Hi:
I test mmapi sample “12_camera_v4l2_cuda”, and command is
./camera_v4l2_cuda -d /dev/video0 -s 1920x1080 -f UYVY -r 60
I found convertvideo is time-consuming, about 10ms. It seems to be abnormal. I added some time print, and found most time-consuming is “lane->dqBuffer(v4l2_buf, &buffer, &shared_buffer, -1)” at dpThread.
void *
NvV4l2ElementPlane::dqThread(void *data)
NvV4l2ElementPlane *plane = (NvV4l2ElementPlane *) data;
const char *comp_name = plane->comp_name;
const char *plane_name = plane->plane_name;
PLANE_DEBUG_MSG("Starting DQthread");
prctl (PR_SET_NAME, plane_name, 0, 0, 0);
plane->stop_dqthread = false;
while (!plane->stop_dqthread)
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[MAX_PLANES];
NvBuffer *buffer;
NvBuffer *shared_buffer;
bool ret;
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, sizeof(planes));
v4l2_buf.m.planes = planes;
v4l2_buf.length = plane->n_planes;
if (plane->dqBuffer(v4l2_buf, &buffer, &shared_buffer, -1) < 0)
if (errno != EAGAIN)
plane->is_in_error = 1;
if (errno != EAGAIN || plane->streamon)
ret = plane->callback(NULL, NULL, NULL, plane->dqThread_data);
if (!plane->streamon)
break;
else
ret = plane->callback(&v4l2_buf, buffer, shared_buffer,
if (!ret)
break;
pthread_mutex_lock(&plane->plane_lock);
plane->dqthread_running = false;
pthread_cond_broadcast(&plane->plane_cond);
pthread_mutex_unlock(&plane->plane_lock);
PLANE_DEBUG_MSG("Exiting DQthread");
return NULL;
Is it normal ? How to reduce time-consuming ?
I’ll be looking forward to your reply!
