FIXED!!! I could not have solved this without your help dimtass! My 1st solution worked by moving all sdmmc1 that were disabled to the enabled section. Now not one hiccup during bootup!
Here is the solution:
Remove all the sdmmc1 references except one in unused_lowpower to match 3.10.40 jetson-pinmux dtsi:
and make sure they are enabled: TEGRA_PIN_ENABLE
sdmmc1_clk_pz0 {
nvidia,pins = "sdmmc1_clk_pz0";
nvidia,function = "sdmmc1";
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
sdmmc1_cmd_pz1 {
nvidia,pins = "sdmmc1_cmd_pz1";
nvidia,pull = <TEGRA_PIN_PULL_UP>;
sdmmc1_dat0_py7 {
nvidia,pins = "sdmmc1_dat0_py7";
sdmmc1_dat1_py6 {
nvidia,pins = "sdmmc1_dat1_py6";
sdmmc1_dat2_py5 {
nvidia,pins = "sdmmc1_dat2_py5";
sdmmc1_dat3_py4 {
nvidia,pins = "sdmmc1_dat3_py4";
and leave disabled:
sdmmc1_wp_n_pv3 {
nvidia,pins = "sdmmc1_wp_n_pv3";
nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
