
0000001001 - MSAFD Tcpip [TCP/IP]
0000001002 - MSAFD Tcpip [UDP/IP]
0000001003 - MSAFD Tcpip [RAW/IP]
0000001004 - MSAFD Tcpip [TCP/IPv6]
0000001005 - MSAFD Tcpip [UDP/IPv6]
0000001006 - MSAFD Tcpip [RAW/IPv6]
0000001007 - AF_UNIX
0000001008 - RSVP TCPv6 Service Provider
0000001009 - RSVP TCP Service Provider
0000001010 - RSVP UDPv6 Service Provider
0000001011 - RSVP UDP Service Provider
0000001012 - Hyper-V RAW
0000001013 - MSAFD L2CAP [Bluetooth]
0000001014 - MSAFD RfComm [Bluetooth]
0000001015 - NDv1 Provider for Mellanox WinOF-2
0000001016 - NDv2 Provider for Mellanox WinOF-2
I have 2 other Mellanox OFED working system disks that I can use right now. I can wait to solve this mystery later on. Thanks for your assistance.
