li_lin
June 16, 2017, 9:31am
1
I modified the 00_video_decode sample.
I tried this change, but the program does not work properly
ret = ctx->conv->setCapturePlaneFormat( V4L2_PIX_FMT_YUV420,
crop.c.width,
crop.c.height,
V4L2_NV_BUFFER_LAYOUT_BLOCKLINEAR);
Hi LI, we support V4L2_PIX_FMT_YUV420M only.
li_lin
June 19, 2017, 5:02am
3
Hi DaneLLL:
Why in the 00_video_decode ,conv only support V4L2_NV_BUFFER_LAYOUT_PITCH, NV12M and YUV420M, but 07_video_convert can be converted to a variety of formats?
Hi Li, in 07_video_convert, YUY420M and NV12M are listed.
ubuntu@tegra-ubuntu:~/tegra_multimedia_api/samples/07_video_convert$ ./video_convert --help
video-convert <in-file> <in-width> <in-height> <in-format> <out-file> <out-width> <out-height> <out-format> [OPTIONS]
Supported formats:
YUV420M
YVU420M
NV12M
YUV444M
YUV422M
YUYV
YVYU
UYVY
VYUY
ABGR32
XRGB32
GREY
OPTIONS:
-h,--help Prints this text
--dbg-level <level> Sets the debug level [Values 0-3]
--input-raw Input will be raw buffer
--input-nvpl Input will be NV PL buffer [Default]
--input-nvbl Input will be NV BL buffer
--output-raw Output will be raw buffer
--output-nvpl Output will be NV PL buffer [Default]
--output-nvbl Output will be NV BL buffer
-cr <left> <top> <width> <height> Set the cropping rectangle [Default = 0 0 0 0]
-fm <method> Flip method to use [Default = 0]
-im <method> Interpolation method to use [Default = 1]
-tnr <algo> TNR algorithm to use [Default = 0]
NOTE: TNR is supported for YUV420M, NV12M, YUYV and UYVY formats
Allowed values for flip method:
0 = Identity(no rotation) 1 = 90 degree counter-clockwise rotation
2 = 180 degree rotation 3 = 90 degree clockwise rotation
4 = Horizontal flip 5 = Flip across upper right/lower left diagonal
6 = Vertical flip 7 = Flip across upper left/lower right diagonal
Allowed values for interpolation method:
1 = nearest 2 = linear
3 = smart 4 = bilinear
Allowed values for tnr:
0 = Original 1 = Outdoor low light
2 = Outdoor medium light 3 = Outdoor high light
4 = Indoor low light 5 = Indoor medium light
6 = Indoor high light
Which format is supported in 07_video_convert but not supported in 00_video_decode?
li_lin
June 19, 2017, 6:47am
5
Hi,DaneLLL,
07_video_convert can set conv’s captureplane output format to V4L2_NV_BUFFER_LAYOUT_BLOCKLINEAR
But 00_video_decode can not
Hi Li,
Please apply the following logic from 07_video_convert to 00_video_decode and give it a try
else if (ctx.in_buftype == BUF_TYPE_NVBL || ctx.out_buftype == BUF_TYPE_NVBL)
ret = ctx.conv0->capture_plane.setupPlane(V4L2_MEMORY_MMAP, 10, false, false);
