“mmc0: cache flush error -110” during Orin work
Hello, We encountered an issue with eMMC when using the Orin module.
During the normal operation of Orin, the following fault alarm will occur with probability: (captured through Orin Debug UART), When a fault occurs, the CPU’s iowait will be very high, causing the system to be very stuck. At the same time, the system log cannot be recorded in syslog.
Jetpack Version: 5.1.2
[1352.469046] mmc0: cache flush error -110
[1352.555324] arm-smmu 8000000.iommu: Unhandled context fault: fsr=0x402, iova1
[1352.570736] mc-err: (255) csr_sdmmcrab: EMEM address decode error
[1352.577036] mc-err: status = 0x20064063; hi_addr_reg = 0x000000ff addr = 00
[1352.585266] mc-err: secure: yes, access-type: read
Please see the attached detailed log for reference.
mmc_err.log (6.1 KB)
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
please test with jetpack5.1.4 too. This error seems from IOMMU.
